Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Regarding service manual for philips magnavox
Chassis part # is PTV835 for model # 9P6034C103 serial # 39657034 mfg date 5/2000. The flyback was replaced Sunday. when tv is turned on it turns on very quiet. Two things are happening now. First, all the colors are out of line .I believe these could be adjusted somewhere. Two, the picture came back. At first it went full size then picture started shrinking and then big again for as long as I had tv on. At least two minutes as if there was something stopping the picture from going back to normal size. Perhaps, an IC chip or a resistor about to short out, maybe. The sound was good. Could you advise us of what or where is the cause of these or would we be able to determine by looking at the service manual and or schematics. We appreciate your help and expertise.
  • 2 more comments
  • jc_rider Aug 18, 2008
    At first the picture is small...then it gets large...the small again...for about 5 minutes and then it was fine. (kind of like it needed to warm up or something. Now, there is no picture or sound at all. Phillips Mag. 9p6040c104 model number.
  • dewsgirl93 Nov 29, 2008
    We have the same problem. Picture big than small. Now it has gone completely but we do still have sound.
  • thebuzbees Feb 25, 2009
    same problem tv screen shrinks in from the sides and also has a green or red line around outside edges
    the tv screen moves inward from edges with red and green halo colors around edges .It jumps back and forth as if it needs to warm up
  • Philips Master
  • 3,459 Answers
You can also get a Factory Service manuals from www.magnavoxhelp.com. The manuals can be downloaded instantly. They are complete with over 2000 pages in all.
Their manuals cover all projection TV models with Chasis # PTV835, PTV836, PTV840, PTV841, PTV842,PTV843, PTV844, PTV847,PTV853
Posted on Jun 24, 2008
  • Edward
    Edward Aug 20, 2008
    JC - this is a common problem with this model. The site www.magnavoxhelp.com has a chip kit to fix the video shrinking problem.
  • Edward
    Edward Oct 12, 2008
    If you have any of the following problems you may want to check the site www.tvrepairkits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
    Symptom: Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
    (Note: The below symptoms typicaly occurs after having the expanding/shrinking screen problem above)
    Symptom: No Audio or Video but power light is on
    Symptom: Audio works but no Video. Power light still work
    Symptom: No Video. Audio is intermittent. Power light still works
  • Philips Master
  • 8,617 Answers
Contact me at slinteriors@yahoo.com and i will send you the service manual. It has over 2000 pages with a step by step trouble-shooting flow chart.
Posted on Feb 12, 2008
I need a owners manual for my TV.
you can get one for free at the following link just let them know your model number in a emmail by clicking the contact link on the lower left side of their page.
http://servicemanuals.vstore.ca/
Apr 12, 2009 | Televison & Video
NO PICTURE ON MY TV BUT I DO HAVE SOUND.
Check all your cables, make sure CRT boards are tight. Make sure you put the black ground wires back on the tubes. Also make sure that no fluid has spilled on the circuit boards.
Mar 27, 2009 | Philips Televison & Video
Can You PLEASE help me
Common problem and fairly easy to fix.
Problem
Solution:
Check with the site www.TvRepairKits.com. They have built a kit to fix this problem.
Jan 22, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox Video Shrinks over and over
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
Works on the following Philips Magnavox sets with chassis number
PTV835, PTV836, PTV840, PTV841, PTV842, PTV843, PTV844, PTV847, PTV853
Or if your Model number is...
50YP43C101,50YP43C102,50YP44C101,50YP44C102,50YP44C103,50YP44C104,55P9161001,55P9161002,55P9161003,55P9161004,55P9271001,55P9271002,55P9271003, 55P9271004, 55P9271005, 55YP43C101, 55YP43C102, 55YP43C103, 55YP43C104, 55YP44C101, 55YP44C102, 55YP44C103, 55YP44C104, 55YP45C, 60P9161001, 60P9161002, 60P9161003, 60P9161004, 60P9271001, 60P9271002, 60P9271003, 60P9271004, 60P9271005, 60YP43C101, 60YP43C102, 60YP43C103, 60YP43C104, 64P9161001, 64P9161002, 64P9161003, 64P9161004, 64P9161005, 64P9161006, 64P9271001, 64P9271002, 64P9271003, 64P9271004, 64P9271005, 64P9271006, 64P9271007, 9P5031C101, 9P5031C102, 9P5031C103, 9P5034C101, 9P5034C102, 9P5034C103, 9P5040C101, 9P5040C102, 9P5040C103, 9P5040C104, 9P5044C101, 9P5044C102, 9P5044C103, 9P5044C104, 9P5511C101, 9P5511C102, 9P5514C101, 9P5514C102, 9P5531C101, 9P5531C102, 9P5531C103, 9P5534C101, 9P5534C102, 9P5534C103, 9P5540C101, 9P5540C102, 9P5540C103, 9P5540C104, 9P5544C101, 9P5544C102, 9P5544C103, 9P5544C104, 9P6031C101, 9P6031C102, 9P6031C103, 9P60349101, 9P60349102, 9P60349103, 9P6034C101, 9P6034C102, 9P6034C103, 9P6040C101, 9P6040C102, 9P6040C103, 9P6040C104, 9P6044C101, 9P6044C102, 9P6044C103, 9P6044C104, 9P6440C101, 9P6440C102, 9P6440C103, 9P6440C104, 9P6440C105, 9P6444C101, 9P6444C102, 9P6444C103, 9P6444C104, 9P6444C105, PV5571C101, PV5571C102, PV5571C103, PV5571C104, PV6071C101, PV6071C102, PV6071C103, PV6071C103, PV6071C104
Dec 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
OPERATING A MAGNAVOX TP3170 C101
i would try the magnavox website,just go to support or customer service and they should have a manual there.if not let me know how you make out.
Dec 07, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
NO PICTURE HAS SOUND
I had the same problem. Check www.magnavoxhelp.com for instructions on how to fix it.
Jun 23, 2008 | Philips Magnavox 51MP392H Rear Projection...
My 60" Philips Magnavox, model 9P6034C103, chassis PTV835
It could be the flyback losing resistace in its windings. What is the chassis number I should have the service manual for it. Phillips/magnavox is hard to cross reference without the actual chassis number.
Feb 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
When you say small do you mean shrunk up top and bottom as well as from side to side. You definitely have a deflection problem either horizontal or vertical.If the picture just shrunk top and bottom you have a vertical deflection problem. Do you have the service manual for your model? If not let me know and I will email you one. Describe the shrinking issue a little more and I should be able to give you some guidance.
Feb 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Buttons won't work
You will probably need the service manual for both chassis to straighten that out. I am posting a link where you can purchase one manual that covers the entire series for magnavox PTV 836-PTV 835 it has 2,440 pages. It cost 19.99 and they will email it to you and provide you with free unlimited support that goes with the manual purchase. here is the link if interested in getting the service manual.
Jan 23, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
1,106 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
