Question about ASUS P4S333-M Motherboard
No Beep, Power supply problem?
I have the ASUS P4S333-M Motherboard that worked great before my Power Supply failed. So, i searched for a used one on ebay and came across a user that seemed to be reputable.
However, no initial beep can be heard and no video monitor is being displayed. I am getting the green light on the motherboard and I can even the hard drive boot up perfectly fine.
My main question of concern right now is do i need to have the same input voltage on my power supply??
The old One is an:
Achieve ATX300W/P4 input 100v-127v/8A 60 hz 200v-240v/4a 50hz
My new Power supply is as follows:
SPI FSP300-60ATV input 115v 10a 60hz 230v 5a 50hz
Everything else operated seemingly well before the power supply failure, so i do not think it is the RAM or the CHIP causing the difficulty.
Is the power supply input range my suspected problem?
thank you all.
  • Hoodsta Dec 08, 2008
    Did you find a fix for this motherboard? I have the exact same one, but can not get any life from it, except the green light does come on. No fans will spin, no beep - or bios post.
    Did a new power supply work for you?
    Problem Solver:
  • 10 Answers
It also came from power supply,but i suggest that u need to reset bios first, if problem not solve remove cmose battery for 12 hour then check
Posted on Feb 12, 2008
My asus ee pc atom dual core is not starting it is showing a black screen with ASUS showing and its not booting
Remove anything that's plugged into it (USB keys, USB mouse etc.)
Try power up. If fails, continue.
Remove power supply, and battery. Hold power button for 1minute. Insert battery and power supply.
Hook up to external monitor/tv. Power on. Can you see anything on the TV?
Remove the RAM chips. Try power up. Does it beep?
If NO then your motherboard is broken (specifically issue with CMOS)
If yes, could be graphics related.
Bring it to a PC shop for full diagnosis.
Jan 20, 2014 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Sounds and lan
go to
http://support.asus.com/download/download.aspx?SLanguage=en-us
select motherboard
select socket 478
select p4s333-m
click search
select your os and then select to download the sound and lan drivers
Sep 24, 2010 | ASUS SiS Chipset P4S333-M...
ASUS P5RD1-V MOTHERBOARD BOOT PROBLEM
It sounds like you have a dead battery on your motherboard.  Just replace it and your settings will remain.
Nov 14, 2009 | ASUS P5RD1-V Motherboard
I get no beep tones nor video card output on new P5N-D motherboard.
Check if the power supply is working. If it does not working then it is the power supply. Change the motherboard power supply.
Nov 07, 2009 | ASUS P5ND2-SLI Deluxe Motherboard
Dont't boot anymore since my power supply died
When the power supply failed, it took the motherboard out at the same time. Time to replace it.
Oct 17, 2009 | ASUS P5GD1 Motherboard
ASUS P4S333 no power
Asus motherboards are garbage, they die within a short period after being sold (perhaps they're even designed to die so that asus can sell more) Buy from a reputable manufacturer like foxconn, abit, gigabyte
Aug 09, 2009 | ASUS P4S333-M Motherboard
ASUS P5GD1-VM motherboard not booting when powered on
First are you sure it is the CPU fan and not the Power Supply fan? Open up the case and make sure the power supply cable is snug into the slot. Make sure that Pin 1 is lined up with Pin 1 on the motherboard. There should be a notch or red dot or different looking Pin to show you where pin 1 is...sounds like it may be a connection problem from power supply to motherboard...try that and let me know what happens we have other options but have to start somewhere..
Mar 06, 2009 | ASUS P5RD1-VM Motherboard
P4S333-VM motherboard wont power on
90% am sure that your motherboard is DEAD...those kind of things happen due to high damage to the CHIPSET...(ex:-Thundering - shocks from telephone line is directed to the modem)...
>> The Green light is only to indicate that power is recieving...
>> It is better to check it from a repair center...
May 09, 2008 | ASUS P4S333-VM Motherboard
My asus p4s333-vm won't beep
you have basically replaced all the parts that could affect your system not to post. that would mean your motherboard is already damaged.
Apr 22, 2008 | ASUS P4S333-VM Motherboard
ASUS P4S333-M Motherboard Logo
162 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
