Question about Mitsubishi VS-45607 45" Rear Projection Television
Vs-45607 would the 9 volt regulator effect the color too.
    Champion:
  • 206 Answers
The 9 volts power many things the microprocesser is one of them, if the voltage is dirty because a filter cap is failing color will be afected as well
Posted on Feb 13, 2008
The picture on my Mitsubishi Model VS-45607 is not staying on track and scrolling continually
Good Day,
It sounds like you have a bad cap or IC. Replace C2P05 100 ufd 16 volts, off Pin 3 of IC2P01. It is on the Signal Board. IC2P01 Part # 270P466020 (stand-up type mounted on heat sink). The Signal Board is the the board on the left hand side looking at the TV from the back. The parts are on the right side of the Signal Brd towards the middle and back. Replace it even if it checks good. Look at other Caps in the general area and if you see black stuff on the negitive leg of those caps(replace them also).
Good Luck, Big Irish.
Dec 02, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Vs-45607 Vertical Hold Problem
Good Day; Just replace the caps first, 99.9% fix if not replace 9v regulator. Good Luck, big IRISH.
Nov 23, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Screen gets horizontal lines and jumpy screen.
Your problem is capacitors CP204 and CP205 by the 9 volt regulator on the main board. Cp204 is a 47 microfard @ 50 volt and the other is 100 microfard@ 16 volts
Nov 13, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Do i need a new circut board???
Good Day;
I don't think so. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
I have repaired 50 or 60 of these.
Aug 16, 2008 | Mitsubishi VS-45607 45" Rear Projection...
TV screen shrinking from top to bottom.
My Dearest, j30;
It sounds like you have a problem in the 9 volt circuit which feeds the vertical output ciruit; CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
This is not a repair that a novice should try, but if you call a factory authorized service center and have them come out and give you an estimate; AND tell them what the problem is, you will look know what you are talking about!
Aug 11, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Vs-45607
Good Day, chefkenny;
This the fix ya you are looking for;
Aug 07, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Intermittent vertical jitter on mistubishi tv 65000
Good Day, sdkhanmd; Replace C2P05 100 UFD 16 VOLT off pin 3 IC2P01 and IC2P01 part #270P466020 (9 volt regulator). Both are on the signal PCB. Also, check other caps in area for leakage. Hope this was helpful, this common for this model. Good Luck, big IRISH.
Jul 21, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
This should resolve your TV"s condition.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
I have stripes going thru my screen
Any other electronicc components within 3 feet of the set?...accordianman
Feb 15, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Vs 45607
Yes, replacing a voltage regulator IC requires soldering.
Feb 14, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
