SOURCE: maclaren quest pushchair.
Ok, I will try to do this step by step.
1. Place flat screw driver under hub cap and pry off (these we will reuse later).
2. Using diagonal pliers, cut star locks from axle, you should have received new one from Maclaren when you got the wheels, if not you will need to get those.
3.Repeat this process for each wheel.
4. Take off the old wheels and put the new ones on. Put on the new star locks (I use a small hammer), put the hub caps back on and viola, new Mac wheels.
SOURCE: Can't fold maclaren mac 3 pushchair
Just below where the handle bar part meets the rest of the frame, on the left and right side you will find black plastic bits that point down, which you can slide your finger behind. The right hand one has a silver button which you need to push in. Then pull both of the plastic levers towards yourself and push down at the same time. The Mac 3 will then fold down.
SOURCE: broken 5 point harness on maclaren quest buggy
Hi this is sarah from Maclaren,
you can email our spares department at:
[email protected]
and they can point you in the right direction!
SOURCE: How to remove, clean, reinstall seat on Maclaren Techno Stroller
If you follow this link to the instrucitons on the maclaren website, the instructions tell you how to remove clean and reinstall the seat. http://us.maclarenbaby.com/toddler-buggies/techno-xt?lang=en
If you have any trouble call maclaren customer service at 1-877-443 4622
hope that helps!
1 877 442 4622
[email protected]
SOURCE: I need a replacement safety clip for a Maclaren's techno pushchair
try this website
http://myebestbuy.com/allplasticbuckleslist-1.aspx
lots of buckles
