Question about Sony CDX-4000X CD Player
Cuts off when driving
Whenever i crank my car up and press the gas my cdx 4000x cuts off. It only comes back on whenever i slow down and approach a stop sign. Do Anyone know the answer?
    Scholar:
  • 82 Answers
Based on your statement I can see three (3) possible problems:
1] Your CD player is not connected properly to your power supply or something is eating the voltage coming to your CD player. To fix this possible problem you have to check the connection of your CD player to the power supply, you must check if the voltage of your car's battery and compare it to the voltage coming to your CD player and be sure it is not bypassed by any other connection. To be sure there is no other connection bypassing your CD player, connect it directly to your car's battery or you may use an independent battery for the CD player.
To do this, connect the +wire of your CD player to the +terminal of your baterry, and then the -wire of your CD player to the-terminal of your car's battery.
2] Another possible problem that I can see is that there is an overload in your car's circuits. The possible solution is that you remove other component that is connected to your car's battery.
3] Another possible problem is that your car's battery is low in voltage already. The possible solution is to recharge your car's battery or buy a new one.
4] Another possible problem is that their is loose connection within the CD player that is triggered by the car's movement.The possible solution is to check the internal connections of your CD player. If something is loose you must connect it firmly.
I hope I solved your problem.
Posted on Feb 12, 2008
1992 chev lumina 3.1 eng. cuts off intermittently. sometimes when driving down the highway and others when idling around a carry-out resturant. Put in neutral and it starts back up. I have replaced the...
DO you have any engine codes still remaining? IF car restarts right away its gonna be tricky finding out what is dropping out. Engine codes are the best clue to start the hunt for problem. From experience however, I have had a few of these come in for same symptom. There are two wires that run from Ignition module/coil pack to the crank sensor, insulation falls off and they melt to each other or to hot engine, intermittent short disruption of signal, hence car stalls whenever wherever and restarts right away.
May 11, 2011 | 1992 Chevrolet Lumina
I need wiring diagram for CDX 4000X
Here is a link to Sony for your CDX-4000X wiring pin outs with color code.
http://www.docs.sony.com/release/specs/CDX-4000X_Spec_Sheet.pdf
Dec 06, 2009 | Sony CDX-4000X CD Player
Engine cuts out whenever gas tank is filled.
The vapor recovery system improperly hooked up.
Jun 29, 2009 | 1998 Toyota Camry
My car will start and then after a minute or two of running, the car will idle down and cut off but I can start it right up again and still get the same results. Whenever I put it into gear to drive it...
Sounds like a possible clogged fuel filter or bad fuel pump. The system provides and initial extra pressure to pressurize the system then pump pressure drops to normal. If pressure is low or filter clogged decreasing available volume the symptoms you describe are the result.
Apr 25, 2009 | 2002 Chevrolet Malibu
First scan the PCM for trouble codes using a hand held engine scanner, Then repair codes by replacing failed sensor as needed.  If no codes are present try replacing the idle air control motor.
Auto Zone will scan your car for codes for free so you know what your going to have to replace and they do have a how to do it your self instructions to what your going to replace.
Good luck and hope this helps
Apr 20, 2009 | 1997 Pontiac Grand Am
the stalling prob when u come to a stop might be ur torque convertor there a wiring plug for it on the transmission unplug it see if thats helps
Apr 13, 2009 | 1997 Pontiac Grand Am
Motor cutting out
ok you need to change your idle soliod so that the rpm stays up and gradualy comes down
Apr 12, 2009 | Daihatsu Charade Cars & Trucks
Sony CDX-4000X CD Player Logo
162 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
