Tip & How-To about Office Equipment & Supplies
HP Office Jet All in One : Resetting Steps
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
NVM Reset
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards,
Rizwan
the printer takes several minutes to print one page all ink cartridges are full and paper tray is full it just started doing this
Please try below two resets and let me know the performance.
Power Drain:
Partial Reset
Regards
Riztech
buttons dont work
Do you see any error messages in the LCD display?
Try resetting the printer as below
Power Drain:
Partial Reset
Semi-Full reset
printer displays error code 0x838a2200. Unable to reset; help!
Try below resets
Power Drain:
Partial Reset
Semi-Full reset
The printer will not turn off. There is no communication with the computer.
Power Drain:
worked yesterday, now will not turn on!
  • Try connecting the printer directly to wall outlet without surge protector.
  • If the problem exists reset the print, see below steps to reset it.
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards,
Riztech
k24674
ADMIN Andrew
ADMIN Andrew
