Question about Brother MFC 420CN All-In-One InkJet Printer
Magenta Near Empty??
The ink cartridge is half way full, but I can't get it to stop saying "MGT Near Empty", even after I just put a brand new one in!
  • 832 Answers
This is only a reminder! The cart will show "empty" when it is really empty. You can print on until the printer stopps because of empty cart (and prints on when it is replaced).
Take the new on out and put it in again. answer display question with "1" (Yes, cart changed). "Near empty" Message will disappear.
Posted on Feb 12, 2008
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
My printer says install magenta what does that mean
It means for you to install the magenta ink. Magenta is a color. You have 4 colors. Yellow, magenta, cyan, black
Oct 14, 2009 | Brother Multi-Function Center MFC-240C...
Machine says that magenta is empty, cartridge level reads empty. But when I put a new magenta cartridge in it reads no cartridge open cover and reinstall magenta cartridge. The cartridge is full and is a...
maybe it have the ink level chip which can be resetted by removing the cartridge and oning and offing the printer for 5 times within 10 minutes coz it saves data of a cartridge upto 5 use before only.. and 6th time insert it.
Sep 28, 2009 | Brother MFC-5460CN All-In-One InkJet...
New Ink Cartridges display low
yes it is not original you buy a new original one then show ink position
Jul 20, 2009 | Canon PIXMA MP780 All-In-One InkJet...
How do i replace cartridge
On the right hand side of your machine-FRONT-right there is a panel that should have come with a sticker on it, you may have taken the sticker off so anyway, it is the ONLY panel on the front right side it just pulls down, put your finger on the rigth side of the machine yhou will feel a little indent and then pull it down, and there are your four ink cartridges. Each cartridge must be replaced individually and on the bottom of the panel you pulled down it will be labeled (B for Black, Y for Yellow, C for Cyan and M for Magenta, and each print cartrdige should also be colored to make it easier as well). Anyhow, you pull the little plastic purple tab that is covering each ink cartridge (in the machine) forward towards you and it should release the cartridge for you to pull out and dispose of) every now and then I have a little trouble and need to use something to help me get started pulling a cartridge forward-just like the tip of a pen or something but you should have no problem with this, and then you put the new cartridge in-the way it says-there should be an arrow on it showing you which way to put it in (also look as you pull the old one out) and as you push the new one in, the plastic tab will click shut and you will hear a "'spray sound". When you are done, close the cover and the machine will first do a "cleaning" before it is ready to be used again. Here is a tip for you as well, this machine WILL NOT WORK if you have any empty ink cartridges, they ALL must have some ink in them for you to print anything, even if you just want to use black, you have to color cartridges as well, I try to use every last bit of color before replacing a cartrdige, I wait until IT MAKES ME REPLACE IT by saying "empty black cartrdige" before I replace it "near empty" is NOT ENOUGH to replace it, mine has been saying "near empty magenta" for weeks now and it still works fine, it just wants me to replace with a new one and waste more money as this ink IS VERY EXPENSIVE, it cost me over $75 to replace all four ink cartridges, the best deal is to get the combo pack with all the colors, or the one with the three colors and then the double black pack. some colors will obviously get used quicker than other colors, so like I said, I have been waiting to replace that "near empty magenta" UNTIL I HAVE TO, as it hs been telling me to do so for weeks now, and I have a replacment in the drawer but once I replace it, it is like throwing money in the garbage since the one that is near empty, is FINE sitting in there while I PRINT OUT BLACK AND WHITE COPIES most of the time anyway, it just won't let you print if ANY of the cartrdiges are ACTUALLY EMPTY, even if you are not using that color, you still cannot have an empty cartrdige or NO cartridge in the machine, it just WIL NOT WORK. GOOD LUCK.
Jun 16, 2009 | Brother MFC 240C All-In-One InkJet Printer
Ink levels are not responding.
Did you buy a brand new or remanufactured/refilled cartridge? Some cartridges will show empty, even when full.
They want you to buy brand new, brand name ink!
Jan 05, 2008 | Lexmark P4350 All-In-One InkJet Printer
Ink cartridge lights blinking
That is happening because you have "smart" chips on your cartridges, so even though you know there is still some ink left in the tank, if the chip says stop, the printer will stop printing. There is a way to bypass that and that is by using a re-setter. You can either buy one or ask to re-set your cartridge in a refill shop.
You can also try holding the "resume" button (triangle in circle for about 10 seconds for each cartridge, sometimes doing that resets the cartridges.
Do not refill the magenta and cyan cartridges if they are not empty, you'll just be wasting your money. Better use it to buy a re-setter ;)
Hope that will help!
Nov 27, 2007 | Canon PIXMA iP6700D InkJet Photo Printer
Brother DPC- 115C
What error does the machine show up?
Plz give some more info in detail!!!!!
Oct 24, 2007 | Brother DCP-110C All-In-One InkJet Printer
Screen reads "Near empty Cyan" but I just replaced the Cyan ink cartridge, its full.
If the firmware update doesn't work, you can reset this error.
Unplug unit. Remove offending cartridge. Plug unit back in, wait until all startup noises have stopped. Open lid and reinstall cartridge. This will solve the fault as long as the sensor is working.
Also, please be aware, you should not have to change a cartridge if it says "Near Empty", only if it says "Ink Empty Magenta".
Also, please make sure none of your other cartridges are empty. I have seen this over and over. Two cartridges empty at the same time, and the person replaces one of them but thinks they actually replaced the other one.
Turn the power off and pull all the cartridges out. Look a the side of the cartridge, you should see a window with a little plastic tab sticking out. This tab should be blocked by a black float inside the cartridge. If you cannot see the float, and the tab is clear with no ink in it and no float tab blocking it, it means the cartridge is empty even if you still see some ink in the bottom.
To be sure plug the machine in without any cartridges. When all the noises have stopped, open the lid and install the cartridges. If you're still getting an error saying either a cartridge is not installed or is empty, then one of your cartridges is empty. Redo the previous paragraph.
Oct 05, 2006 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
202 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
