posted by KodiF on Feb 12, 2008
I have a 2Wire 1701HG Gateway, I was wondering if i could hook it up to a working network and use it for just a wireless router?
Best Solution
posted on Feb 17, 2008
If you want to setup wireless network then......
you need to config your router for wireless network..
for that you need to open router configuration page or either you can run the disc you got with your router..
in that it gives you an option of wireless network..
it will ask you to type in a network name ssid give any name you wish to your network..
it will also ask you to type in a password for network...
choose wpa-psk security and type any secure password in 8to 63 charactersand apply and once it's done...
now if you're on windows xp then click start>then control panel>network connections>then rt click wireless network connections and click view available wireless networks there you'll find your network name ssid in it select it and press connect..it will ask for your 8-63 characters password type in the same press connect it will say connected..
unplug ethernet cable and try opening pages ie..
If you're on vista then click start>connect to>rest is same as above...
Rating Locked! (?) KodiF has rated this solution as Helpful
This Problem Also Relates To:
2wire 1800HG Router (RG1800HG00)
2wire 2700HG-B Router (2700HGB)
Motorola WR850G Router (DHWR850G)
Motorola SBG1000 Wireless Cable Modem Gateway Router (493989-001-00)
3Com 1 x T1?CT1?PRI WAN - Router The Router 3000 Family extends your wide area network reach to ...
Actiontec (GT704WG) Router
Actiontec GT704WG Wireless Router (gs583ad3-01)
Can you Help with these Routers problems?
Linksys Wireless-G WRT54G Router
I get an excellent connection
I get an excellent connection... Answer This...
Linksys Wireless-G Broadband Router
Linksys Wireless-G 2.4Ghz...
I have a Linksys Wireless-G... Answer This...
Netopia 2247NWG-VGx Wireless Router...
help router/nat 2 strict
when i ply my gta4 on my ps3 it... Answer This...
Repair Service
Find Router Repairman Near You:
