Question about HP DeskJet 970cse InkJet Printer
Won't pick up the paper but the cartridges move up and down the line
The same ol' it was working fine then all off a sudden, it didn't seem to pick up the paper. When it did, it jammed. When I pulled the paper out, it then seemed to reset itself and printed ok 2 weeks. Now, I'm back to the same problem, it won't pick up the paper, but makes the rolling noise, moves the cartridges left then right, then left then right, then a very mechanical sort of crunching noise like it is trying to either pick something up or release something under the lights section but can't.
I've already replace the cartridges. And I'm trying to shine a light to see under the lights section in the right, but I can't see what is catching when it makes the noise.
Any ideas?
  • ilecooper Feb 22, 2009
    Is there a way to fix this problem? The feed paper light stays on and no matter how many times I click on it, the paper won't be fed to be printed on. Please help!
  • 28 Answers
Hai Boss it is not the problem with the Catridge . Some of the Spring has begin missing in assemble part . you pull the paper out the problem cause from there never ever pull the paper ..
Posted on Feb 12, 2008
I have a problem with my printer, when i switch it on the cartridge carrier moves to the left and all of a sudden the rollers rotate fast afterwards the cartridge carrier moves back to the right again and...
The machine is not detecting paper in it. If you have paper loaded in the machine, then your paper tray needs to be adjusted so that the rollers can pick up the paper. There is a plastic lever that you press and push up to the end of the bottom of your paper when its loaded in the tray. Remove the paper tray, load it with fresh paper and put it back in. Press the plastic lever and push the paper all the way up to where it is supposed to be to make sure that the rollers can pick it up. Then clean any documents that have not printeed out of your print que. You can find the print que down by your clock on the bottom right side of your screen. Click the arrow and look for a picture of a printer. Right click on top of the printer icon and delete documents that are pending. That should solve your problem.
Oct 14, 2011 | HP Deskjet D2660 All-In-One InkJet Color...
I just put in a new toner cartridge and it was working well a couple days. The toner is fine but the paper light keeps coming on. At first, the paper was stuck around the toner cartridge and now, the...
Hi Chris!
As you described, I didn't see anything would cause the problem. Just suggest that you could give it a clean. Sometime just because you use it for a while(finish a toner cartridge), it get dirty. Unplug the power, and gentl take out the cartridge, paper tray then clean the roll and surround with wet clean paper. Give it a try and see what happen. Please make sure that you do it gentle when put back things.
Hope this will help. Thanks for reading.
Jul 19, 2011 | Brother HL-2040 Laser Printer
We just moved, and now that I've set the printer up in a new location, the paper won't feed at all. I removed the cartridge and wipped the paper feeder with alcohol still no luck
Hi
When you move the printer normally somethings will brake and get stuck. But 1st things 1st did you check if the tray lifts to take the paper? or try to take the paper atleast? if not then you can try to wiggle the printer a little and you should fine some thing being stuck come out and the printer work well again.
PLZ RATE MY SOLUTION
Jul 06, 2011 | Samsung ML 2010 Laser Printer
Paper catch rollers out of alignment
Hi.
Try this
1.take a sheet of paper ,,fold it length wise 2-3 times to make it thick.insert this into the paper feed tray...move it left and right a couple of times..this clears the obstruction if any..
if this does not work..call lexmark tech support,,,your printer would be replaced if in warranty..
good luck
Jan 25, 2009 | Lexmark X5470 All-In-One InkJet Printer
Hp PSC 1410v All-in-one will not pick up the paper
Remove the paper cassette and the toner cartridge then turn the machine upside down and look at the rubber roller. It SHOULD NOT spin freely.
Roller drive tabs will sometimes break
Jan 24, 2009 | HP LaserJet 2200dn Printer
HP Desk Jet 3320 paper won't feed any more
Hi , I think the belt which moves the cartridge is worn out or it could be something to do with the sensor.check both and should work fine.
Jan 14, 2009 | HP DeskJet 3320 InkJet Printer
Will not feed paper
Sounds like the gears are out of alignment for the paper pick up tray.
May 28, 2008 | Brother HL-2070N Laser Printer
Print cradle cannot move error
hi,
this seems to be a hardware problem..... anyway try this...
> unplug the powerchord
> open the rear access door, and check whether there is any paper jammed or any bit of paper or thread stuck inside.... if so remove it
> clean the rollers using a lint free cloth
> close the rear access door
> open the door so that you will get full access to the cartridges...
> move the cartridges to and fro for several times manually with your hand
> close the door
> plug the power chord
> try again to copy multiple pages
thanks and regards
agnel
Mar 17, 2008 | HP PSC 1210 All-In-One InkJet Printer
Paper will not feed properly/one side of paper not feeding in straight
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
542
Dec 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Pictures with horizontal lines
I'm assuming the horizontal lines you're gtting are dark lines, not white omission lines and you are not currently using a cartridge that is leaking (otherwise, this solution is not appropriate). I had the same problem, and after a good deal of frustrating experimentation, found that the problem was caused by the cartridges picking up and retaining ink left on the little absorption pads where they rest. Normally, the pads should accomplish just the opposite effect, but it seems that after a certain amount of use (especially if you've ever had a defective, leaky cartridge), the pads just get too full. As the cartridge moves horizontally across your paper, ink picked up from these pads literally drips on your print. Could appear as lines and also as small smudge dots at the lengthwise travel stops where the cartridge travel reverses.
I could see that it would be fairly easy to remove the pads and either clean or replace them if I were to disassemble the housing of the printer. If you wish to do a really thorough job and you feel confident in your reassembly ability, go for it. I chose a quicker approach and it's solved the problem for the past two months: Open the lid and wait for the cartridges to move over to the left (cartridge replacement position). Then, pull the plug on your printer (or they will move back to the right after a few minutes). Use a small flashlight to locate the two absorbent pads over on the right, where the cartridges normally rest. With paper towels or any other absorbent disposable, blot those pads over and over until you get little or no ink on your paper towel. While you're at it, give the whole area under the lid a decent but gentle cleaning using a soft cloth or swab. Might take a couple of prints to completely eliminate the lines, since you won't be able to clean the underside of the cartridge carrier assembly this way, but this should solve your problem
Nov 19, 2007 | Canon PIXMA MP150 All-In-One InkJet...
HP DeskJet 970cse InkJet Printer Logo
157 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
