Question about RCA RT2280 System
Rca rt2280 home theater
After being subjected to low or partial power for about 20 seconds, untill I reset generator fuse, I no longer get sound. I don't know where or what that piticular low power fuse looks like or where it is located. I'am good at soldering. Where is it, what color, shape, ect. Can I really do this? I hope! please help......drg....drgenaro2@yahoo.com
  • Anonymous May 02, 2008
    I get no sound from speakers when trying to do surround sound but the radio does work
Hi my son lost my tv remote for my toshiba tv, i was hopping my rca universal remote could adapt to my tv but i do not know the codes how to program it does anywhone have a solution thanks.
Posted on Mar 24, 2008
No sound at all
Run through your menu settings to see what should be working, and not muted or in functions not being used. Otherwise have it checked by a technician, it may a power supply out or a bad digital sound processor board. Also check your speaker cords, they may be shorting, putting your unit in output shutdown protection.
Oct 28, 2013 | RCA RT2280 System
Hoooking up surround sounds with optical cable surround system is RT2280 AHHH please help my husband is driving me crazy to get it fixed and he cannot figure it out. Superbowl must be in surround sou
Make sure the digital setting (optical/coaxialor analog)is correct.
If youre connection is differet from default setting
1.select the source
2.press function
3.rotate multi jog to toggle among optical/coaxil/analog to match
yuor connection.
your selection will be stored automatically.
every time you press the source button the input setting(dvd/opti)
will be show on display.
heres a link to the manual go tto page 21 advanced settings.
http://www.google.co.uk/url?sa=t&rct=j&q=surround+sound+RT2280+AHHH&source=web&cd=4&cad=rja&ved=0CEMQFjAD&url=http%3A%2F%2Fsupport.radioshack.com%2Fsupport_audio%2Fdoc66%2F66651.pdf&ei=G2QMUbKqMOOY0QWJlYBw&usg=AFQjCNG2gc-bExNRynH2JEV22sR-L_ggDg&bvm=bv.41867550,d.d2k
Feb 02, 2013 | RCA RT2280 System
No sound from tv, dvd, cable. Speaker test does work. Sound stopped suddenly when channel was changed.
What does this mean: "when channel was changed"? TV channel?? Would that mean a remote command was issued? How about FM (no external cabling)?
Page 23...
http://www.retrevo.com/support/RCA-RT2280-Home-Theater-Systems-manual/id/402ag600/t/2/
Sep 02, 2011 | RCA RT2280 System
I have an RCA RT2280 Home theater system that hasn't worked properly for years. I put the system away in it's box for about 3-4 years and decided to give it a try. To my suprise the tuner was working...
Could be a bad connection on a voltage regulator. (most likely on a 15v line) And check for a bad capicator (one of the larger ones) 4700uf 16v I think. The cap may have vented or the top may have domed.
It is repairable, Parts and labor around $75-100.
Mar 13, 2011 | RCA RT2280 System
Rca rt2870 wont turn on
a fuse may need to be replaced
Jul 31, 2009 | RCA RT2280 System
I have RT2280. Audio levels used to be 1-50, now
Sounds to me as if someone may have gotten into the menu to adjust the individual levels of each loudspeaker and cranked some of them way up. As to why the "main" volume level goes from1-20 now as apposed to 1-50, you got me there...
Is there a reset button or equivalent on the remote or the unit? Try that. Try unplugging the unit for 15 minutes...
Here's the owner's manual:
http://support.radioshack.com/support_audio/doc66/66651.pdf
See page 21 for advanced volume control functions...
Mar 04, 2009 | RCA RT2280 System
Buzzing sound through the speakers
Sounds like you are getting interferance from something like a cordless phone, TV, Computer something like that.
Feb 08, 2009 | RCA RT2280 System
RCA 2280 Optical Input w/PS3
The only optical option is through the satalite function. After I hooked up my xbox 360 with optical audio, I pushed the SAT button on the front of the RCA receiver then turned the multi jog wheel until it read "optical" out came surround sound. I hope this helps you.
Dec 07, 2008 | RCA RT2280 System
Rt2280 no power up, no display, standby light works
Might be the relay on the power board that stands up just behind the big transformer. I has a complete no power also, I shorted out the relay legs on the black one, it started to work again. I will probably replace it, since the problem started by the system shutting off randomly.
Oct 19, 2008 | RCA RT2280 System
RCA RT2280 surround sound mode button wont select 5.1 dolby digital mode.
I had the same problem and this is what I did to fix it. Assuming that all of your equipment is powered on, (tv, blu-ray/dvd, rca receiver) you'll need to go into your dvd players audio menu and select the dolby digital audio.
Once you do this, the digital signal is sent to your receiver from the dvd. The receiver should automatically set itself to the dolby digital preset. If it doesn't, press the surround button until you reach it. I found part of this information here. And the rest was personal experience.
Also, it depends on if the disc format is in dolby 5.1. I hope this helps you.
Dec 18, 2007 | RCA RT2280 System
RCA RT2280 System Logo
258 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
