Question about Lexmark P4350 All-In-One InkJet Printer
Lexmark P4350 AIO incorrectly identifies cartridges, will not allow printing
When attempting to print on the P4350 printer, error message says the wrong cartridges are installed, and will not print. I have the correct cartridges in, and it was working at one point...
not sure what all was done to try to fix this, it's a friend's system, going over to look, just hoping for some ideas before taking this on.
was working on Vista, when it started messing up, they moved it to an XP machine. Same error on the new puter.
Any thoughts?
thanks,
gary
  • vanwyke Feb 25, 2008
    Lexmark P4350 has been working OK using a refilled cartridges.
    It is now demanding "compatible cartridges".
    The p4350 screen identified the Black (Left) cartridge with a "X"
    and errorcode 1102.
    Have tried 1 Reloading the lexmark driver.
    2 replacing left cartridge with photo cartridge supplied
    with the machine
    Old cartridges work fine still, in photocopier mode.
    I am reluctant to invest £35 or so in new cartridges and still find I
    have a dud printer.
    Software is XP SP2
    I vanwyke
  • truckerjenks Jun 15, 2008
    my lexmark p4350 has been working fine,using refilled cartridge for the last 18 months,but now has come up with error 1102.any help appreciated need to get invoices out
    Genius:
  • 2,035 Answers
Some times refilled cartridges works fine,and in Lexmark cartridges
they do not support refilled onces ,Try a new compatible cartridge it should print ..
Posted on Mar 11, 2008
My Lexmark printer when turn on it makes noise and it can not print with a error code 2200
Hello thanks for using Fixya
The 2200 error message indicates a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message.
Step1.
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes:
Continue to step 2.
No:
Attempt a test scan. If the error message does not reappear, the error is resolved.
Step2. Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.Did the error message return?
Yes:
Continue to Contacting Lexmark.
No:
Continue to step 3.
Step3: Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes:
Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No:
Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Step4: Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes:
Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No:
Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Feb 11, 2011 | Lexmark P4350 All-In-One InkJet Printer
Your printer is not able to recognize the cartridges.Please do the following:
  • Turn on the printer and remove both cartridges
  • Place both cartridges in front of you so that you can see the contact foil, with the nozzles facing downwards
  • With adhesive tape, cover the FOUR upper contact points on the far left contact column of both cartridges
  • Reinsert the two cartridges and close the cover
  • Open the cover again after 2 or 3 seconds
  • Wait until the printer gives you the cartridge carriage (If there seems to be a problem with either of the cartridges, ignore it)
  • Open the cover and remove the two cartridges
  • Remove the adhesive tape
  • Clean the contacts, reinsert the cartridges and close the cover..
Goodluck..
Feb 25, 2008 | Lexmark P4350 All-In-One InkJet Printer
Show error2200
1.Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.
3.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved. Source(s): http://support.lexmark.com/index?page=co…
Apr 23, 2010 | Lexmark P4350 All-In-One InkJet Printer
Error 1203.consult user guide .write on my printer screen.and i nothing can to do.thanks for help
Overview
The 1203 error message is caused by either a communication failure between one of the printheads (cartridges) and the All-In-One (AIO), or by a short in one of the printheads. The procedures below will help you to resolve this issue.
Troubleshooting a Communication Error between the Cartridge and the Printer
NOTE: The embedded links in the table lead to specific troubleshooting documents.
Step Action
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on.
No: Print a test page. If the test page prints, the error is resolved.
2 Open the top cover of the AIO and remove both cartridges from the AIO.
Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4
Power off the AIO and remove the power supply from the back of the unit. Reinsert the power supply, and power the AIO on. Open the top cover of the AIO and insert the color cartridge. Close the top cover.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat step 4. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 5.
5
Power off the AIO and remove the power supply from the back of the unit. Reinsert the power supply, and power the AIO on. Open the top cover of the AIO and insert the black/photo cartridge. Close the top cover.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 5. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
NOTE: The embedded links in the table lead to specific troubleshooting documents.Step Action
1 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
2 Remove the cartridges. Clean the cartridge contacts and the AIO carrier contacts .check the link for cleaning http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:590:0:0&framed=&docid=ENUS24064&relevance=0
Defective Cartridge Check
To test the cartridge, replace it with either a new cartridge or a known good cartridge from another printer of this type. If the error message persists, proceed to Contacting Lexmark.
Please rate my response!!
Jan 28, 2010 | Lexmark P4350 All-In-One InkJet Printer
I have just change printer cartridge, the display is now showing printer error 1203 followed by cartridge missing could you assist me with this issue please
Hi!
To resolve the printer error 1203 on your Lexmark X5470 All-In-One (AIO) Inkjet Printer, you need to perform the following tasks---
Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on. if the error message return then continue to print a test page. If the test page prints, the error is resolved. If still the power persists then you need to open the top cover of the AIO and remove both cartridges from the AIO. After that power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on and if the error message return then there is a hardware problem with the printer. If error message not return then you need to again power off the AIO and remove the power supply from the back of the unit. Reinsert the power supply and power the AIO on. Open the top cover of the AIO and insert the color cartridge. Close the top cover. If the error message returns then you need to clean the cartridge contacts.
Again try to rest it by powering off the AIO and remove the power supply from the back of the unit. Reinsert the power supply and power the AIO on. Open the top cover of the AIO and insert the black/photo cartridge. Close the top cover. Now print a tests page. If the test page prints, the error is resolved.
1 Open the top cover of the AIO and remove the cartridges.
2 Remove the cartridges. Clean the cartridge contacts and the AIO carrier contacts.
Checking the Cartridge
To see if the cartridge is defective, replace it with either a new cartridge or a known good cartridge from another printer of this type.
1. Turn the printer/All-In-One off and unplug the power cable from the outlet.
2. Open the printer/All-In-One lid so that the cartridge carrier can be accessed.
3. Remove the print cartridges. (For information on cleaning the cartridge contacts, click here.)
4. Using a dry, clean cloth wipe the carrier contacts gently from top to bottom.
5. Repeat Step 4 for the other cartridge slot (if applicable).
6. Reinsert the cartridges, slide the cartridge carrier to its original position, and close the printer/All-In-One lid.
7. Plug the printer/All-In-One back into the power outlet and turn it back on.
You should only follow the steps below to resolve a print quality problem if you have already attempted to solve the problem by printing a "Clean Print Nozzles" page.
Cleaning procedure - Remove the print cartridges. Moisten a clean, lint-free cloth with water. Gently hold the cloth against the nozzles for about three seconds, and then wipe in the downward direction while keeping the print head in downward position on the cloth. Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and then wipe in the upward direction of the print head.
With another clean section of the cloth, repeat steps 2 through 4 above. Allow the nozzles and contacts to dry completely. Reinsert the print cartridges. Print the document again. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times.
If still the error message persists then you need to contact the Lexmark.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
I have a Lexmark P4350, I put a new 33 color ink cartidge in and it does not reconize it and has an Error 1102
The 1102 error message is caused by a communication failure between one of the printheads (cartridges) and the All-In-One (AIO).
The procedures in this article will help you to resolve this issue.
Please follow the steps given below:
Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO back on.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark below.
No: Continue to Step 4.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power on the AIO.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 4 and 5. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
No: Continue to step 6.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
7 Insert the black/photo cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
Step Action
2 Remove the cartridges and clean the cartridge contacts (click here for instructions) and the AIO carrier contacts
(click here for instructions).
Apr 03, 2009 | Office Equipment & Supplies
What does error 1203 Mean?
Overview
Step Action
5
Mar 11, 2008 | Lexmark P4350 All-In-One InkJet Printer
Printer Error
Step Action
5
2 Remove the cartridges. Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts
Mar 04, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark x5470
A Right Cartridge Incorrect message generally indicates a communication error between the All-In-One and the cartridge. This can be caused by a faulty cartridge; however, it may be due to a simple interruption in the communication between the cartridge and the All-In-One.
The procedures below will help you to identify the cause of the error and resolve the issue.
Rebricking the All-In-One and Resetting the NVRAM
Step Action 1 Power off the All-In-One and remove the power brick from the back of the unit. Wait 20 seconds. Then reinsert the brick and power the unit back on.
2 Reset the NVRAM of the All-In-One
Yes: Continue to Checking the Cartridges.
Step Action 1 Open the top cover of the All-In-One. Remove both cartridges. Close the top cover. 2 Power off the All-In-One and remove the power supply brick from the back of the unit. 3 Reinsert the power supply brick into the back of the All-In-One and power the unit back on.
Does the error message reappear?
Yes: Skip to Contacting Lexmark. There is a hardware issue with your printer and you need to contact our technical support center.
No: Continue to step 4.
4 Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts (click here for instructions). Continue to step 5.
5 Power the AIO on, reinsert the black/photo cartridge, and close the top cover. Power the All-In-One off and then back on.
Yes: Power the unit off and try step 5 with another black/photo cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
6 Power the AIO on, reinsert the color cartridge, and close the top cover. Power the All-In-One off and then back on.
Yes: Power the unit off and try step 6 with another color cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Try printing a test page. If the test page prints, the error is resolved
Nov 11, 2007 | Lexmark X5470 All-In-One InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
248 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
