Question about KitchenAid KHWS02R Front Load Washer
Fault problem control panel shows f02
  • gillian215 Dec 09, 2008
    Where is the drain pump filter?
  • 770 Answers
F02= LONG DRAIN
If the drain time exceeds eight minutes, the water valves are turned
off and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Posted on Feb 12, 2008
I have a brand new Viking french door oven...Went to set it at 450 on bake setting and got an F02 error code. How do I fix this?
Fault F02 is indicating an overheat fault- service manual says to replace main electronic control board.
Sometimes switching off at wall will clear the fault.
However, switching off at wall will reset the clock- you need to set the time before the oven will work-press middle button until small triangle is next to clock icon, set time using temperature dial. Once clock has ben set, try using oven to see if F02 fault reappears. Good luck!!
Oct 05, 2017 | Viking Ovens
My Cda washing machine is showing f02 fault code
CDA WASHING MACHINE CI931IN SHOWS FAULT F02 ..not sure if this is your model..when you go to this page just scroll down the page and you will see what you need to read.do not fill any thing in.
Nov 20, 2016 | CDA Washing Machines
Flashing F02 in the middle of cycle
Seems to be fault in the KEYPADS, check the connectors, check the harness , Remove the connections from the control panel and reset the connectors.
If the fault stays then it be due to problems on the board. check the door switch.
Jan 24, 2013 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
F- code 02
How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
Dec 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
How can fix f 02
whirlpool duet f02 codeHow to fix fo2 fault code on a whirlpool duet front load washing machine, The whirlpool duet is one of the machines that have a main computer control that operate and monitor the functions of the machine,
This control is usually mounted behind the front panel,sometimes at the back or to the side, it also has a speed control board that is mounted on the bottom usually at the right side.
Whenever a problem accur there is a fault code displayed on the machine, there is a technician sheet with the fault codes on the machine, the technician can use this guide to go directly to the problem,
This f02 code mean there is a problem with the drain, there is a drain filter that sometimes get clogged with lint and other things,
Removing the kick plate and removing the drain access on the pump will reveal the drain filter, use a small bucket, and towels to catch the water that will be in the pump
Nov 26, 2012 | Whirlpool duet Washing Machines
I have a kenmore elite oasis 110.27042602 with fault code f2. Should I try replacing the control board? I already cleaned the contacts on it. Thanks!
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 25, 2011 | Kenmore Washing Machines
My oven is saying "stop" . Previously to this is was showing F02 and the fan wouldn't turn off. We turned the main switch for oven off and back on and it now says "stop"
Previous fault F02 is indicating an overheat fault- service manual says to replace main electronic control board. However, switching off at wall has reset the clock- you need to set the time before the oven will work-press middle button until small triangle is next to clock icon, set time using temperature dial. Once clock has ben set, try using oven to see if F02 fault reappears- sometimes switching off at wall will clear fault. Good luck!!
Mar 16, 2010 | Whirlpool AKZ159IX Oven
F02 keeps showing on display
If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
Cause: wrong detergent, too much of the right detergent, detergent placed in wrong compartment.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 18, 2010 | Whirlpool GHW9400 Duet Washer
Control panel flashing F02
the water in your drain pump is still forzen...its taking to long to drain...ckeck drain hoses too...onthejob
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F02 Error on Front Load Kenmore HE3
F 02 Is your key pad user interface that has failed. I would call back and get some free service from a different technician.
Oct 23, 2008 | Kenmore Elite 45986 Front Load Washer
KitchenAid KHWS02R Front Load Washer Logo
246 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Eric Taylor
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
