Question about Palm Tungsten E2 Handheld
Installation I have tried to install mh tungstem E2 PDA but it keeps saying that The wizard was interupted before palmOne could be completely installed.
  • shumanal Feb 15, 2008
    Did have a Palm Tx (2 of them) but both died (again). Received Palm Tungsten E2 in exchange. When trying to install software from E2 installation CD, get following error message on PC = "Error 1316.A network error occurred while attempting to read from file C:\windows\installer\palm.msi."
    I've tried to uninstall the Palm program presently on my C: drive & wind up getting the same error message.
    Not getting anywhere in trying to get up & running again.
    Problem Solver:
  • 36 Answers
Got to the control panel, add/remove programs. Remove PalmOne if it appears there and try again.
You might want to download the latest version of the desktop from the PalmOne site.
Posted on Mar 12, 2008
How to change from com 1
Palm (PDA) - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/Palm_(PDA)
WikipediaThe Palm Treo 700p is one of many smartphones produced that combines Palm ... Although HP kept the Palm brand initially, all new PDA devices announced at press ....In order to try to change this trend Palm had been working on a new ...
How to Replace the Battery in Your Palm Tungsten E2 PDA ...
? 4:34
https://www.youtube.com/watch?v=caJVwecskho
Sep 2, 2007 - Uploaded by Aaron Kelly
How to Replace the Battery in Your Palm Tungsten E2 PDA. Aaron Kelly ... for battery replacement. Includes one year money back guarantee!
[PDF]Handbook for the Palm Tungsten E Handheld - Textfiles.com
pdf.textfiles.com/.../PDA/PalmOne%20Tungsten%20E%20Handheld.pdf
Chapter 1: Setting Up Your Palm™ Tungsten™ E Handheld . . . . . . . . . . . . 1. System requirements . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Jan 03, 2016 | Palm Computers & Internet
My first problem arose yesterday when, while syncing my E2 with my Desktop MAC OSX 10.4.11, the sync operation failed and the hand held Tungsten E2 could not be opened turned of and none of the prorams on...
Hi
you may perform soft reset, if issue persist perform full reset. please do not forget to backup your important data. let me know when you need further assistance so I will post the solution depend on the result.
Mar 14, 2008 | Computers & Internet
The syncronizing software for OZ-290HII will not work with my computer,though it installs,it keeps saying (file export failed) and this unit has a USB cable. I followed all the instructions but that...
Hello Sr,
Kindly read this, it may help you.
When the software that lets your computer communicate with your PDA acts up, always check the cables and connections first. Is the USB (Universal Serial Bus) or serial cable connected securely to the PDA (or cradle) and the PC? Is the PDA seated properly in its cradle if it uses one? If everything is in place, visit the palmOne (www.palmone.com/us/support/downloads) or Windows Mobile (www.microsoft.com/windowsmobile) Web site and download the latest version of the HotSync or ActiveSync software that is compatible with your PDA and your computer's OS. Keeping synchronization software up-to-date is important because newer versions fix compatibility problems and usually add new features.
If you have a Palm OS PDA that uses a USB connection, sometimes incompatibilities exist between Windows and the software that you can resolve only by running a special USB utility found at the PalmOne download site mentioned previously. Select your hardware from the drop-down list and click the USB Registry Utility link. Download the USBRegClean.exe file, navigate to the downloaded file, and double-click the icon to install it. Reboot your computer and reinstall the Palm Desktop and HotSync Manager.
...contd
Mar 09, 2008 | Computers & Internet
It says the wizard was interupted before java (TM)could finish installing
it means ure installation source is damaged. try installing from a new setup wizard. u can get a new one from sun website.
Oct 18, 2009 | Computers & Internet
Tungsten E: difficulty starting and turning off
PalmOne had a manufacturing issue in the Tungsten E and E2 PDA versions.
Bottom line is the On/Off switch is not properly soldered (enough soldering amount) so is easy that breaks the soldering joint of the switch to the main board.
The repair requires to open the PDA, remove very carefully the mainboard, and put straight (vertical) and re-solder the switch again.
It is needed a minimum of tools for it (soldering iron, torx screwdriver, wire soldering, plastic pry tool), and some skills and experience in fixing electronics.
Also, you can get with a radio or TV repair techniocian, and ask specifically to resolder such On/Off switch.
Best regards,
Jun 08, 2009 | Palm Tungsten E2 Handheld
Tungsten e2 palmone driver help
You need to download palm desktop and hotsync manager from the palm website. Totally free. Found at.
http://www.palm.com/us/support/palmdesktop.html
Aug 01, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Appropriate software for tungsten e2 palmOne
If you said you have the software (desktop), your doing it backwards. Run the desktop software by going to my pc and running the disc. The software will then ask you to plug in your E2 so it can register it. It will then synch and your in business. Had E2 for a very long time. Can tell you things that guy can do that would surprize you. Have everything but unit now.
Mar 15, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Tungsten E2 PDA battery
E2 has a great battery might not be it. Its not easyly replaceable like in some other models.
the battery can be replaced by a professional or by yourself.
The pda should work on charger? does it work while pluged in?
If it doesnt work while its pluged in theres something more seriour wrong with it.
You can try soft and hard reseting.
Instructions can be found in this pdf file http://www.palm.com/us/support/handbooks/tungstene2/en/maintain.pdf
If you cant open pdf files you need to find yourself pdf reader, google pdf reader and get one.
If soft or hardreset have any effect and the device still doesnt work even on charger then it has a hardware issue and I recommend contacting palm or the place where you bought the pda and findout about repairs and possible price, may be high.
good luck and if theres anything else let me know.
Feb 19, 2008 | Palm Tungsten E2 Handheld
Error 1316 - installation failure
Have you uninstalled the previous version of Palm Desktop?
Do you have more than 1 profile on your computer? Sometimes multiple profiles can make things difficult is software is installed logged in as one and then you try to install/uninstall as another profile.
Are you installing Palm desktop from a disk?
Try this file from palms site -
http://www.palm.com/us/support/downloads/windesk414e.html
Also, take a look at this-
http://www.palm.com/cgi-bin/cso_kbURL.cgi?ID=17525
Dec 06, 2007 | Palm Tungsten E2 Handheld
Palm Tungsten E2 Handheld Logo
67 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
