Question about Rival CF153-WM Deep Fryer
How do I remove lid for cleaning
Booklet says remove lid before cleaning, but doesn't say how to remove it. Please help!
    Problem Solver:
  • 5 Answers
Http://www.rivalproducts.com/help.aspx?helpNav=1
How do I remove the lid to my fryer?
  • If your fryer has a hinged lid, to remove lid, depress the OPEN LID button and lift the lid to a vertical position. Remove by pulling the lid upwards. Reverse the sequence to secure the lid back into position.
Posted on Apr 27, 2008
With lid in open position just pull it straight up and off.
Posted on Mar 02, 2008
Lid lock is blinking and won't cycle Whirlpool Washing machine Model WTW4850XQ1
blinking lid lock light tells you their is a code being stored in the computer, something is wrong. the booklet that tells you how to access the codes is located on the front of the machine, to get to it tilt the washer back (get help to hold machine) look up to the right side toward the top of the front, plastic bag, remove the booklet and follow the diagnostic test. you may not get it into diagnostic first time if you have not done this before but keep trying you will make it , it will give you a code to your problem please put the booklet somewhere in case the serviceman needs it if he has to come out
Jul 02, 2017 | Whirlpool Washing Machines
Need to remove lid
If you have the kind of lid that has the slots on the back this video will help
Dec 10, 2013 | Zojirushi Kitchen Appliances - Others
How do you remove the lid for cleaning as it is advertised?
If you look closely you will see that one hinge has a slit in it and the other doesn\'t . Open the lid and gently edge it forward until the hinge comes free through the slot and do the same in reverse after you clean it.
Oct 31, 2012 | Oster Kitchen Appliances - Others
I bought a new bosch dishwasher less than one year ago, and it doesn't clean my dishes because the lid on the soap dispenser will not open during the cleaning cycle. Please help SAP! Thank...
Try cleaning the latch that holds the door. After a year the detergent will build up on the spring causing it not to open. If that doesn't do it call the people who you bought it off of. It should have a extended warranty for a year.
May 14, 2011 | Dishwashers
I have a whirlpool washing machine and the red light for clean pump is on and i have no idea where or what to do have looked for my booklet but no joy please help. Thankyou Elle
HELLO THERE ELLI:
PLEASE READ CAREFULLY ,
when it's in pump-out (spin), the washer DOES make sounds, there is probably something clogging the hose going to the pump. Pair of panties, children's sock, anything relatively small. This will be BEFORE the pump. You'll have to remove the cabinet from the front (easy job), remove the hose going TO the pump, and check it out.
If, when it's in pump-out (spin), the washer just has a faint hum, the pump is probably locked down (pair of panties, children's sock, anything relatively small). Replace the pump.
If, when it's in pump-out (spin), the washer is quiet, the lid switch is broken. Very common problem. Replace the lid switch.
Don't automatically think 'clog'. These washers, while relatively loud machines, are very common-sense workhorses. Clogging is rare.
Jul 07, 2010 | Washing Machines
I have a Cook's Essentials Pressure Cooker. Haven't used it for a while and unfortunately I put the instruction booklet into the pot. Tell me how to open it please - I forgot how to open the top. Thank you
hi,
opening your pressure cooker's lid is an easy one.
  1. There is a safety lock in your pressure cooker.
  2. You have to slide them to unlock position to open your top.
  3. Grasp the upper handles and pull out simultaneously to unlock the self locking grips from the rim of cooking pot.
  4. I have provided pictures for your assistance in opening the lid. Please make use of it. Please rate my solution as helpful. Thank you..
Apr 10, 2010 | Kitchen Appliances - Others
How do i clean my cuisinart grind and brew coffee maker? i can't find my instruction booklet and it needs to be cleaned. thanks!
From the manual I found online here.
CLEANING AND MAINTENANCE COMPLETELY CLEAN AND DRY ALL PARTS AFTER EVERY USE. Always turn coffeemaker OFF and remove the plug from the electrical outlet before cleaning. Open the reservoir lid*. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use. Do not put any water in the unit once the grinder basket has been removed. Wipe the area under the grinder basket with a damp cloth. If water gets into the grinder motor, the motor may become damaged and may malfunction.
DECALCIFICATION Decalcification refers to removing the calcium deposits which form over time on the metal parts of the coffeemaker. For best performance from your coffeemaker, decalcify the base unit from time to time. The frequency depends upon the hardness of your tap water and how often you use the coffeemaker. To clean, fill the water reservoir to capacity with a mixture of 1/3 white vinegar and 2/3 water. Turn the coffeemaker on by pressing the ON button. One cycle should be sufficient to adequately clean the coffeemaker. When the cycle is completed and the five beeps sound, turn coffeemaker off. Repeat operation, this time using fresh cold water.
Sep 09, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Lost my instruction booklet
website is www.rivalproducet.com . . . but did not find a manual . . . ours come with every other page blank . . . not much help . . .
Jan 16, 2008 | Rival CF153-WM Deep Fryer
Rival CF153-WM Deep Fryer Logo
454 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ric Shull
Ric Shull
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
