Question about Clarion RAB250D
How to Remove RAB 250 D
Hey guys
I bought a new stereo and my old Clarion RAB250D is firmly stuck inside my Toyota Corolla 97.
How can i remove it? i searched for the manuals but nothing is out there
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
You need the removal keys to remove it from the cradle. They look like flat Allen keys. Remove face plate and put these keys down either side of the cradle.
You can find these at any stereo store.
Posted on Feb 12, 2008
Clarion car stereo manuals
My 2009 Toyota Corolla Axio came a clarion NX308 .. How do I change the language from Japanese to English ?
Aug 16, 2014 | Clarion MAX685BT Car DVD Player
Removing back glass from 97 corolla dx
Get a glass company to do it. They have all the tools, adhesives and the glass.
Aug 13, 2014 | 1997 Toyota Corolla
I am replaceing the starter on a 1998 toyota corolla 1.8 ltr. How do I get to the top bolt on the starter to remove it ?
To replace the starter of a 1998 toyota corolla, please follow the steps below:
  1. Remove the key from the ignition, and remove the battery, do not attempt this with the battery in car.
  2. Remove the battery and tray.
  3. Look to the rear of the engine, You'll see the top of the starter, loosen and remove the 14mm bolt/nut holding it down below,
  4. Drain the radiator and remove the lower radiator hose. This will let You squeeze the starter around the AC line,
  5. Then install the new starter, the one bolt You removed from the bottom, screw the last 14mm bolt on the starter into the transmission loosely,
  6. Go up top, reinstall the top bolt, tighten this firmly but not all the way,
  7. Go below, tighten the bottom bolt to final spec.
  8. Reattach all the wires, make sure the trigger wire is snapped in fully.
  9. Go up top, firmly firmly tighten to spec the top bolt,
  10. Reinstall everything You removed up top the below,
  11. Reinstall the battery and make sure the ignition is off while doing this,
  12. Hook up battery and ensure every thing that was loosened has been installed back on.
  13. Then You crank it to see if it will start.
Hope this helped. Thank You for using FixYa!!!
Jan 26, 2011 | 1998 Toyota Corolla
Hello! Just bought a 2003 Citroen C3 with a Clarion stereo wich has a cd stuck inside. How do i get it out? Already tried eject and it does a strange noise but, the cd is still stuck inside. Help!
it sounds like the intake/ eject rubbers are not working this is almost always due to a broken drive belt take the top of the stereo and have a look for the intake wheel see if the belt is broken and then replace
Dec 28, 2010 | Clarion DXZ545MP CD Player
How do i take out my radio from my toyota corrola
The Toyota Corolla has been around long enough that many owners find themselves needing to replace the factory stereo. Installing a new stereo in the Toyota Corolla gives improved sound and updated features. Swapping out the stereo in the Toyota Corolla takes basic tools and less than an hour. This article covers models from 1990 to 2000.
Open the hood and remove the negative battery cable from the terminal. Apply the parking brake and place the car in "D."
    > Remove the trim from around the stereo by prying with your fingers at one corner. Some early models have two screws at the top of the trim piece to remove first. Allow the trim to hang on the drivers side of the dash if it's connected to the cigarette lighter.
    > Locate and remove the four screws holding the stereo in place. Pull the radio out of the dash and disconnect the wires from the back of the head unit.
    To install
    > Connect the wiring harness adaptor to the original harness and let it hang from the dash. Slide the new stereo into the Toyota radio mounting kit, which is a thin metal cover and secure it per the manufacturer's instructions. Most adaptors have screws to hold the stereo in place, however some have clips, which engage automatically.
    >Plug the wiring harness adaptor and antenna wire into the back of the new head unit and push the entire assembly into the dash. Reconnect the negative battery cable and turn the radio on.
    > Ensure all of the stereo controls and speakers are working. Secure the radio in the dash with the original four screws and replace the trim.
Dec 05, 2010 | 1990 Toyota Corolla
1995 toyota corolla passenger side window will not close stuck open
Replace window regulator and motor. Procedure: Remove inside door panel, cut regulator wires, raise window manually and hold in place, undo bolts holding window glass to regulator, undo bolts holding regulator to door-frame, remove regulator. Reverse to install.
Feb 11, 2010 | 1995 Toyota Corolla
I just need to know how to remove the dash so that I can take the old radio out and put the new one in
Should be very similiar to this:
http://www.neocarz.com/blog/2007/07/2006-toyota-corolla-radio.html
Dec 18, 2009 | 2005 Toyota Corolla
Clarion RAB250D w\casset need to set clock and stations.
While pressing the BAND button, press the DISP button for 2 seconds or MORE to enter the clock editing mode.
To move between the hour and nimute fields, use the left (hour) and right (minute) buttons.
To store the clock setting, press the BAND button.
Also to change between manual tuning and seek tuning press and hold the BAND button for 2 seconds of more. "SRCH" will appear in lower side of display when in search mode.
To preset a station manually press the BAND button to select the band at which to store the station (AM, FM1, FM2, FM3).
Tune to the desired station to be preset
Press and hold the corresponding preset button (1-6) for at least 2 seconds to store the station into memory.
Apr 26, 2009 | Clarion RAB250D
Radio cassette removal from 1996 toyota corolla
HI
I took my car to halfords to have my stereo fitted (also bought stereo from Halfords). they basically had to taken everything out of the middle bit to get to the stereo (All the air vents and control switches etc). It took about an hour to do, but at least you know there is no quick way to steal the radio once it is in. I think it helped that I managed to get a guy that had once been a macanic so he knew what he was doing.
Hope this helps
Aug 28, 2008 | 1996 Toyota Corolla
Clarion RAB250D Logo
251 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
