Question about Zenith XBV442 DVD Player/VCR
XBV442 DVD door won't open
When I press Eject on the remote or directly on the dvd player, the display says "Open" but nothing happens. The dvd that is in there is being read perfectly, we just can't get it out now.
I tried unplugging it for a few minutes but nothing. I also opened up the door and gently pressed on the tray but that didn't work either.
  • Anonymous May 24, 2008
    my dvd door will not open and i have had a dvd in there for Lord knows when
  • ten4 Sep 08, 2008
    I have the same problem. Isn't there a manual override somewhere?
    I tried gently prying it open with a screw driver, but no luck.
I have opened many a player and given the tray a slight assist. Voila it unsticks
Posted on Mar 25, 2008
DVD door will not open to eject DVD
There could be 2 reasons, 1. Hardware issue 2. Software drivers:
Fixing 1: Hardware
Make sure the DVD is fixed properly in your tower ( I am not sure whether you are using a tower or lappi)
The direct solution is to put a pin i the small hole present on your DVD player. That should open the DVD door.
To fix the software part.
>> Try to update the drivers depending on the operating system you are using.
>> Download the latest drivers to check if it fix the issue.
>> Open the My computer >> Right click on the CD/DVD drive and select Eject, this will normally open the door.
Else, try to uninstall the drivers from Device Manager and then restart the PC once, this will reinstall the drivers once again by its own if your Windows is up to date.
Please do get back to us, if that does'nt fix.
Jan 18, 2014 | Zenith XBV243 DVD Player/VCR
Unlocking my DVD player
some others
new model pacific 1002mk2 (ASDA) using remote.;
press open on remote
press clear
press 1-3-6-9 Then 0(for multiregion)
Press close
It's important to note that you will not see anything happen on screen or display!
The buttons are small,so you'll have to be precise
1. PUT A REGION 2 DISC IN PLAYER
2. WHEN IT IS LOADING UP PRESS "SETUP"
3. PRESS "7" FOR MULTI REGION
4. PRESS "PAUSE/STEP"
5. PRESS PREVIOUS " |> "
6. PRESS SETUP
YOUR PLAYER IS NOW MULTI REGIONAL.. IS YOU WANT TO SET THE REGION IN STEP 3 PRESS 1 FOR USA OR WHATEVER YOU REQUIRE....
or
switch on.on the remote press "open/close",0,1,2,3,open/close and it plays straigt away. but nothing is shown on the screen.
or
It's true - a quality DVD player from Asda for £59.95. Highly recommended. This 1359 hack worked with my Pacific 1002 purchased March 03.
Note. There is no on screen display or any indication on the machine when entering the hack.
Switch machine on and using the remote control only:
1. Press 'open/close' button (the draw should be left open).
2. Press the 'clear' button.
3. Press '1'.
4. Press '3'.
5. Press '6'.
6 Press '9'.
7. Press '0' (zero for multi-region).
8. Press 'open/close' button.
End.
or
1. switch on dvd with remote (leave drawer closed)
2. Press: setup
3. press: 7 (note nothing will happen)
4. press: pause/setup button (again nothing will happen)
5. press: previous/I<< button (nothing will happen)
6. press: Next/>>I button (nothing will happen)
7. press: setup
Dec 05, 2007 | Televison & Video
Zenith xbv442 how to get put of safe mode
Click here to download the user manual to your player. It will talk to you.
Jun 08, 2012 | Zenith XBV442 DVD Player/VCR
How to Unlock a Sony DVD player DVP SR320 which displays "LOCKED" when eject/open button is pressed?
Apr 22, 2012 | Televison & Video
While playing the VHS the player switches from VCR to DVD in the middle of the movie multiple times. We ended up having to tape the DVD player closed because it would turn the player on in the middle of...
Hi, it sounds like either the eject button on the DVD player drawer has been damaged or the remote is in need of cleaning (I assume the remote to have an eject button too). you can remove the remote by removing a battery and seeing if the problem stops.
Best you remove the tape from the DVD drawer as this will not stop the DVD mechanism from trying to open the tray, bit like trying to constantly push against a locked door - you will cause damage if it hasn't already.
Aug 13, 2010 | Zenith XBV442 DVD Player/VCR
Unable to open the door of the dvd --when you press the eject button to open the slot---the door does not open---everything else works
Quick trick
First let's find out if the motor is dead or
the magnetic clamp is to strong for the motor.
Press eject then listen closely for the sounds of struggling motor
if you hear it trying SLAP the top right over the DVD drive
and that should break the magnetic seal and release the tray
you may have to try a few times Press eject and open hand slap kinda
hard the top of the DVD drive , don't worry you won't hurt it.
if that works email me and ill tell you how to fix this.
Rob
rsheehan@northernsteeldesigns.com
Oct 14, 2009 | GoVideo Go Video DVD/VCR Combo
Sony SLV-D930 GI - The DVD Drawer will not open when I press eject. The display says ''OPEN'' but nothing happens
Please unplug Sony dvd-vhs combo from AC wall socket for couple of minutes, replug back in and turn it ON, now press eject button to eject disc tray.
Let me know if problem still exist.
Thanks.
Aug 29, 2009 | Sony Televison & Video
The door to the dvd player is stuck partway open on my zenith vcr / dvd combo player
the gears on the drawer skipped a few teeth. as crazy as this sounds, give it a stern whack back in. if the plastic teeth are flexible enough to skip teeth one way, it'll be flexible enough to skip some the other way.
Jul 15, 2009 | Zenith XBV442 DVD Player/VCR
DVD Player won't open
check if your dvd door is driving by belt or gear . if its belt ,check if its slack, if gear check for worn gear. weather gear or belt check if the motor driving it responds each time you press the eject button .check if the eject switch is ok .then if all this are ok ,check the ic controlling the eject/close functions
Jul 11, 2008 | Samsung DVD-V1000 DVD Player/VCR
Dvd player won't open
I had the same problem for my panasonic dvd player (ht540). Neither of the above solutions worked so I found this one on the panasonic website:
1. turn off unit by holding down the POWER button for 10 seconds.
2. unplug the power cord and wait for one minute.
3. plug the cord back in and turn on the unit
4. when the dvd begins to play, press "EJECT".
It worked for me. The site for other troubleshooting is:
http://www2.panasonic.com/consumer-electronics/support/FAQs/details-FAQs+for+DVD+Recorders-UCM_PRD_CNT_001989#dvdrec6
Peter
Oct 09, 2007 | Philips HTS3410D/37 700W DVD Home Theater...
Zenith XBV442 DVD Player/VCR Logo
340 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
