Question about TruTech PLV1615T 15 in. LCD Television
No picture When we use the remote or turn on using standby button, the red lights blinks and nothing happens. What is the problem?
  • danl47 Feb 28, 2008
    I have the same tv and the same problem.  No picture, the red light just starts blinking when I push the Standby/On button.  Changed rooms, cable connections and remote batteries...no luck.
  • HAIR84 Jun 10, 2008
    pushing the stand-by button the tv is not coming on the light just blinks.unplugged and changed plugs no luck. still won't come on
    Champion:
  • 367 Answers
Open the back of the TV,and look at the can shaped items on the board that the power cord is hooked to.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.So far I have fixed four of the same make,and model TV as this,and they all had either one,or two bad capacitors.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Posted on May 21, 2008
Samsung HDTV black screen no picture no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 12, 2017 | Televison & Video
Samsung HDTV no picture no sound
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 13, 2014 | Samsung UN22D5000NFXZA 22 In Led Hdtv...
TV won't turn on. Red standby light blinks
Samsung told me this was a common problem and I would have to have it serviced by an authorized repair facility.
My problem ended up being the internal power supply, but they also told me the main boards burn up.
Nov 06, 2013 | Samsung BN94-05038F Main Board for...
Why is the power button blinking on then off, i can't turn my tv on
The set is in shutdown because of some internal problem. Can be almost anywhere in the set---
Mar 13, 2012 | Televison & Video
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Blinking red light standby/timer
It seems to respond to power supply, send it to a nearby technician. The problem might be it fused the picture power supply fuse. make sure the installation is at you presence.
Sep 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Emerson AV101 System
I'm in the same boat... happened once before, then came back to life. Now it's back to a red standby light and no ejecting tray
Mar 04, 2007 | Emerson AV101 System
TruTech PLV1615T 15 in. LCD Television Logo
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
