Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Taking pictures i've had my camera for about 4 months now and this is the second time this has happened. my camera turns on fine but i can't take pictures or videos. i can look at one picture from a whole bunch that was saved in teh memory card but thats it. the first time this happened my friend told me to shake it and i don't know how that helped but after a few minutes my camera worked perfectly fine again. can someone help?
  • 489 Answers
Hi
You said it started working again, so I don't see what 't00nz' is getting at with his answer.
It sounds to me like your flash was not working... but that would only stop it from taking pictures and not video as the flash is not used for video.
So... I would have to then guess it's a loose connection somewhere or your shutter button is defective. If you or somebody else opens the camera you can check for loose connections and see if there is anything physically wrong with the shutter button itself and the button under what you are pushing with your finger.
The outer button assembly that you are pushing on is easy to replace, the inner button is NOT easy to replace.
And yes, if it's acting up and its only a few months old, send it in for repair under warranty for sure!
Good luck
Darntoothysam com
Posted on Sep 22, 2008
  • Canon Master
  • 4,738 Answers
First look on the back and with the camera on press the DISP or DISPLAY button. If you still have a problem after doing this, then it needs to be repaired. You mention the camera is only 4 months old, and is thus still under warranty. Call 1-800-828-4040 or 1-800-OK-CANON (1-800-652-2666) to have it repaired for free under its warranty. And here's its warranty:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=224&modelid=14919
Posted on Feb 18, 2008
I've had the camera for about 6 months now. It's been fine until recently. Now it is intemittent whether it wants to take a picture or not. You push the shutter button sometimes and nothing...
It's faulty and new enough to be under the manufacturer's warranty. There is no simple fix for intermittent faults like yours. so just send it back for repair/replacement.
Jun 17, 2011 | Canon PowerShot SD1400 IS IXUS 130...
When using the flash is takes 4/5 seconds before I can take another picture. The taken photo appears for about 1 second then the screen goes black for 4/5 seconds before I can take another picture
Friend,
You are using a 10 MP camera. Imagine the size of the picture taken. It is massive. And so would the size in megabytes. To save those many MBs is a time consuming affair. that is what takes 4 to 5 seconds. And during that time the camera can do nothing else.
Do not worry. The camera is fine. Just that you have a very good camera and do not realize it.
As regards the photo being visible for a second only, you can change the settings and have the picture on display for a longer duration. That would be fine as while you are viewing the pic, the camera is busy saving the pic file. You would not feel those 4 to 5 seconds at all.
Dec 28, 2010 | Canon Powershot A2000 IS Digital Camera
I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This...
I have a Fuji FinePix A330 camera and when I try Problem with the Fuji FinePix A330 Digital Camera I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This just started happening recently. But when I take a picture in the dark with the flash the photo turns out fine. Any answer as to what caused this? Thanks
Dec 28, 2010 | Fuji FinePix A330 Digital Camera
Doesnt turn on
It could be something more serious, but the problem you describe is frequently due to corroded battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, clean the contacts at both ends of the batteries, and reinsert them in the camera. This cleaning cures the problem about 90% of the time, and I hope it works for you.
Aug 26, 2009 | Kodak EasyShare M1033 - black Digital...
I have a Kodak M1033 camera that I bought just over 6 months ago. I took it on holiday it worked fine and then suddenly it switched off. Since then it only powers up for about 5 seconds, shows a unfoc
I'm not sure why this works for me, but I think it's worth a try:
1) First, take your SD card out of the camera.
2) Then turn on your camera and let it turn itself off.
3) Read the next step first and be ready to press the shutter release button (take a picture) right after the LCD screen turns on
4) With the camera lens pointed down towards the floor (aim down), turn on the camera. At this point the LCD screen should not be blurry anymore. Immediately press the shutter release after confirming that the LCD is not blurry. If the camera stays on and you can review the picture (most likely of your feet), then you are almost done.
5) Turn off the camera and re-insert your SD card.
5) This may not be a permanent fix, but point the camera lens downward whenever you turn on the camera. It should work normally if you do this. Mine worked normally (meaning I don't have to point it downward when I turn it on) after doing this several times. Your results may vary.
Jun 02, 2009 | Kodak EasyShare M1033 - black Digital...
My d40 won`t take pictures
Try Blow cleaning the Memory card slot ... sometimes dust does that
Oct 05, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
C533
goto http://www.digitalcamrepair.com/self_diagnosis_page.htm
for self diagnosis.please let me help you before leaving a bad feed back.
Apr 04, 2008 | Kodak EasyShare C533 Digital Camera
My second camera, Same Problem
Have you tried cleaning the battery terminals in the camera with some very fine emery paper or sand paper? Especially if you live in a humid environment.
Jan 30, 2007 | Canon PowerShot A520 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
