Question about Ovens
Oven wont heat up properly
My oven is 7 years old but just recently will not get up to the required temperature. I have to put it on full temp just to heat it up enough to cook something.
  • spunkyloo Jun 07, 2008
    We have a 3 yearold frigidaire PLEB30S9DCA single wall oven.
    on [Bake] it does not heat up at all
    on [Broil] the broil element does not heat up at all
    on [Conv Convert] or [Convection/roast] the fan comes on and it heats up to a very low temp, ( would say not more than 150 degrees)
    neither self cleaner works.
    No error codes show up, timer works, clock works
    Help please?
    thank you
  • socialwork10 Aug 20, 2008
    Oven will not heat up at all. We have had it for about five years and has been an outstanding oven, but just this week i turned the oven on and it would not heat up past 150 and now it will not heat up at all and it gave me F7 error code.
  • 552 Answers
This may be the thermostat control.
I would find someone to check the resistance of the element with an ohm meter.
It should read 15 to 20 ohms.
Put the timer on manual first and try the oven, because it could be the timer.
It would be ok to just replace the bottom oven element because most of the time it is a faulty element.
Posted on Feb 12, 2008
I have chef EGC651S oven with separate grill. On fan assist oven only heats up to a certaain temp and doesnt get any hotter what could be the reason for this
Probably thermostat problem, although some chance you have one side of a 220vac breaker not working. In otherwords oven heating element is "getting" half of the required power. Call electrician!
Mar 08, 2015 | Ovens
GE oven JKP26GOP2BG wont heat
either the temp sensor probe in the oven cavity it open/shorted or way off scale and telling the control board the units up to the temp set point,theres a way to test these with an ohm-meter for resistance at certain temperature but i dont have the chart for that test,it may be inside the unit if you can locate it
Dec 02, 2012 | Ovens
My gas oven heats very slowly and sporadically. It often smells like burning plastic when heating. The oven is about 9 years old and did not have this problem until recently. What could be wrong? Might...
Good morning, your oven most likely has a weak igniter. That would keep the gas safety valve from opening properly. It will get close to the required amperage but valve will only flutter and not allow enough gas to ignite. Hope that helps.
Jan 29, 2018 | Maytag CWG3100A Gas Single Oven
How do you fix the temperature for the whirlpool oven
Buy a oven thermometer to put inside the oven to check the accuracy of your oven temp setting. If the oven temp is not too far off from what your oven thermometer is reading, you can recalibrate the oven knob. Pull the knob off and look at the back. You can adjust the degrees approx +or - 20 degrees. If the temp is all over the place or just not heating up enough, then it's time to replace the oven thermostat, assuming the oven isn't too old or not worth fixing.
Oct 05, 2010 | Ovens
Amana Electric Oven Issue
My oven never reaches the proper temperature sitting for baking. Controls for the oven only is push buttons. How can I adjust this. This has been going on since I have bought the Amana
Oct 27, 2008 | Amana AOCS3040 Electric Single Oven
Oven not heating up properly
You could very well have an electrical problem. You may not be getting the full 220 volts needed to make the oven function correctly. Call a local appliance technician or electrician for service.
Dec 28, 2006 | GE Profile JTP56 Electric Double Oven
Ovens Logo
399 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
