Question about Kenwood DPX302 CD Player
Aftermarket cd player
I just swapped my factory cd player out for a aftermarket one . Everything seems to work fine but there is some kind of humming sound that gets worse as you press the gas . My car is a 1992 lexus sc400. Any help is appreciated . thanks addam.f
  • addamj Feb 13, 2008
    I am using the acc and the b+ . and no i am not using the harness it was gone already
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
Where are you getting yoru power supply from? Did you use the old existing harness?
Posted on Feb 12, 2008
2004 GMC Sierra 2500HD with factory Bose stereo system but no on-star, put an aftermarket clarion CD/DVD player in it over 2 years ago i put in the adapter for making the Bose factory system work and
either your connectors need cleaning or maybe a break in the wiring. Is there on spot where both wires come together if so check there.If there is any plugs, pull them apart and clean them with contact cleaner
Dec 15, 2014 | 2004 GMC Sierra 2500HD
Installed aftermarket stereo and now car want start but everything else works
Switch the wiring harness for the cd player back. t probably disabeled the ignition systime in the car.
May 01, 2014 | Brembo 2007 Dodge Charger - SXT, RWD -...
YUKON CD PLAYER NO SOUND!
Is your IP Bus cable on the INPUT and not the OUTPUT ? I know it sounds funny, but usually(95%), that's the case. If it's in the wrong plug, you'll have power and a display, but no audio. That's why your getting data but no audio.
Sep 08, 2009 | 2003 GMC Yukon XL
Stereo problem
What kind of stereo, probably a wiring problem.
Aug 12, 2009 | 2002 Dodge Durango
My 2002 Chev. 1/2 ton Silverdo's CD player will not play. It takes disk and everything seems to work but no music. I hadn't used it in many months so unknown as to when it boke. Any suggestions? If you...
If you turn the disc upside down and it says no disc, your player is reading the disc just fine. If it seems like its playing (track timer is counting as song plays), then I would guess its an audio problem. Disconnected harness in the back for the speakers or if you have a seperate amplifier (aftermarket or factory), it could be disconnected or broke.
Jul 10, 2009 | 2004 Chevrolet Malibu
I have a 2003 GMC Sierra 1500 and it has a factory CD/Radio Bose system. The radio works fine but can't get the CD player to work, it won't eject or load a CD. I recently had an ignition fusible link prob...
you might have to take it to the dealership to have the radio reprogramed. it should only cost 40 bucks. these radios are very tempermental and have a mind of their own sometimes. My profesional recomendation would be to have an aftermarket cd player in. they are much nicer and have way better quality than the factory radio's
Jun 20, 2009 | 2003 GMC Sierra 1500
Factory cd player doesn't play aftermarket burned cd's
What format are you burning them in? CDA or MP3 most Factory units will only play CDA format, just pick you up a copy of Nero and choose Aduio CD, it will convert you MP3 format to CDA and you should be able to playthem with no issue, the CDA format also works in the old portable CD players as well...
Hope this Helps,
David
If my solution was helpful please rate accordingly.
Mar 17, 2009 | 2002 Jeep Wrangler
Jensen VM9311TS wont play cd
you are probably mising to power on the factory amp from the vehicle
Nov 04, 2008 | Jensen VM9020TS Car DVD Player
Cd player not working
Need more info to provide you with a solution. For example, what brand and model is the cd player, is it an aftermarket or factory unit, does the radio work, did you unhook the battery, etc?
Jul 25, 2008 | Car Audio & Video
No audio from cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go. The same goes if your have an aftermarket amp driving your speakers.
Sep 23, 2007 | Alpine CDA-9885 CD Player
Kenwood DPX302 CD Player Logo
100 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
