Horizontal output transistor
My television has two circuit boards a main board located on the floor of the set and a secondary board located on the crt tube on which board will I find the horizontal output transistor... I have another television can I simply swap them if they are the same
  • 1 more comment
  • gottaproblem
    gottaproblem Feb 12, 2008
    Think I have located the horizontal output transistor pretty much thank you, will try swapping them, both televisions are going to the tip now so if it saves one of them, then all well and good... on top of the tube is a large rubber cup that has come loose does this make a difference to anything
  • ktibug Sep 17, 2008
    my rca tv will turn off then try to turn on three times. i have the back panel removed and there is a burning smell.
  • Anonymous Mar 29, 2014
    Output transistor for Diamond 54cm colour TV
  • 44 Answers
You can Swap them if they are of the same rating, must check the wattage. cause the width problem & the power transistor become over heat. you can also use both of them in parallel, if they are ok. your tv live longer.....
HAVE A NICE DAY...
Posted on Feb 12, 2008
  • 2,130 Answers
Most likely the transistor will be on the main board. It will also be mounted to a heatsink. The board you see mounted to the rear of the CRT is not associated with the horizontal and high voltage. Follow the high voltage wire attatched to the side of the CRT back to the flyback transformer. You should find the transistor near the transformer.
As for swapping them out: you can swap them out if both TV's are the same model number or if the transistors have the same part number. If not, I would not do it. You have to make sure that the specifications of the parts are identical otherwise you can damage the replacement part and possibly the TV.
Let me know if I can be of further assistance to you.
- Jim
  • SHARCNET-USA
    SHARCNET-USA Feb 12, 2008
    The rubber cup supplies the high voltage to the CRT. The cup will move around a little but it should not be loose. Make sure you let the TV set bleed off the high voltage before you touch this connection. The correct way to discharge this lead is to attach a lead to the chassis ground and the other end to a screwdriver and insert the screwdriver under the rubber cup and touch the metal lead under the rubber cup. Make sure your hand is insulated when doing this. You can remove the rubber cup by grabbing the rubber boot and squeezing it. This compresses the clip under the boot and allows you to remove the lead from the CRT. make sure you do this with the set unlugged and with the CRT anode fully discharged.
    Make sure that both horizontal output transistors are the same part number.
    Good luck, please let me know what happened.
    - Jim
UndefinedI've checked a Panasonic crt color tv model TC-21fj20p, and I find a hard way to discover the cause of the problem until now.. The set has a good primary voltage supply. No problem with the IC...
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Any short circuit at the horizontal output section circuit will shut down all the secondary SMPS voltages, as there is short circuit protection circuit to all Sony TVs.
Oct 28, 2014 | Televison & Video
Why set come on and go off
Short circuit detection at the main board. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 03, 2014 | Televison & Video
No power sharp 21v-w70m
Short circuited component at its main board. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Give a special attention to its horizontal output transistor. Replace it, and check. Check this device for collector to base, or collector to emitter leak. Even a slightest leak, will cause sivere problem.
Apr 16, 2014 | Televison & Video
The tv will not come on it just clicks
It is a symptom of short circuit. There should be any shorted component/s, at its main board; not related to its power regulator section. Check the horizontal output section circuit to locate the fault. Check the horizontal output transistor for damage. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 11, 2013 | Televison & Video
Power light flashes, tv will not come on
If the power light flashes, it is an indication of shorted component/s on the main board circuit. most probably it will be with its Horizontal Output section. Horizontal output transformer, Horizontal Output transistor etc: Your set need a detailed check up.
Jun 20, 2012 | RCA F36650 36" TV
Dear sir i have samsung 21 inch flat television now horizontal drive transistor fails after few hours i replaced 3 times the same transistor(tt2222) but again geting fails so pls let me know what is...
Hello
You just replace the freewheeling capacitor, normally come up to a value of 5600pf 2000V or so, connected to the collector of the horizontal output transistor, fitted very close to the collector lead. Replace the yoke return capacitor, 0.33uf or so also. Usually samsung sets use no heatsink for the horizontal output transistor. You just put a small heatsink to it and check. If it doesn't overheat, you can remove it later.
You can suspect the deflection yoke also for shorted winding. To check this. pull out the CRT base board out of the neck of the picture tube, place it where it doesn't get short circuited, and unplug the deflection yoke connection from the main board, and switch on the set. See whether the transistor overheats now. If it doesn't overheat, suspect the deflection yoke for shorted turns of winding inside it. Till the transistor overheats, suspect the LOT.
NOTE: Never switch on the set while unpluging the deflection yoke connection plug from the circuit board, without dismandling the CRT base board. CRT may get damaged, with a black burned spot inside the center of the screen.
OK.
Dec 15, 2010 | Samsung CXJ1952 19 in. Combo
Sony kv32fq70 led blinking 2 times
Hello
It is due to the self fault diagnosis function built in with every latest Sony sets. According to the faults, and section, number of blinks will deffer in numbers. In your set, two blinks indicates that there is some short circuit occured due to some component faults inside the circuit board of your TV. This fault is calle [OCP], Over Current Protection.
It may be sometimes due to the fault of shorted LOT [Line Output Transformer], or its driver transistor has a short between its collector to emitter leads, or any capacitor shortage, or any kind of short, which causes heavy current flow from the regulated power supply section of your TV.
You just start with the horizontal output transistor stated above. It can be located very near to the LOT. usually screwed onto a metal plate, to radiate heat from it while it works. You just resolder it out from the board and check with multimeter, preferably an analogue one, and measure its collector to emitter resistance, both forward and in reverse mode. If it has a short you will get almost full deflection in the multimter movement. If it is so, you have to suspect the LOT said above too, because horizontal output transistor failure indicates some LOT trouble also.
If so just replace the transistor with same type and number, and switch on the tv just for a short period, say 3 or 4 seconds, and feel the temperature of the replaced transistor with your bare hand, after switch-off the set by unpluging from AC mains outlet. If it overheats, there is some overload, and it is mainly due to the above said LOT. There is an other chance too for this fault. That is deflection yokes' winding short. It is very rare, 1/1000 may occur. Normally an LOT short is found in most cases. If the transitor overheats as said earler, replace the LOT also.
Without the transitor, you just connect a filament bulb of 220v 100W or so, between the main positve rail of the DC supply voltage 130vDC. If the bulb glows constantly, you can make sure that the short is due to lot fault.
An other posibility is shorted secondary filter capacitor and retifier diode. The 130VDC is derived from the secondary side of the SMPS transformer at the power regulator section. There is a rectifier diode and an electrolytic fulter capacitor, normally come to the value of 220MFD 160V or so. If the capacitor gets shorted, it will give a heavy load as stated earlier. Check these components also. OK.
Nov 20, 2010 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
I turn the power on, but it keeps shutting off. The standby light is pulsing two times if that helps any. Thanks
Hello
Two blinks of standby light in Sony sets denotes that there is some short circuit inside the circuit board. It could be with a shorted capacitor, shorted horizontal output transistor or defective Line Output Trnasformer otherwise known as [LOT]. To determine it you have to open the TV. You must have a concept of soldering and more confidence. LOT described above can be located on the mainboard itself. One wire from it goes to the top side of the picture tube's final anode, and seem to be sticked to it with a rubber ******. That is [LOT]. Very near to that LOT you can locate the horozontal output transistor stated above, screwed onto a metal heatsink. You just resolder it out from the board, and check it for collector to emitter leak. It is best to replace it with a new one of same type and number. Insist on same type and number, since it is a critical component. After replacing it, just switch on the TV for a few seconds, say four or five, and switch it off, unplug it from wall socket and feel the heat of that trasistor with bare fingers. If it overheats, it is a sure symptom of LOT fault. You have to replace the LOT also with same type and number. Before replacing the above said components, you just resolder the transistor said above, and just switch on the set without it. If the sytandby LED lights for the same number of time, there may be any shorted capacitor in the main secondary supply rail; usually 130VDC, LOT power supply. There is a EHT boosting capacitor fitted very near to the transistor said above, at about 470Pf; ceramic or so. There is a chance that this capacitor may get shorted. Anyway, your TVs secondary power supply rail has a short. Two blinks of standby light denotes Over Current Protection [OCP]. It is a self diaganosis process going inside the the TV, and every Sony set has the same fuction. Ok
Take every precaution before you open the TV. Mind that you are going to work with an electrical equipment, which has as high as 26,000VDC points are inside it. Keep chlidren away from you while you are working. Not even allow them to come nearby you, and let an adult beside you as a precautionary measure. Ok
Nov 12, 2010 | Sony KV-27S42 27" TV
My rca tru flat is NFG
The high-pitched squeal usually indicates that the horizontal drive circuit has failed as a result of a dead line-output transistor. This symptom indicates that the control circuit of the main power supply is trying to over-compensate for a greater than usual secondary current. Certainly, an inspection of the line-output transistor will show that it's most likely dead. Sometimes instead of the squeal you will hear hiccups instead. Focus your attention on the horizontal circuit.
Jan 06, 2008 | RCA TruFlat 27F520T 27" TV
1996 Sony 32" Trinitron - Suddenly lost picture and sound
The most common problem with TV was the failure of the Horizontal Output Transistor, this will also damage 2 transistors in the power supply and a resistor in the power supply also. (From memory): Horizontal Output location # Q501, 2 power supply transistors Locations Q601, Q602, and resistor Location R607. Also solder the Horizontal drive transformer, you can find it by following the circuit board from the base of the Horizontal output. Some models used an IC instead of the 2 transistors in the powersupply, it will have six legs and check like 2 transistors. Good Luck.
Jun 04, 2007 | Sony KV-32S26 32" TV
Televison & Video Logo
957 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
