Question about HP PSC 2175 All-In-One InkJet Printer
Plug and play problems
I have windows xp. I am trying to get my printer to hook up to it but everytime I plug in the USB wire the computer won't recognize it. The computer informs me that something has been added but it doesn't know what.
All the info I have on the printer says that it should be a plug and play printer and install itself but this is not happening. Is the problem the printer or the computer.
  • Jacamei Feb 12, 2008
    Thanks a lot. The problem ended up being a bit more complex than that but you put me on the right track and now it is working!
  • 831Mommy Feb 13, 2008
    The link helped me too! Thank you so much!
    I've had troubles for the past year with this printer...worked at first. I had followed instructions to uninstall the printer from the control panel, then mak sure it's not showing up within the printer and fax, then I removed the driver within the server properties from the printe and fax window. I used this link you suggested, and it appears to be finally WORKING! THANK YOU!
    President:
  • 2,351 Answers
Hello. You need to install the CD software. Taking the term plug & play is not what it used to be. Your XP needs everything to be in it's place & have a name & drivers to function. Click the link below which will load HP's instructions for installing & uninstalling your USB printer PSC 2175 all-in-one. Scroll down to installing software:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu05205&lc=en&cc=us&dlc=en&product=90809&rule=1462&lang=en
Everything will work out ok. Still need anything? Just post back.
Posted on Feb 12, 2008
    Scholar:
  • 95 Answers
Let me ask one question. Have you loaded the print drivers for your printer. If not do so. This will fix the problem.
System Volume Information folder keeps appearing in my usb flash drives. I can see it when I plug into my game console but not on the computer. Everytime I delete it on the console it ends up back on there...
its system generated folder
this folder appear when u plug a USB drives in different OS based computers make it delete every time or use that drive in same computer every time
Oct 25, 2013 | HP Computers & Internet
Everytime i try to download music to my memory
try using a different USB port to put the Dynes reader into then insert the memory card in it once the dynes reader is detected by the machine, if still not being detected check the services window
in XP click start open the run window type services.msc in the list look foe Human Interface Device Access double click and change it to Automatic, then look for Plug and Play do the same set it to automatic, then look for Universal Plug and Play Device Host set it to automatic as well make sure that after you set each that you click apply then ok to make changes take effect, after you've done the automatic settings remove the dyne card reader restart the computer aftrer restarting then insert your mini memory card into the dyne reader then insert the dyne reader into a USB port on your computer, Hopefully this should work ^_^
Jun 04, 2010 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
Everytime i plug usb device my computer restart....
You should download a usb antivirus or buy it and scan your usb drive
Apr 28, 2010 | Microsoft Windows XP Professional
I can't use printer from computer,all it's saying on the instructions I got was, plug power in and ubs cord to printer,nothing hooked into my tower, go figure???? so how do I do it,it's a new computer,just...
Plug the USB cord from the printer to an available USB connector on your tower, insert printer disk into computer drive, then go through Printer Setup and you should be able to print.
Dec 14, 2009 | HP Ruggedized DC Car Adapter for HP...
Since i got windows xp my cannon i70 nolonger is printing
Try to re-plug the printer to another USB port on your computer, it should automtically detect the printer as a new hardware. If it didn't, try these steps:
  1. Run Add Printer Wizard of Windows (from Control Panel> Printers and Faxes).
  2. Choose Local Printer (it's okay if it didn't find Plug n' Play printer).
  3. Select USB Virtual printer port (assuming that your printer is connected through USB to your computer).
  4. When it ask to choose the manufacturer and model, just select the closest match to your printer.
If the model couldn't be found (or not even a close match to Canon i70), you will need to download driver from Canon website.
Oct 12, 2009 | Cannon i70 Printer
SimpleTech 250GB External Hard Drive can't be recognized
First of all,
uncheck the "Allow the computer to turn off this device to save power" option in the device manager for USB Hub Properties, Power Management Tab.
Try rebooting the computer once as C:\Windows\inf\INFCACHE.1 file may be corrupted and need to be replaced (either restore a previous version or just delete it and try connecting again).
Next,completely uninstall all USB devices and the main hub and then re-install.
Sep 07, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Konika Minolta 2400W can not connect. Clearly Windows XP sees it, and the driver is installed etc. When I plug or unplug the USB cable, Windows plug 'n play notices the difference. And the USB cable works...
Everytime you disconnect and reconnect the USB cable to a different port, unfortunately, Windows creates a new and distinct copy of the printer. You can see this by looking at the Windows Printers folder. The solution is when you change around USB ports, right click on the printer icon that is actually the active one (the other copies will be grayed out) and Set to Default. Then you can delete the other invalid copies. Then in the Minolta status software, go to the Display menu and Select Printer to change which printer is monitored to the correct copy. It's very stupid that Windows Plug n' play does this, but it does. So avoid change around USB ports on your Konika Minolta printer.
Jul 19, 2009 | Minolta magicolor 2400W Laser Printer
Printer is not working.
Your computer should pop up and tell you that you've installed a new piece of equipment anytime you plug something into the USB port, since most peripherials are plug and play. If not, then it doesn't recognize the printer. You may have a bad USB port. Try plugging the wire into a different USB port during the installation process.
With Brother, you have to use their installation CD and follow their instructions. You can't hook up the wires till *after* the CD has walked you through their installation process.
Try reinstalling using their CD and a new USB port to see if it will work now.
Jan 06, 2009 | Brother HL 1440 Laser Printer
Is hp deskjet 2460 a plug and play printer?
Try uninstalling the software and delete the printer from you "Printers and Faxes" window if it is there.
Disable your firewall and any antivirus programs you have running.
Try installing the printer again according to the setup guide.
Once installed enable your firewall and A/V.
Sep 09, 2008 | HP Deskjet 2460 InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
71 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
