Question about ASUS M2V Motherboard
Usb 2.0 does asus m2v already have usb 2.0 capability and if so how do i deturmin if i have the right driver
    President:
  • 2,351 Answers
Yes, your M2V board is USB 2.0 complaint.
How do know if your PC has USB 2.0?
You can identify whether your PC has Hi-Speed USB or relatively easy. Open control panel, open System. Click the Hardware tab & Click Device Manager.
Scroll down to Universal Serial Bus Controllers. Click the + sign to expand. There should be an "Enhanced" USB host controller present. Windows 98 systems may use a different name, because Hi-Speed USB drivers in this operating systems are not provided directly from Microsoft, (Windows ME, 2000 and XP)
get their drivers through (Windows Update). There should also be two "standard" version USB host controllers present as well. They are embedded in the USB chip which routes the differing
USB speeds accordingly without user intervention. nVidia (shows as "Standard" controller) & not enhanced but are still USB 2.0
You need to enter your bios. How to enter your bios?
When you turn on your Pc press the delete key every 2 or 3 seconds. Your system will load the bios. Use your manual & go to pg. 4-16 section 4.4.2. Make sure you have Enabled USB 1.1 & enable USB 2.0. Enable Legacy USB support & set USB 2.0 Controller Mode to HiSpeed. Bios EHCI Hand-off, set to Enable
Save & Exit your bios. When your system has finished loading run Windows Update. This will update your USB driver to 2.0
How fast is USB 2.0? USB 2.0 has a raw data rate at 480Mbps.
If you have more question just ask!
please vote...
Posted on Feb 16, 2008
"M2V-MX SE"MOTHERBOARD WHICH MEMORY USE
Hello here are the info about the mainboard:
http://www.asus.com/Motherboard/M2VMX_SE/#specifications
The mainboard uses:
2 x DIMM, Max. 4 GB, DDR2 ram.
The driver download site:
http://support.asus.com/Download.aspx?SLanguage=en&m=M2V-MX%20SE&p=1&s=24
Good luck
Feb 26, 2013 | ASUS M2V-MX Motherboard
M2v usb 3.0 pci-e card not detected
Hello the home page is here:
http://www.asus.com/Motherboards/AMD_AM2/M2V/#specifications
Your mainboard does not support pci-e cards in the white socket.
They are TOTALLY INCOMPATIBLE with each other.
The PCI Express x1 is for a graphic card.
Usb 3,0 cards does exsist as pcix and this is what you are looking for.
If you want to know what pcix is:
http://en.wikipedia.org/wiki/PCI-X
Hope this will help you
Oct 26, 2012 | ASUS M2V Motherboard
Hello! Please help me! What are the video card supported for asus m2v mx se. I have processor amd athlon 64x2 (dual core 4800 2,4khz), 2 gb ram and windows 7 32 bit. Thank you very much and good luck!
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Feb 01, 2011 | ASUS M2V-MX Motherboard
I NEED TO WIN7 64 BIT DRIVERS FOR M2V ASUS MOTHER BOARD
Hello try the vista 64 bit driver from here:
http://www.asus.com/Motherboards/AMD_AM2/M2V/#download
Select the driver and hit global for download
Unzip the file before you install
Good luck
Nov 14, 2010 | ASUS M2V Motherboard
NO AUDIO , ASUS M2V-MX SE MOTHER BOARD. WEB SITE FOR FREE DOWN LOAD OF DRIVERS
Go here:
and enter "M2V-MX SE" in the search box on the top left corner. You will be asked your OS (XP, Vista, Linux, etc.) and brought to the appropriate download page.
You will find all drivers there - LAN, Video, Audio, BIOS, etc. Let me know how it worked out...
Apr 16, 2010 | ASUS M2V-MX Motherboard
I want asus m2v mx motherboard driver
Go to Asus Downloads
Enter your model number as M2V-MX in the Search box in the upper left and then click Search Info.
You will get 2 choices: M2V-MX and M2V-MX SE.
Click the correct one. Then you wil need to select your operating system from a pop-up window. Use the drop down menu and then click Search.
A list of available downloads will be listed.
Thanks for using Fixya.
Apr 05, 2010 | Computers & Internet
Vga driver of m2v-mx se
Windows XP VGA driver - http://dlsvr04.asus.com/pub/ASUS/misc/vga/VIAS3G_VGA_V6141071.zip
Vista Driver - http://dlsvr04.asus.com/pub/ASUS/misc/vga/VIAChrome9_VGA_V7141060_vista32.zip
May 06, 2009 | ASUS M2V-MX Motherboard
Regarding sound drivers in motherboard
Drivers are found here: http://support.asus.com/download/download.aspx?SLanguage=en-us
If you are not using Win XP, then select the appropriate operating system
Apr 25, 2009 | ASUS M2V-MX SE AMD AM2 Socket AM2 2000 MHz...
M2V Lan Driver
1 Why use vista is nothing but headaches and nightmares.
2 asus should have a driver listed on there website that can help you.
3 no driver may exisit for vista (common issue)
all else fails for finding a driver make a free account at http://www.driverguide.com/ (make sure to us a popup blocker when visiting)
Mar 19, 2009 | ASUS M2V Motherboard
Addinga card reader to an ASUS M2V m/board
Install a PCI usb card to give you the USB connectors.
Feb 16, 2009 | ASUS M2V Motherboard
ASUS M2V Motherboard Logo
842 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
