Charger will not fit anymore
I purchased a Delstar MP4 player 2 weeks ago, after I loaded my music into and try to charge it the charger appeared to change size and it will not charge anymore... what can I do???
  • nan1871 Feb 13, 2008
    Thank you, I'll try it but the usb cable I have does not fit in the mp4 player anymore...thanks for trying...
Yes I do, the USB cable is fine it's just the piece that goes to mp4 player does not fit anymore. I charged it and loaded my music and used it... I went to recharge it and the piece that goes into the mp4 player would not fit, it appeared to have gotten smaller...
Posted on Feb 14, 2008
  • 21 Answers
If you got a USB cable with the unit, you can connect to your PC and recharge the battery that way. Just be sure to have the power switch turned ON. The screen on the player will indicate its connected and you should see the battery indicator in the lower right corner showing a charging condition (bar moving)
Posted on Feb 13, 2008
  • John Schafer
    John Schafer Feb 13, 2008
    I'm a little confused. If I understood correctly, you have both a USB cable to connect to the computer, and an AC charger/adapter that you can plug into the player to recharge it. Is that correct?
  • John Schafer
    John Schafer Feb 14, 2008
    If you want accept my tech buddy invite and we can talk directly about this problem. I may have a solution, but I need to ask some detailed questions about the connector and player.
The mp4 player will be fully charged and when i take it off the charger and i want to listen to it. It will pause and freeze then will turn off right away. I will try to turn it back on and it wont turn...
i think in 3 possible solutions: 1- try to charge it with another charger 2- connect your mp4 to a computer and run a virus scan, after this try it. if don't, format your mp4 and try to charge it again. 3- the charge system of your mp4 is damaged, so take it to the technical support for to repair it.
Aug 05, 2011 | Mach Speed Trio V430 MP3 Player
Help my MP4 players wont turn on!
Does the icons on the unit show if it's charging? If so the LED is on the charger is bad.
Sep 16, 2008 | Delstar DS-802 Digital Media Player
Usb cable for delstar mp4 degital player
The cable plug is called Hirose. Specifically a mini-B 4pin Hirose, BUT-- there is a single slot as well as a double slot. You need the double.
640dab4.jpg If you find one and can't tell from the pics or description, ask the vendor.
Here are a few links though I haven't purchased myself.
http://foliumcei.com/usbadapteramaletohiroseminib4pmale.aspx 99 CENTS!!!!!!!!!!!!!!!!!!!!!!!
http://www.powersonic.ca/usb20-cable-mini-hirosemini-p-3714.html?osCsid=38c68f6d5fdb33d77b04d6c43004c103
http://www.revealcable.co.uk/acatalog/Camcorder.html
http://www.ebuyer.com/product/95792
http://www.ebuyer.com/product/95797
http://stores.channeladvisor.com/cablestar/Items/hiroseusbzz?sck=73192081&caSKU=hiroseusbzz&caTitle=USB2%204%20Pin%20HiRose%20MP3%20Digital%20Camera%20Cable%201.8m%20Lead
So I guess you lost your AC charger as well. I recently purchased a cool USB charger at Dollar Tree. They also have various cords including USB A to A extension in case you only purchase a Hirose adapter. Good luck.
Sep 01, 2008 | Delstar DS-802 Digital Media Player
A locked Delstar MP4 player
hold bottom button it locks and unlocks player
Jul 04, 2008 | Delstar Audio Players & Recorders
Jensen GPS charger adapter
just get a standard 5 volt charger. Most 5 volt chargers use the same plug size. My jensen uses the same charcher as my pocket pc and my mp4 player.
Jun 16, 2008 | GPS
Wont charge
Try using a wall charger.
Apr 16, 2008 | Delstar DS 917 Digital Media Player
Delstar 1GB MP4 Digital Player
Have you got that on ON position. Some time you have to hold th play button for few seconds to get it on
SSB
Jan 11, 2008 | Delstar DS-2821 Digital Media Player
Delstar Mp4 player
I HAVE 3 delstar mp4 player and it worked fine for a few months. I plugged it in to charge, took it off the charger and now it is frozen on a blue screen with an hourglass design. What's wrong and how can it be fixed? Help please ALSO I FORGOT TO MENTION THAT NONE OF THE 3 MP3/MP4 TURNS ON AT ALL. PLEASE HELP....
Dec 07, 2007 | Audio Players & Recorders
Help me how to put music to panasonic sv-mp730v
When the battery is charged it should appear as a USB storage device to your operating system.  You can interrupt the charging by pressing the `mode' button if your battery is good.
I found with my (SV-MP730V) that with a duff battery, I got the symptoms you describe ... now I have to find a new battery!
Oct 03, 2007 | Panasonic SV-MP510 MP3 Player
156 people viewed this question
 Grubhead
Grubhead
