Question about Dell 2300MP Multimedia Projector
Dell 2300 projects verticle stripes accross the projector screen.
My Dell 2300, projects verticle non moving stripes accross the screen, certain colors are not present when it does this. Projector has only about 100 hrs on whole unit.
I have reset the bulb, blew out the machine for dust and reset it several times.
  • 44 Answers
This is due to improper power supply or a loose connection inside. the symptoms are of power supply unit inside projector. check out the current and amperes inside the projector on board. sometime the current stable but the ampears are down.also check the switching transistors & filters inside.......
Posted on Feb 12, 2008
I have a Optoma EP721. It now projects verticle lines on the screen background. How do you eliminate the verticle lines ?
It sounds like you have a projector which is in need of professional repair. You should eliminate source material problems first though by checking the projector with alternative input sources, ensuring that you also check the cables, and various inputs on the projector.
If the lines are present on all the inputs then the fault is internal to the projector. This will require professional repair. The first point of contact should be Optoma at www.optoma.co.uk/support.aspx (UK) or http://www.optomausa.com/ (USA). They should be able to give you an idea of ow much it may potentially cost to have your projector repaired and (most importantly) check whether it is under warranty. Most Optoma projectors ship with 3 year warranties these days.
Feb 19, 2011 | Optoma EP721 Projector
Dell 2300 MP Verticle lines distorted image
light engine or bulb is gettingbad ok how many hours on bulb fans clean ect thx nick
Feb 11, 2008 | Dell 2300MP Multimedia Projector
4 narrow bright stripes down left side of screen
reset the projector,if it doesnt help,its probly got to do with ur dlp colour wheel.
Jul 03, 2010 | Optoma EP739 Multimedia Projector
We are using a Dell 2300 projector. The Power
check that you have a signal going out of the monitor socket on your lalptop.
On Dell with projector connected and switched on, press the blue fn button bottom left usually, and while holding, press one marked CRT/LCD, (maybe f8) this will cycle to the following.
laptop only, laptop and monitor, monitor only, while holding Fn button press until you have desired outcome.
hope this helps.
Apr 12, 2010 | Dell 2300MP Multimedia Projector
I have a Mitsubishi WD-52525 DLP
if you have a picture the engine is probably ok. this is a common problem with this set.it is probably the main chassis (DM or FMT)
visit www.tv-techs.com
Dec 17, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Won't project; can't find signal
Make sure that your computer was turned on first (don't ask me why). Then hold down the Fn key while pressing F8. Hope that helps.
Aug 28, 2008 | Dell 3200MP Multimedia Projector
Projectors
Hi there
This would mean that your Projector is still under warranty.
The problem you are describing is a faulty Mainboard - which fortunatelly for you is covered under warranty.
Mar 31, 2008 | Office Equipment & Supplies
Lcd proctor image
Disconnect the computer and then run projector if it still comes then service your projector.
Viren
Sep 11, 2007 | Optoma EP737 - DLP PROJECTOR - 1500 LUMENS...
VT45 Projector: Blue pixels throughout screen
If the problem is what I describe as a blue haze over the entire image projected, I was told this is a defect in the cable - we have a Dell Video Projector 2300 - and it takes only a dell VGA cable.
So, the problem is in the cable - solution is replace cable.
Feb 28, 2007 | NEC VT45LPK Projector Lamp for VT45
Dell 2300MP Multimedia Projector Logo
591 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
