Question about Ovens
Oven staying hot a long time after it was turned off
I cooked something at 8:30 and it burned, even though it was only in for five minutes on 350. It seemed that the oven was on a much higher temperature. Now the door panel where the lock is for self cleaning is very hot, I have never used the self cleaning option and the oven door is not locked. Why is this so hot 1/2 hour after I turned the oven off. Also it seems that the broiler coils are hot, not red. No indicator lights are on, and the oven has been off for 1/2 hour. I am worried about an electrical malfunction. Do not know what to check for in the circuit box or how to unplug the oven.. It is a whirlpool about 20 years old built in the house with the microwave on top.
  • CareyD Feb 24, 2009
    My oven is a GE flattop, 10yrs old, and the other evening after I shut the oven off, I realtized about 2 hrs later the oven was off but the oven was very hot. The coil on the bottom of the oven in one spot about the size of an inch was glowing orange while I was baking the chicken, but then it stopped. Decided to unplug, but now I don't know what to do. Any advice?
  • Gary Davd
    Gary Davd May 11, 2010
    need the model # you could have a stuck controller or thermostat. there is no plug it is hardwired you will need to turn off at the breaker box
Thanks for your reply. I contacted an appliance repair person I have used before and he told me about turning off the breaker, which I did. He suggested using an oven thermostat to see if it was heating to the correct temperature as a first step. It may be the thermostat, I do not know what the controller is as presented by one of the responders. At any rate I learned that my breaker for the oven is by itself and is not attached to the stovetop which is good. I will have to weigh the cost of replacing a part on a 20 year old builder quality oven with microwave on top to a new one. Any ideas on a new problem free model are appreciated!!
Posted on Feb 12, 2008
We cooked pizza at 500 something popped and now our oven cooks but not right , any ideas
If you have an electric range, look at both the top and bottom elements while oven is cold. Look for a rough spot like a hole in the element. You may have just burned out one of the elements. Sometimes they go bad without any marks. Turn on oven to about 350 and watch the bottom element to see if it gets red hot. Then set for broil and watch the top for the same red hot glow. If either does not glow red after 5 to 10 minutes, that element is bad.
Apr 02, 2016 | Ovens
When cooking Pizza at 220c the top burns-even though the element is on the top and the pizza in the bottom third of the oven, and the base is uncooked - this also takes 30 minutes to cook?
you are using the broiler to cook it,the upper element is the broiler,the lower one is for the oven,turn on the oven so that the bottom element is on,if it doesnt work,then that is the problem
Jul 19, 2015 | Ovens
Whirlpool gas oven is taking three times as long to cook something,what is wrong?
have you checked with an oven type thermometer for 350 degrees against the setting of 350 degrees,if its off very far then its the oven temp sensor in the upper left middle or right rear wall of the oven thats bad it looks like a small pencil type rod 2" to*' long it merely unplugs off the oven s control panel in the rear,you can test its resistance also to get an idea if it is your culprit,otherwise the oven element could have a hot spot in it and not letting all the current thru to properly heat the element,it will be dis-colored in that area
Nov 23, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
GE Profile Oven temperature varies wildly
What is the model number of your unit?
Nov 19, 2012 | Ovens
Does an electric oven need curing before I cook in it for the first time? If so, how long and at what temperature?
you can run it at 350 for like a half hour or so and you'll smell a funny smell from the metal heating up,when i replace an ignitor or an element i run it for like 10 minutes just to burn off the smell of the metal.i'm sure the factory already had that fired up to check it but i would start it and burn anything off of it that might be in there before i cooked anything,it can't hurt it.good luck with your new machine.
Apr 08, 2011 | Whirlpool RBD305PD Electric Double Oven
Kenmore 790.95662100 electric oven does not bake evenly. It seems to bake items until you get into the center of a cake or the center of something with mass. The same temp has previously cooked without...
Sounds like the thermostat is out of calibration. IE- you set the temp at 350, but the actual temp is only 275, resulting in undercooked food. I repair comercial restaurant equipment, and use an infra red thermometer to check actual temp in the oven, against the set temp.
Mar 27, 2011 | Kenmore 49222 Electric Single Oven
I have an SL100 - 10W La Germania table top oven (gas) I did not receive a operations manual with purchase of the oven and I do not understand its operation. Questions 1. How does it maintain the set...
I GOT THE SAME QUESTION .. IT IS A GAS OVEN . WHEN THERMOSTAT IS SET TO GAS MARK 4 WHICH IS EQUIVALENT TO 350 DEGREES , AFTER 10 MINUTES, IT REACHES ITS DESIRED TEMP. BUT IF I DON'T ADJUST THE FLAME, THE TEMP WILL RISE HIGHER AND HOTTER THAT I NEED TO OPEN THE OVEN DOOR TO DECREASE THE TEMPERATURE INSIDE. ANYONE KNOWS IF THAT IS NORMAL? THANKS12_1_2012_3_54_19_am.jpg
Oct 26, 2010 | Ovens
Cooking
A good pre-heated pizza stone will help cook the crust better when the pizza is placed right on the stone. As for the cheese burning, check the actual temp. of the oven with a good thermometer.
Feb 07, 2008 | Blodgett DFG-100 Gas Single Oven
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Gas oven not heating to temp
The fault is either the capillary has fallen away from back or it is a faulty thermostat.
Regards
Advisor
Nov 17, 2007 | Ovens
Ovens Logo
754 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
