Question about Amana AFD2535DES French Door Refrigerator
How do I test the defrost thermostat?
The evaporator fan will not run...tested the fan > works, tested the freezer light switch > works. If I connect the defrost thermostat wires together should the fan immediately start running if the thermostat is faulty?
I'm down to the thermostat or the jazz board and I want to make sure I'm not missing something before I buy the jazz board.
Thanks in advance for any help.
  • Stratfm Feb 12, 2008
    If you can please send the the manual on test process and test point to my e-mail: framalfar@yahoo.ca
    Thanks
  • 770 Answers
The fan is ctrl by the Jazz board the thermdisc is for defrost post your email and I will send you the manual on test process and test point as well as the defrost
Posted on Feb 12, 2008
  • Guy Many Aug 04, 2013
    Hi Gary. Thx!
    Please send to gmany@avaya.com. Thx!
There is ice forming on the evaporator coils of my GE Monogram refrigerator. This is the "all-refrigerator" model (ZIRS36NMDLH). There appear to be two 'thermodisc'. One thermodisc is...
Hi.
When the back of the freezer is icing up you need to test the defrost system, which is responsible for the problem . The evaporator coils freeze up because the defrost system is not working. this results in compressor and fan running most of the time and in reduced or no cooling, particularly in the fresh food section. The freezer may still be cooling.
Defrost system problems are quite a common issue with refrigerators. Coils freeze because of a defective defrost system. With coils frozen the condenser will go under stress and will loose efficiency. The result is the system not producing enough cold to refrigerate the fresh food section while the freezer section instead keeps working.
Try disconnecting power overnight. Allow the freezer to defrost with power off. If the fridge works after that you have a defective defrost system. In that case the problem may come back after a couple of days. To fix the problem the parts comprised in defrost system must be tested, so to find and replace the defective part.
The defrost system comprises defrost thermostat, heater, defrost control and fan. The parts that fail more commonly are thermostat and heater. Both parts are located behind freezer firewall and tested reading impedance with a multimeter. Element and thermostat are faulty if they return Ohms infinity (the circuit is open) when reading impedance with a multimeter at the part's contact.
If thermostat and element are OK, the next part to be tested is the fan. Fan can be tested by simply checking that the motor is running when energized.
Here a tip explaining how to deal with a similar problem on a different fridge model: Fridge not cooling. Procedure is similar with your model.
Here all parts and diagrams for your model.
You can also find parts and diagrams for most appliances using the links listed on this page:
Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Aug 22, 2011 | GE Refrigerators
Ice develops at back of fridge
hi chris
dave here hope i can help
I would test the defrost timer, defrost heater or defrost limit switch
TESTING AND REPLACING THE DEFROST TIMER
This timer activates the heater that melts frost in the evaporator for 10 to 20 minutes every 10 to 12 hours. In the process, it turns the compressor off and on. If it fails, the compressor may not run. Or the heater may not go on, eventually causing a hidden ice buildup that blocks the cold-air flow and disables the evaporator fan. An access hole lets you test the timer. If the timer isn't in the control panel, look behind the front grille or behind the rear access panel. If the compressor fails to run turn the timer until it clicks. If compressor goes on, timer is faulty. If unit isn't defrosting automatically and turning timer stops compressor or fan, timer is faulty.
Before replacing timer, spray it with electrical contact cleaner through access hole and turn it a few times. Stop just before a click and wait to see if timer advances on its own.
To replace timer, unplug the refrigerator and open control panel. Remove screws holding timer to panel and pull of leads. If wires aren't in a plug, move then one at a time to new timer.
EVAPORATOR AND DEFROST HEATER
In a frost-free unit, the evaporator coils, their fan, and the deforst heater are located behind the freezer's back wall or under its floor. The fan, which circulates cold air between the coils and the two food compartments, is controlled by the door switch, the thermostat, or both. To check the fan, open both doors, wait for the compressor to go on, and hold in the door switch. If you can't hear the fan running, test the fan(below).
The defrost heater, which melts frost on the coils, is cycled on by the defrost timer(above). If the frost melts before the end of the defrost cycle, the defrost limit switch turns the heater off. The heater may be a metal rod, a wire wrapped in foil, or a coil inside a glass tube. All are tested the same way. Test terminals for the heater are often located in the control panel or under a doorjamb; check the wiring diagram. Or test the heater leads inside the evaporator compartment.
TESTING THE EVAPORATOR FAN
To remove the evaporator fan, unplug unit; open back panel(or floor) of freezer. Then unscrew housing holding fan, and take off leads going to fan motor. With VOM(Volt-Ohm Meter) on RX1, probe motor terminals(except green ground wire terminal). Look for moderate resistance(50 to 200 ohms). Replace fan if much lower or infinity.
TESTING THE DEFROST HEATER
Open control panel. With VOM on RX1, probe test terminals. Look for 15-to 100-ohm reading. If infinity, turn defrost timer(as above); retest.
TESTING DEFROST LIMIT SWITCH
Trace and disconnect leads. With VOM on RX1, probe leads. Look for infinity reading when switch is warm, zero after 20 minutes in working freezer.
Hope this sources your problem
Thank you for using Fixya.com
Jul 20, 2008 | AEG Santo U 86000i Compact Refrigerator
I have a sub zero 361rfd. The freezer portion is no longer cooling, however the fan still runs. Also, The refrigerator is set to the coolest temperature but I suspect it's not sufficiently cold....
Check the temperature setting Assure that there is enough room for air flow in the freezer or freezer Check for air flow restrictions in vents Test the temperature control Clean the condensor coils Check the door seals Test the door switch Test defrost heater Test defrost timer Test evaporator fan Check for a clogged drain tube Check for refrigerant leak Freezer is too cold
Check the temperature setting Test the temperature control Freezer is noisy
Hissing and popping is normal, it is the defrost heater. Check that the freezer is level Check the drain pan Check the condensor fan Check the evaporator fan Inspect the compressor mounts Freezer runs continuously
Defrost the freezer Clean the condensor coils Check the door seals Freezer starts and stops frequently
Clean the condensor coils Check the outlet voltage Test the condensor fan Test the compressor relay Test the overload protector Test the compressor motor Freezer does not defrost automatically
Test the defrost timer Test the defrost heater Test the defrost thermostat Freezer has an unpleasant odor
Remove spoiled food Clean freezer interior with a solution of h Clean freezer interior with a solution of hot water and baking soda Clean the door seals Remove breaker strips and check for wet insulation Water on floor outside of freezer
Check the drain pan If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve Water inside the freezer
Check for a clogged drain tube If you have an ice-maker, check freezer and ice-maker for level
Hoping that this will help to solve the problem....
Aug 18, 2011 | Refrigerators
Kenmore 253. 9287413 Can't get the freezer to get cold enough. Freezer alarm keeps turning on and the temperature is only 25 degrees inside. Temperature alarm light stays on all the time. Quick freeze...
You can fix this, just follow the procedure given to enable get back your refrigerator going,
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
I hope this will help in solving the problem......
May 10, 2011 | Refrigerators
MY FREEZE WILL NOT GET COLD OR FREEZE ANYTHING
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
If you have an ice-maker, check freezer and ice-maker for level.
With all this it helps to solve the problem....
May 04, 2011 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Does it make sense that a frigidaire plhs67egsb3 refrigerator freezer could stop working simply from overloading? The compressor is running, the condenser coil was clean but the evaporator coil was frozen...
the defrost heater or thermostat circuitry is bad,you need to test both components,also the defrost timer control if the other parts test o.k..,the defrost tstat has to be below 32 degrees or it will test bad/open,when the evaporator coil gets iced up you cannot blow cold air through a solid block of ice,(NO air flow)means no cold air throughout the unit even with the evaporator fan running
Apr 12, 2011 | Frigidaire Freezer FFU1212D
Freezer not cold.
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
Hope this will help in solving the problem.....
Oct 07, 2010 | Frigidaire Refrigerators
The freezer side is not keeping food frozen. Every three minutes I hear something turn on and it runs for about xx seconds. The model number is ASD2626HES. The refrigerator side seems fine.
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
Hope this solved the problem, Take care....
Sep 19, 2010 | Amana ASD2626HE Stainless Steel Side by...
Not cooling as normal 2008 summit ridge reserve dometic rm 1350 with ice maker. started acting up last year, fans not coming on so I addedan external one .problem solved until recently lost power. now...
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 21, 2009 | Refrigerators
I have a cold freezer/warm fridge problem
Hi, Yes, They are the same thing. Can you hear the fan motor running in the freezer? If not it probably needs replaced. Some units shut the fan off by a door switch. If its not running when the door is closed, it could be the door switch. If the fan is ok, make sure the thermostat is set right. Sometimes something in the frige gets bumped against it and it will get moved. NOTE: Allow aprox 12-24 hours for changes in thermostat settings to take full effect. If this all checks out ok I would suspect the defrost timer. Remove everything and place in coolers or another refrigerator. Unplug the refrigerator. With doors open let it sit for aprox 6 hrs. A fan blowing into the freezer section will help. Plug back in and see if it works good again. If it works good for a couple of days and problem returns, Replace the defrost timer. Hope this helps. kstfas
Sep 15, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Amana AFD2535DES French Door Refrigerator Logo
454 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
