Question about Cobra 25 LTD 40-Channels Base CB Radio
Fuse each time i connect power to my cobra 25 it blows the inline fuse, any advice or help would be great
  • drive1951 Feb 13, 2008
    i am trying to locate a reverse protection diode
    for my cobra 25 cb, can't read the numbers off bad diode
    anyone who knows where to find this diode and what numbers to ask for. and would like to extend my thanks to BENIMUR>>
    Brigadier General:
  • 6,966 Answers
There are only a couple of components that could cause the fuse to blow. They are:
1. Reverse protection diode (D23)
2. filter capacitor (C123)
3. Outputs (TR14 & 15)
4. Audio Amp (IC4)
5. Zener Diodes (D22 & 19)
6. the fuse itself (it should be 2 Amps
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 12, 2008
  • Louie  Role
    Louie Role Feb 14, 2008
    Hi again drive1951 ,
    Appreciate the update and you're more than welcome. Am glad to be of assistance and appreciate the rating too.
    Though I have to correct myself. Initially given numbers were for a Cobra 29, the PCB part numbers for the Cobra 25 LTG should be:
    1. Reverse protection diode (D17)
    2. filter capacitor (C65 1000uF/16V)
    3. Output/Driver (TR7 2SC2075 & TR8 2SC1957)
    4. Audio Amp (IC1 TA7222AP)
    5. Zener Diodes (D13 & 15)
    To your 2nd post > location of D23/Reverse Protection Diode
    it is often across the power connector terminals rear end inside the unit. In some other instances, it is soldered to the PCB but still very near the power connector. It would be the only biggest diode inside. Another indicator that it is bad is when the fuse blows even if the radio is switched off.
    To your post > can't read the numbers off bad diode
    depends which diode:
    D17 - 1N5400 or 1N4003 or SR1K1
    D13 - 5.1volts
    D15 - 9.1volts
What size fuse is used in COBRA 29LTD CLASSIC radio.
First question should be, what happened to the last one? If the fuse blew on you, you need to find out why. If it was just missing when you got the radio...
That said it is surprising that the manual doesn't state this value directly. However, it is a 4W transmitter and the manual I referenced states that you should connect to an "accessory" fuse for mobile installation. My car has a 10a fuse in that position but a 3A slo-blow in the power wire's inline fuse holder should do the trick. (The main reason for using the "Accessory" fuse is for operation with the engine off, but not battery drain unless the key is inserted.) Another clue for my SWAG is that for a "base station" installation, the manual recommends a 12Vdc power supply that can deliver >2A... So I think we are in the ballpark.
If you have lost your original manual you can get a replacement from the Cobra support site here:
https://www.cobra.com/support/product-manuals
V/R,
Veg
If a train station is where the train stops, what happens at my workstation?
~Author Unknown
May 04, 2016 | Radio Communications
Brand new Midland 5001z 40 channel cb blows fuses its turned on
Where did you buy the radio at? Can you return it to the store? If you purchased it at a big box store, like Walmart, they will take it back without a receipt on an exchange.
More than likely the radio was wired backwards by someone, which blew the protection diode, and then was returned to the store and put back on the shelf.
If it is just a blown protection diode, it is only a $10 fix at most any cb radio shop.
If I can help anymore, please let me know.
Dean Pitts
Rollin CBs
dean@rollincb.com
Feb 05, 2012 | Radio Communications
Brand new Midland 5001z blows fuses immediately after its turned on. I tried the power cord on Cobra 25 that has the identical plug configuration and its Ok. I don't have the receipt as I got it a
bad final also check for any burned resistors in the area. If the final caused the resistor to burn the just replacing the resistor it would burn the new one also.
Feb 05, 2012 | Midland 5001 40-Channels Base CB Radio
I have a 29 ltd with no mods that i know of .i installed it into my 2006 nissan titan and when i plug my power cord into the unit it instantly blows the inline fuse. i have a 3 amp fuse in it . do you...
  • Well it could be. Did the CB work before putting it into your truck? If the fuse is blowing you have a direct short. You might pull them two little screws on the tip of the cord and inspect the wires and tips of the cord. Make sure everything looks good there. Make sure the cord is hooked up properly as well.
  • Let me know what you find out.
  • Hope this helps.
Nov 19, 2011 | Cobra 29 LTD CB Radio
Have cobra 29 nw ltd keeps blowing fuses inline and in cigarette lighter adapter adapter is 10 amps and inline is no more than 5 amps
This is an easy fix if you are comfortable soldering.
You must have hooked it up backwards. Big problem when using a cigarette lighter adapter. You have to be careful, if you hook a radio up backwards you blow the polarity protection diode.
  • Go to radio shack and buy an N1004 diode.
  • Open the radio
  • Look towards the back right of the radio for a black diode D23. it will probably look burnt, but not always.
  • Use a soldering wick to remove the solder holding the diode in.
  • Remove it, and replace the diode making sure its going in the same direction as the old on. Strip on the side the triangle is pointing.
  • Solder it in.
  • Test the radio
That should do it.
Make sure you are careful to hook the radio up to power corrctly.
Nov 14, 2009 | Cobra 29 LTD CB Radio
Cobra 25LTD Classic internal neg. wire burnt when I hooked up.
COBRA RADIOS HAVE A DIODE THAT WILL BLOW IF HOOKED UP BACKWARDS, THIS IS A BLACK DIODE WITH A SILVER RING ON ONE END OF IT, YOU MAY HAVE TO TAKE IT TO A CB REPAIR SHOP AND HAVE IT REPLACED, HOPEFULLY YOU DID NOT USE OVER A 5 AMP FUSE
Apr 01, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Trying to hook up a cobra 29 but keep blowing inline fuse
I had the same problem with a 25 that was just disconnected for replacement. I found a shorted diode right where the power cord came in. I also didn't like the way the electrolytic capacitor right next to it was charging so I changed it also.
Problem solved.
I am sure the 29 will have a similar setup. I you want I will look up my schematicof a 29 and tell you the numbers to check.
Of course it is also possible somehow too much voltage was applied to the radio. In which case the previous repairs will almost surely be needed.
I hope this helped, Good luck
tdill49
Feb 22, 2009 | Cobra 29 LTD CB Radio
Cb Radio blows the 15 amp fuse in the car when powered up
Look where the hook up wire goes into the circuit board. Find the protection diode.Round small black cynlinder with a silver band. cut the diode and run a continuity check across the positive and negative. If all checks out try to fire it up.15 amp fuse is way to high for that radio use 5- 7
Feb 09, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
CB keeps blowing fuses
There are a few common reasons the fuse keeps blowing:
1. The transmitter final transistor is bad, it usually is directly connected to the 12v source and not switched by the power switch.
2. The power wires were accidentally reversed I.E. positive to ground, neg to 12v. There is a protection diode on the circuit board that did its job and is now shorted. it will keep blowing fuses until its replaced.
Dec 30, 2008 | Cobra 18 WX ST 40-Channels Base CB Radio
No sound
Yes It sounds as though the audio amp may have taken the hit go to this link and download the service manual it will give you voltage info http://www.cbtricks.com/radios/cobra/25ltd_st_25wx_st/index.htm ...Chia
P.S. If you have an external speaker plug it in to the PA hole on the back put the radio on PA and see if you get any sound then if the dynamike is turned up it will be LOUD.If not I would replace the audio amp.If you need one let me know and ill directc you in the right direction...Chia
Jan 10, 2008 | Radio Communications
Cobra 25 LTD 40-Channels Base CB Radio Logo
327 people viewed this question
Top Cobra Radio Communications Experts
Steve
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
