Question about RIM BlackBerry Pearl 8100
Jackhammer I wanted to know why my jackhammer isn't working the way it was. It feels like it's really dry inside (not as smooth & easygoing as before) and too slow. I wanted to know if it needs greasing or a tune up or any maintenance???
  • wood warrior Feb 13, 2008
    Actually my question was about a 60 lb. jackhammer. You know? the kind that you use to "break concrete" BOSH brute jackhammer. It's used to break concrete, walls etc. So I just wanted to know if it needed lubrication on it or greasing or any other maintanance on it. Because it's not working the way it was it's a little bit slower than before.
Hi
Check your main memory. If you could have loaded more number of programs there will be problem in accessing the memory. Automoatically the speed will come down. If you remove of those unwanted stuff from your phone including stored messages you will find better speed and accessibility.
Sam
Posted on Feb 12, 2008
How do i fix oil leak in seals of jackhammer
by a service kit that are made for your model
I do you a suggestion how you can do it yourself if you have a burner to heat up the bolts because of loctite sealant i think you know something of forces on that parts ? because of the tools that are neccesary to service it .
Here is a suggestion of a brand that is maybe there or coming in your Country . thats why i do this suggestion by a dutch link .
https://devs.hitachi-koki.co.jp/ois/explodedDiagram.html?type=svg&modelName=H+90SE&newwindow=true
If you know the brand of your hammer ? sometimes bought secondhand and no modelname google it on 3 words powertools the brand service or choose pictures if you will see pictures where you can see your hammer but there are can be marketing technical differences by the models because a suggestion i made by Hitachi the H90 and H90SE are not compatible by service kit a part of spares can only be used.
The time you spend is meaningless if you only think its leaking oil. because there is a thin lubrication inside most jackhammers and if that's leaking ,the working hours are on it, for time wasted re prematurely burned grommets make high-priority work bolt seal the front of the machine at the stroke chisel the first rings oil seals as well as the size of the stroke bolt must be tight and smooth, as if only a little air leaks burned den all your new o-rings (ie be hard in the short term) by overheating, use lubricants, not just fat because of the high temperature internal structure and the thermal conductivity of the parts together.
Jan 13, 2015 | Hammering
Wh a t type of oil do I use on a H65 hittachi jackhammer
Is not enough this is a better suggestion for you because of wasting time for only oil (lubrication is not only very importand because of heating but if it was leaking theres more to do 323745 service kit comes complete with the most neccesary parts allways but priority in this is extra (in most cases) change the strokebolt(second hammer) allways by if that looks not smooth surface.
https://devs.hitachi-koki.co.jp/ois/explodedDiagram.html?type=svg&modelName=H+65SB2&newwindow=true
Dec 10, 2014 | Hammering
Car jerks hard taking off
Since you\'re old school I would think you\'ve already checked the normal stuff like the fluid level in the transmission. If this is good, has the transmission ever been serviced? I\'m not familiar with your vehicle so if it has a filter it could be that is partially clogged, Does the fluid have a strong smell to it? Does is feel absolutely smooth or can you feel or see little flecks of something in it. You may solve this by dropping the pan and replacing the filter. But if that is the problem it will only be temporary as if there is debris in the pan you are ready for a rebuild.The sooner you do it, the better before you have hard part damage. Another possibility is a bad solenoid in the tramsission that isn\'t sensing the pressure until it is high enough to jerk when it kicks into gear. Again to even check this though you need a transmission guy to pull it and look it over. Sorry guy.
Mar 23, 2014 | 2007 Pontiac G6 GT Convertible
H45sb start but dont hammering
Or a 320825 CONNECTING ROD or worn striker / or second hammer this is a very high priority very critical peace because of its a 2 millimeter 2 short difference sometimes to measure it will not good reach each other because of the chicel. must can get an idle mode if there is no push and by Hitachi you never believe it it gets worn you should see the difference with new parts pos 12 until 25 (parts 24 and 18 are the high priority parts together) its not a good idea to service a hammer where gaskets seals or o-rings are not fully air-tight. then the o-rings are burning again in a very short time because the tool becomes inside dry and overheat if its starts leaking
https://devs.hitachi-koki.co.jp/ois/explodedDiagram.html?type=svg&modelName=H+45SR&newwindow=true
Feb 02, 2014 | Electric Demolition Jackhammer
How do I pair my jabra easygo to my I phone 4s?
Detailed instructions can be found by downloading the user manual from the Jabra support page.
PAIRING IT WITH YOUR PHONE1 Put the headset in pairing mode- When you turn on your Jabra EASYGO for the first time, theheadset will automatically start up in pairing mode, i.e., it isdiscoverable for your phone. When the headset is in pairingmode the Bluetooth status indication on the StatusDisplay isflashing.2 Set your Bluetooth phone to discover the EASYGO- On your iPhone 4s, go to settings>General>Bluetooth and make sure Bluetooth is turned on.3 Your phone will find the Jabra EASYGO- Your phone will find the headset under name Jabra EASYGO.Your phone then asks if you want to pair with the headset.Accept by pressing Yes or OK on the phone. You may beasked to confirm with a passkey or PIN. Then use 0000(4 zeros). Your phone will confirm when pairing is completeand the Bluetooth status indication on the StatusDisplay willshift from flashing light to steady light and the headset voiceguidance will say connected.
Manual pairing modeIf you wish to use the headset with a different phone, or if thepairing process was interrupted, you can manually set the headsetto pairing mode.Make sure the headset is on. Press and hold the answer/end buttonfor approximately 5 seconds until the Bluetooth icon turns froma steady light to a flashing light. Then repeat steps 2 and 3 in theabove pairing guide.Connecting with your phonePairing is only needed the first time a headset and phone areused together. When the headset and phone have been pairedonce, they will automatically connect when the headset is on andBluetooth is activated on the phone. The headset can be usedwhen it is connected to the phone. If the devices are paired, butdo not immediately connect, tap the answer/end button. Whenyour headset is connected the Bluetooth connection icon in theSTATUSDISPLAY WILL BE CONSTANT ON FOR 3 SECONDS andthe headset voice guidance will say connected.
Feb 19, 2012 | iPhone Apps
How do you know if the truck's 4 wheel drive is working? Thank you
On a dry dirt road put it in 4wd and drive slowley while turning back and forth very sharp, you will feel the wheels bind with each other. Then put it back in 2wd to feel the difference. You won't feel a huge difference on the dry dirt, but it will be there if the 4wd works. If you try this on dry pavement you will REALLY feel it and hear the tires straining with each other. It is not recommended that you make a habit of this on dry pavement because the binding is really hard on your drivetrain.
Dec 26, 2010 | Ford F-150 Cars & Trucks
I want to paint my 2008 mazda3 hatchback rims black! Any suggestions??
Sand blast first..........Then prime and paint with rock guard black or powder coat them which include backing as well......Hope this helps.
Sep 12, 2010 | 2008 Mazda Mazda3 Hatchback
Jackhammer drill with false contact
Replace the switch... it is bad...
heatman101
May 31, 2010 | Hammer Factory-Reconditioned Milwaukee...
When I apply the brakes on my 2001 GMC youkon about 2/3rds of the time I hear a grinding type noise that I can feel in the brake pedal. The truck stops fine the pads rotors etc. all look good. Any ideas?
When you say the pads and rotors look good, did you actually remove the wheels and check them? A lot of times the outside pad will look ok, but the inside pad can be right down to the metal backing plate. If you can get under the truck, run your finger across the rotors on the inside of the rotor. It should feel smooth. If it feels rough, the inside pad is gone. There really isnt any other reason you would both hear and feel grinding in the brakes.
Nov 21, 2009 | 2001 GMC Yukon XL
Kango 950k
it sounds like it needs service,service is taking lower unit apart cleaning and regrease with special kango grease, if unit was serviced recently or not used much, grease could be real old and dry,sometimes you have to warm up unit before they start hitting correctly,,also if used a lot could be dirt build up,inside bit holder.remove bit holder clean out dirt regrease with heavy bearing grease,just grease the lower part,not very much grease is needed
Jul 28, 2009 | Electric Demolition Jackhammer
RIM BlackBerry  Pearl  8100 Logo
112 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
