Question about Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System
Door would not close all the way
I installed a new chamberlain whisper garage door opener 3/4 hp door doesn't close all the way down?
  • 504 Answers
DOES IT REVERSE OR STOPS BUT NOT TOUCHING THE FLOOR?
IF IT DOESN'T TOUCH THE FLOOR YOU EITHER NEED TO ADJUST THE DOWN TRAVEL OR LENGTHEN THE CONNECTING ARM.
IF IT REVERSES YOU NEED TO DETERMINE IF IT IS THE SENSITIVITY OR THE SAFETY EYES.
Posted on May 27, 2010
My new installed garage door opener closes and opens right away
You have to adjust the safety pressure sensor. It is set to too light a pressure. Check your manual for the adjustment.
Mar 10, 2013 | Chamberlain 1/2-HP Whisper Drive Belt...
Just installed new Chamberlain motor but makes loud snap when door opens and closes about 3 inches from ground?
Do you have a security system in your home? Sometimes the door shut sensors get out of alignment and the door strikes the sensor. This is the exact same problem I had with my door.
Nov 05, 2017 | Chamberlain 1/2-HP Whisper Drive Belt...
The motor runs but it only opens a few inches and slowly goes back down its a chamberlain whisper drive model HD900D
Hi. I have seen this before, although usually not from chamberlain garage door openers.
Pull the release cord that unlocks the door from the opener, and manually open the door ALL the way open.
Then lock back in place in the open position.
Then use automatic opener to shut door.
It will close very slowly, but should close all the way.
Then, open the door again using the remote, and the door will once again open slowly, this time it should open all the way.
Then close door with remote, and door should now close as it is supposed, with the proper speed.
The slow opening and shutting is the system position sensor resetting itself.
This is why your door is acting up.
I would also look up by the belt drive connects to the front of the garage door opening, to make sure there isn't any dirt, cobwebs, or other obstructions on the sensor that may cause it to re-close the way it does.
Jan 24, 2011 | Chamberlain 1/2-HP Whisper Drive Belt...
(Chamberlain 1/2 hp Whisper Drive garage door opener) the garage mounted opener will open the door, but none of the remotes now work. batteries have been changed already. Is there a way to reprogram the...
If the wall button will operate the door up but none of the devices do then look at the wall button. Find the lock button and push it for 2 seconds and then try the remotes again. This is your vacation lock. You can get a manual at chamberlain.com. Now if the door does not open or close with the remotes you can reprogram them. Press the colored learn button on the motor head and then press the button on the remote. Repeat for each remote. If they fail to program you will need a new logic board. Thanks BB
Aug 18, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Adjustment of a Chamberlain WD822KL
The opener is having a hard time operating the door. It sounds like the door is out of balance. The door should stay all the way up at half down and all the way down. You should be able to raise and lower the door by hand EASILY. The opener is only meant to lift10-15 lbs. Thanks BB
Apr 08, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Hi there. I have a Chamberlain Whisper Drive
I just had that problem this morning and the cause was that the springs that help hold the weight of the garage door were broken. This caused the garage door opener to raise the garage door a fe inches and then drop again. We called in a professional and $200 later we had new springs and everything works fine now.
Nov 07, 2009 | Chamberlain 1/2-HP Whisper Drive Belt...
Belt Noise for Chamberlain HD600 1/2 HP Whisper Drive Garage Door Opener
You could always use "Belt Ease" from an Auto Parts store. It's made for squeeky belts.
-Lonnie
Jul 29, 2008 | Electrical Supplies
Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System Logo
1,105 people viewed this question
Top Chamberlain Building Materials Experts
Joseph Hoffmann
liveone15
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
