Question about Kenmore 14.8 cu. ft. / 419 liter Chest Freezer 11531
Compressor Stops on Kenmore Chest Freezer
Model 253.8193616 will not start by itself but if I tap it real good beside the temp control knob and call it by it's right name, the compressor starts right up again. I do this twice a day but I want to leave the house for a couple of days....is there a part I can replace? Although the unit is 16 years old, it looks new and is worth saving. Please help.
  • 770 Answers
The thermostat needs to be replaced part # 216230400 it is $59.51 at www.sears.com (parts) or it is $52.45 at www.apdepot.com this will fix ya.... both will ship direct to you. If you have to leave you can unplug unit and jumper out the thermostat 2 wires plug back in. This will make the unit run 24/7 until you get the part but it is better than losing the food
Posted on Feb 12, 2008
  • 883 Answers
Sounds like the temp control has begun to acquire oxidation on the contacts inside of it. When you tap near it, there is just enough impulse vibration for the spring-loaded contact points to help the electricity to find a path through the oxidation. If you feel strong one day, take it apart and polish the metal contacts to remove the oxidation. Then re-assemble it and re-connect the wires. Should be good as new again. Second option...replace the control dial unit. Most contact points in electronics are designed to have a "wiping" effect when they are actuated thus removing any oxidation from the mating surfaces.
How tofind out if your chest freezer is stuck onn defrost mode
If its in defrost mode it will get warm and the frost will melt. People usually just unplug them. Tge compressor usually has a switch or temp knob. It may be in back by the compressor underneaith. There would be an indicator as to the temp.setting on it. It may not have one at all and may have another issue.
Jun 23, 2014 | Kenmore 8.8 cu. ft. / 249 liter Chest...
I have a kenmore chest freezer model 19502/19702. I had it unpluged for 5 months. When I plugede it back in the power light flickers. Tryed other outlet. Other then that it seems to be working
We purchased this same Kenmore chest freezer model 19502/19702 in 2010. In less than 2 years the compressor quit. If you do a search on this model you will see dozens of complaints. Don't waste your time or money on this freezer.
Apr 16, 2012 | Kenmore Freezers
Start up current draw
Lock motor Amps ( LMA ) is the current draw when the compressor starts.This draw of current is less then 1sec.The amp amount shoud be on the compressor Name Plate.This amp draw is also the amps used when the compressor goes bad and locks up then the overload kicks out.
May 21, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
Just bought a used GE chest freezer model FH5DSAWH from friends. Brought it home plugged it in and it doesn't get cold. Can hear it running and the compressor gets hot. Any ideas? Was told it worked great....
your ptc overload relay on the compressor is bad,unplug it off the compressor and get a replacement at an appliance parts store,plug in the replacement and this will solve your problem
Apr 27, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
Kenmore Chest Freezer Model number 1987191852 has started to defrost own its own. Compressor starts and shuts down after appx 2 seconds. Has this unit reached the end? is it cost effective to repair?
Good day,
That short cycle you hear, is the compressor trying to start, and can't.
It is possible one of the start components has failed. Under a cover on the side of the compressor are either 3 or 2 components.
The start relay, the protective overload and on some models a start/run capacitor. These components can be removed by pulling them off of the pins of the compressor.
Most appliance parts houses will be glad to test them for you. Replace any that test bad.
If all test O.K. then it is an internal problem with the compressor itself, which would take the services of a trained tech and pretty pricey.
Apr 11, 2010 | Kenmore Freezers
Kenmore chest freezer does not stay below 30 degrees compressor runs but I don't see a fan to cool the compressor
If your chest freezer is less than 50 years old, it does not have a fan. Cooling coils contact inner walls of freezer compartment, warm coils dissipate heat through outside walls of freezer. If compressor runs, temp is 30+ degrees, gasket is OK, lid not left open, then you have one of two contions: 1. Low capacity compressor 2. Refrigerant leak. Solution to either is to replace freezer. (My opinion: Don't get a Kenmore brand, which generally ties you into poor warranty and slow and poor service.) No matter what brand name is on the freezer, it is most likely manufactured by Electrolux (in St. Cloud, MN) or Haier (from China). Look at the model / serial number plate before purchase to see where it was manufactured. Yes, the USA manufactured ones are better. (and I'm not just saying that because the plant is less than 15 miles from where I am sitting right now)
Jan 01, 2010 | Freezers
Freezer stops and start
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
Jun 03, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Believe it or not, but it is normal. Especially when just turned on. As the internal temp. gets colder so will the temp. on the side get cooler.
Apr 20, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Feb 19, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Kenmore 14.8 cu. ft. / 419 liter Chest Freezer 11531 Logo
307 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
