Question about Dryers
Our Maytag gas dryer will not heat up.
The dryer will tumble but the ignitor will not ignite the gas. I ahve already replaced the ignitor. What else be could be the problem?
  • 958 Answers
Check if there is voltage across the igniter. if there's no voltage, trace the diagram and you might stumble on a thermal fuse that is busted.also, check the gas solenoid. the ignitor could be heating up but if you dont have gas then there will be no ignition...
Posted on Feb 12, 2008
Tumbles but does not dry
When you put your wet cloths in the dryer close the door. You should then turn on the dry cycle you wish, not the fluff option as there will be only air and gas dryer will not heat the cloths. Wait 30 ~ seconds after the dryer is turned on and listen for the gas to ignite and begin warming and drying the cloths. If you hear no bump sound like the ignition of the gas, then you have an ignition issue. It will require replacing the ignitor. All the best and good luck. Hope this helped.
Oct 02, 2012 | Maytag Neptune MDG5500AW Gas Dryer
Brand new dryer won't heat. Tumbles fine - but no heat. Maytag 2000 series. I already checked the breaker - no problem
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 27, 2011 | Dryers
GE Dryer DDG7580B does not heat. vents are clear, dryer tumbles, just no gas ignition. Other gas appliances working well. Help!
Replace the ceramic ignitor WE4X444. An easy fix. Nut is on the gas valve (not the line) to remove the burner assembly to replace the ignitor.
Good luck..
Jan 31, 2010 | GE Dryers
Maytag MCG8000AWW gas dryer no heat
The ignitor may be bad you can chek to see if there is 110volts when the dryer is allin by unplugging the wire to the ignitor and putting using a multimeter to chek for voltage at the wires. If there is power to the ignitor and the ignitor is not glowing up then the ignitor is probably bad replace the ignitor.
Jan 12, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Dryer tumbles but no heat
I believe this unit has a hot-surface ignitor, and they work great, but do go bad eventually. The easy way to tell is to visibly see if the ignitor is operating during startup... can you get to it?
The hot-surface ignitor is easy to replace- (be careful not to touch it with fingers - like with halogen bulbs)
Dec 15, 2009 | Dryers
My dryr tumbles but does not dry
Gas dryer? First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.  If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Electric dryer? Temperature sensor has failed or heating element has burned out.
May 30, 2009 | Whirlpool Dryers
Stops heatinng
Hi, first thing to check is the venting. If the vent is plugged, it will cause the heat to short cycle.
If later in the cycle, the ignitor glows but will not ignite the gas, you will need to change the coils on top the gas valve. This is a common problem.
Please let me know if I can assist you further.
Thanks
Vic
May 24, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Gas Dryer not heating
Check the thermal fuse on the heat vent canister.
Check the glow bar ignitor on the gas valve.
Mar 03, 2009 | Maytag Dryers
No heat
Is the ignitor glowing? There is a flame sesor on the burner assembly if it is open you will not get any power to the ignitor to lite the gas.
Apr 24, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
229 people viewed this question
Top Dryers Experts
Marvin
Marvin
