Question about SanDisk Sansa e200 MP3 Player
Stops playing after one song
I'm sure i'm making a simple error but when i try to play a playlist it stops after the first song. any help would be appreciated. thanks kevin
  • kevyoung Feb 14, 2008
    Dear painofun. I did download a lot at once. I ll delete some of the lists and try redownloading to see if it helps. thanks.
    Scholar:
  • 99 Answers
Dear kevin,
When you downloaded the playlist, did you dl a bunch at one time?  If you did, an error could ve occured which affects the plyaing mode.
Posted on Feb 14, 2008
Beeping with f and e showing
BMP accepts the following options: -h, --help Show summary of options. -n, --session Select BMP/XMMS session (Default: 0). -r, --rew Skip backwards in playlist. -p, --play Start playing current playlist. -u, --pause Pause current song. -s, --stop Stop current song. -t, --play-pause Pause if playing, play otherwise. -f, --fwd Skip forward in playlist. -e, --enqueue Don't clear the playlist. -m, --show-main-window Show the main window. -v, --version Print version number and exit.
ford performance chip.
May 25, 2012 | Kitchen Ranges
I can't make my archos
be sure that you have already saved a list of song on your playlist. and for the pdf also make sure that there was a file that save on that location...
let me know
Aug 29, 2008 | Archos Audio Players & Recorders
Can't create playlists on my zen x fi
I tried some suggestions posted here, and after some testing, I can now give you step-by-step instructions to create a playlist on your Creative Zen.
First, you need to think of the NOW PLAYING list as the "selected songs to be added to a playlist".
So, to start clean, let's empty out the NOW PLAYING list as follows:
1) from the MUSIC menu, select NOW PLAYING
2) when a song is shown on-screen, click the context menu
3) select REMOVE ...
4) select REMOVE ALL
Now, the NOW PLAYING list is empty.
Now, you need to select (mark) the songs you want to add to your new playlist:
1) go to an individual song
2) click the context menu, and select ADD TO SELECTED
3) go to another desired song, and do step 2) again
4) repeat until done
Now, to create a NEW playlist, go to the MUSIC menu, then:
1) select NOW PLAYING
2) it will show you the first song that you selected
3) press the Right button, to scroll through all of the other songs you selected
4) when any song is shown on-screen, click the context menu
5) select SAVE AS PLAYLIST (this refers to ALL songs in your NOW PLAYING list)
6) type the name for your new playlist, and click checkmark
ALL of the songs in the NOW PLAYING list are now saved as your New playlist.
From the MUSIC menu, select PLAYLISTS. You will see the name of the playlist that you just created. When you select that playlist, you will see the list of songs you had selected.
Please note that these songs are still in your NOW PLAYING list also. To create a another New playlist, you will first need to empty out the NOW PLAYING list as you did above.
I hope that helps.
Enjoy!
Nov 30, 2008 | Creative Labs ZEN SLEEK MP3 Player
Philips GoGear SA3245 - Playlists Not Showing Up on Player
Have solved this problem on GoGear syncing with WMP 11 by going to options on the device itself, then go to the "settings" option, scroll down to "PC Connection Preferences", from here you will select the check box saying "MTP" then back out of options and connect your device and go back to your WMP 11 and drag your playlists to the syncing area and resync your device. You should then be able to see your playlists under the playlist option in music along with the "playlist on the go" playlist.
Hope this will help!
- Jared
Determan Technology LLC
Aug 31, 2008 | Philips GoGear SA3245/37 Digital Media...
Probelm with playlists
The Vista compatible software may work different, but I have mine set to Repeat OFF, and I have no problem with playlist play. Is it possible that the songs that you put on your playlist are in the wrong format? If they were streaming files, or DRM-encrypted WMA's, there may be issues with playback. Convert the songs in your playlists to mp3 format ON THE COMPUTER, and then delete the playlists that are not working OFF YOUR SANSA. And then re-add the playlists to your Sansa.
-Tha Mp3 Doctor
Jun 03, 2008 | SanDisk Sansa Clip MP3 Player
Removing random play setup
try menu then system.
i think that it is in there. I would go further, but am afraid it will do it to me. I too had that same problem. Good Luck
Jan 18, 2008 | Creative Labs ZEN V Plus MP3 Player
Remove random play
go back all the way in the menu till you get to the begining and select music library, then go back to play mode and select normal
Playing music on my ipod classic
I'm pretty sure you can't do this. At least, I haven't figured out how.
One thing you can do is make a playlist in itunes and drag several albums into it. Then your ipod can play the whole playlist. But this requires some forethought, since you have to set up the playlist on your computer.
Another thing you can do is create an on-the-go playlist right on your ipod. Here's how:
1. from the main menu, click music, then albums
2. scroll to the first album you want in your playlist
3. press and hold the center button until the highlight blinks. don't go into the album; you're pressing and holding on the name of the album
4. scroll to the next album you want in the playlist
5. repeat step 3 until you've got all the albums in your playlist that you want
Now, go to the main menu and press music, then playlists. Scroll all the way to the bottom and notice that you have a new playlist called on-the-go. If you go into it, you'll see that it has all the songs from all the albums you selected.
If you scroll past all the songs, you also have options to clear or permanently save the playlist.
Now you can play all those albums by selecting the playlist.
Again, it requires some setup, but it does enable you to play multiple albums without interruption. A nice side-effect of this method is that you can choose the order, whereas an automatic next album feature would play them in alphabetical order.
(FYI, you can add individual songs to an on-the-go playlist as well.)
And one final option: If you go to Music - albums - ALL, you can press play and it'll play your entire iPod in order. You can scroll to any song you want to start on, but you can't really scroll to the exact album you want to start on -- unless you know where to find the first song on that album.
I know that all three options are available in the latest iPod software. If something's not working for you, you may need to update your iPod's software through iTunes.
Jan 09, 2008 | Audio Players & Recorders
MP3 Player plays only 25 songs, capacity 1GB (861 MB)
Seems like a big problems you got there...
I reccomened re-formatting your drive to fat32 (for windows users) and giving it a second try.
I had the saem trouble a while back with my iPod Video 60gb and noticed that it was storing huge amounts of data that wasnt meant to be there. After the reformat it all worked again.
You also sure its not a full drive? because my Q-Be used to say "file error" on a full drive (vista bug)
---Give reformatting a go though.
Nov 03, 2007 | Audio Players & Recorders
Mp3 problems
Make sure that the mp3's that you upload in the phone are in the correct folder, moreover make sure that the folder itself is named correctly otherwise the phone won't recognize it and might just ignore.
Jun 14, 2006 | Motorola Mobility V710
SanDisk Sansa e200 MP3 Player Logo
52 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
