Question about Lexmark X5470 All-In-One InkJet Printer
Scanner I am unable to use the scanner. Press Scan Button .. Downloading Application List. Cannot retrieve application list.
  • Anonymous Feb 13, 2008
    same problem exactly - always used to work well...
This happened to me yesterday after recieving whatever lexmark update my computer downloaded. I restarted everything, computer and turned on/off fax and unplugged for a bit.
It seems to be working OK now.
I know that's lame dell-style, advice, but the restart worked for me.
Posted on Feb 14, 2008
Downloading application list - cant retreive application
If your pc tels you its downloading application, have a look a your printer drivers, your usb cable connecting your pc to printer and or the data cable inside the scanner might have gone faulty
Apr 18, 2013 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5650 cannot retrieve application list
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 16, 2012 | Lexmark X5650 All-in-One InkJet Printer
"Cannot retrieve Application List" Error message
plz install drivers of your printer first to your pc.
Mar 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
I am unable to scan. While in the Scan Mode, the message says "Downloading scan application list from your computer, please wait" The next message says "cannot retrieve scan application list from my...
the reason why the printer is giving you that error msg is because the all in one center is not communicating properly with the programs on your computer to your printer.
try to scan directly to your computer using the all in one center instead.
Jul 23, 2009 | Dell 966 All-In-One InkJet Printer
Lexmark x5470
is this scanner plugged into a power strip by chance.plug it directly into the wall power
Oct 05, 2008 | Office Equipment & Supplies
Scanner
Reinstall the software/drivers and try again.
May 23, 2008 | Lexmark X3550 All-In-One Printer
Lexmark X5470 scanner problem
i had the same problem but if you open the Lexmark All-In-One center (can be found in start --> all programs --> lexmark 5400 series --> all-in-one center) and select scan (it will work)
if you dont have the program installed find your installation disk and when u re-install it, it should come up again
SH33P
Feb 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
499 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
