Floopy drive when i put a 3.5 disk in drive keeps asking me to format it, these are all proven disks recently used?
  • cmrgfmt Nov 09, 2008
    When I connect the drive It will not read any of the disks that I have been using with other comparable computers. I kept being asked if I want to format the disk. When I reformat, it starts and then says that it can not complete the format. I have tried many different disks (they all work on other computers). I have also had the supplier send out a new drive. The problem is the same with the new drive. I have used the drives on 2 different computers and had the same problem with each. HELP!
  • HoJo-Fxr Nov 13, 2008
    I have the same trouble but with a different genaric older drive, I copied the data off the disc's and reformated. The disc's worked for a week then wanted to be reformated. The disc's read fine on other PC's, so I am replacing the Floppy drive with a new one. Could you have a virus that is messing with your drive?
    Scholar:
  • 95 Answers
Sounds like you have a bad floppy drive. If you are unable to read a disk and it wants to format it so it can read it try letting it format a floppy with no data on it or with floppy you don't care about. If it can format and you can read and write to it, then bad disks. If not then you know you have a bad floppy drive. Replace and enjoy.
Posted on Feb 12, 2008
I loaded a number of files awhile ago on my ex hard drive. Now when I try to see it or retrieve it my computer keeps telling me I have to format the disk in drive F before I can use it. If I format now,...
Try going to contol panel then administrative tools. In the window that opens look at the left window pane for disk management click on it. You should see the disk that says you need to format it, Compare file systems your c drive and the disk you can't read. (Fat32, NTFS, Fat) Right click on the disk that's giving you problems and see if Vista will let you mount the drive. If it won't you should put the drive in a portable enclosure and use a Windows 7 PC to Burn your files to disc. Vista is extremely unstable If you can load Windows 7 your problem will go away and you'll have a way better OS!
Jan 03, 2018 | Iomega Computers & Internet
I recently had my Gateway ML6721 freeze up and was asking to insert OEM supplied disk for repair. Repair didn't work was looking for missing drivers. Attempted several times to do a repair with no success...
You don't ! Get the model of your hard drive and go to the manafacturers Web Site. There you will probably find a sofware utility that will format and partition the disc for you. No other Computer ? Use a Friends !
Aug 24, 2009 | Computers & Internet
My segate 300Gb HDD keeps asking to format it when i recently pluged it into a new computer to transfer data to and it said that the driver didnt install correctly. since then it keeps asking to forma
I'm assuming that this was functioning at one point. If you are using Windows, Right click on my computer and click "Manage" Then go to disk management? Does it see the drive at all. If so, has a letter been assigned? It is possible that the operating system will show the drive even if it can't read the data. Look to see what file system and how it sees the disk having been partitioned. It is possible that your partition table has been corrupted. This can possibly be fixed using a tool like disk doctor or fdisk.
If, on the other hand, the drive is also making funny noises, you may have a mechanical failure on the drive.
May 29, 2009 | Seagate 300GB USB 2.0/FireWire Hard Drive...
Solaris 9 SPARC doesn't work with Maxoptix T4-2600 disks
You must using solaris format utility to label thies T4-2600 drive. And you must put 512byte/sector MO disk into drive. for example:
1.$ su - root ;Become root user
2. # format ; identified disk
3. choose disk
4. label disk
5. if type unknow please input : type
6. choose T4-2600
7. label
8. modify disk partition
9. newfs ; ex: newfs /dev/dsk/c1t0d0s0
10. mount disk
11. using MO disk like HDD
Mar 26, 2009 | Computers & Internet
Problems during formating
You have to chose the driver for your operating system and create a floly disk with it.
To create a floppy disk boot with your motherboard CD and chose the option to create floppy disk (WINXP)
If you are using windows Vista you can directly chose drivers form CD.
Jan 14, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Dell l400 problem
1.If you purchase an external USB CD drive you will not need to use your floppy discs for booting. 2. You can connect a USB CD drive to your system. 3. Your system will recognize any device plugged into your USB drive. 4. There is no CD drive available for internal installation in your computer. 5. With the USB CD drive plugged in and the windows installation disc inserted, your computer should take you through the setup program automatically.
Nov 10, 2008 | Dell Latitude L400 (220-3575) PC Notebook
Using windows dvd maker vista with sp1 starts to burn then at about 98% get error message and stops the burn. also when i try to format a dvd disc ready to burn that wont work and the dvd drive d is...
two things. Firsly make sure that you are using the correct disks i.e if your drive is dvd-r then only use dvd-r disks, if its dvd+r then only use dvd+r disks if it is a multi drive then it won't matter what disks you use. Secondly don't format the disk first. If it asks you to format the disk click on the X to shut the pop up box. Only put the disk in when dvd maker asks for you to insert a disk.
Oct 22, 2008 | Computers & Internet
UNABLE TO READ A NEW, UNUSED FLOOPY DISK THAT I PUT NEW INFORMATION ONTO. THE ERROR, AS I CALL IT ASK ME IF I WISH TO FORMAT THE FLOPPY. IT REFUSES TO READ THE FLOPPY DISK WHICH HAS MY INCOME TAX INFO...
The disk may have unrecoverable formatting errors making it useless. Or your hardware could be on the failure.
If you absolutely must , try purchasing or borrowing an external floppy drive and try to save the information to the disk on the external drive. If if formats and works then you know your internal floppy drive is bad.
If it has the same problems as formatting it in your internal drive, then the floppy itself is bad.
If I may suggest , in the future it would be wiser to save all your data to a removable USB Flash Drive. They are very very inexpensive and cost a lot less then a box of floppies :)
Aug 17, 2008 | Computers & Internet
Floopy disk
Hi
Regarding configuring flopy drive for desktop please check these things
The wire on the ribbon cable with the red stripe is the pin 1 end and there should be a mark on the floppy drive as well marking the pin 1 end. Sometimes a little arrow or triangle point at pin1 sometimes stenciled with a number.
Regards
Balisonu79
Feb 14, 2008 | HP External floppy disk drive cable...
Computers & Internet Logo
780 people viewed this question
Alun Cox
David Payne
David Payne
