Question about Foxconn P4M800P7MA-RS2 Motherboard
Ddr2 ignored my motherboard supports DDR 400 and DDR2 533... have 2 slots each. I used a DDR1 256MB pc400 ram. I bought two DDR2 512MB pc 533 and installed in my pc (of course I removed my DDR1 256Mb pc400 ram). My problem is that, after after a minute or two, my computer hangs. I wonder why because my motherbaord supports DDR2 533. What shall i do to fix it? I want my DDR2 to be used in my pc.
What mobo you,re using.go to update ur bios,if can,t try install 1 stick only.
Posted on May 08, 2008
The size of the ram is not enough, try increase the size of the ram.
uzowuanya
e-mail: uzowuanya@yahoo.ca
Posted on Feb 16, 2008
Can I use DDR2 in an Acer Aspire T135?
The e RAM specifications for your Acer are -
Memory - DDR 266/333/400 expandable up to 2GB
Jun 11, 2011 | Acer Computers & Internet
My EPoX 4PDA5 has 2 512mb ddr ram's, I was wondering if i could replace them with 1gb ddr2 or ddr3 without changing the motherboard, or would i be able to get 2 1gb DDR's and still use the 512's? because...
From http://www.motherboard.cz/mb/epox/EP-4PDA5.htm:
4 DDR modules for DDR 333/400 dual channel architecture
If you have 4 ram slots and only 2 are filled, you just need to match the speed of the two you currently have, they can be any size(500mb, 1gb, etc). I'm not sure you'll be able to find DDR ram anymore though.. and NO you cannot use DDR2 ram.
Jan 12, 2018 | EPoX EP-4PDA5 Plus Motherboard
Problem With ddr2 (Upgrade From ddr 512mb 400 to ddr2 1gb 800)
If it works fine with one stick of ram. Then it is the ram that is incompatible. You can try different settings but you may end up that the stick isn't compatible. Hope this helps let me know if you have any other questions.
Thank you,
Lee
Nov 05, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
Asus p5 vdc-x motherboard not recognizing ddr2
Ok i am just guessing here
maybe your motherboard does not support
ddr2 rams and hence it wont boot up as it does not detect any ram in the slots......
try to boot with one old and one new ram (ddr and ddr2) and post the result
are you sure whether the ddr2 ram is supported?
Jun 30, 2009 | ASUS P5VDC-X Motherboard
RAM memory expand modules
sir..thanks for more information abut your unit..the best memory u need is 1gig DDR1 or (X2)times two 512Mb DDR1 PC400 memory..Thanks and Good Luck...^_^..Have a nice Day Sir..
May 17, 2009 | Compaq D51C PC Desktop
Can i upgrade RAM from 533MHZ to 667MHZ for P4M800P7MA?
Please try to upgrade your BIOS, it may solve the issue.
Jan 14, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
Asrock K7VM2 Motherboard Memory Upgrade
Some MOBO support different type of memory modules like ddr 400, 333,533 and other, if your computer is working fine with that PC400 it only means that your MOBO is compatible with it. Since you're planning to upgrade the memory just get another PC400 because the memory should be the same to work fine.
Jun 06, 2008 | Asrock K7VM2 Motherboard
Please help me in my RAM
Hi hope13,
you had it correct the first time. The DDR2 533MHz memory should be in the Blue slots. When using two DIMMS the motherboard requires the DDR2 533MHz memory be of the same size, brand & speed. For you to get a blue screen has nothing to do with you're memory. If there was a problem with you're memory, you bios would let you know by beeping a series of repeating beeps. Blue screens are usually caused by software & some hardware like you're hard drive. If you have data on you're hard drive & you do not want to erase it by re-installing windows fresh (That includes a must format), than I can suggest you download this software from this site. Click on the link.
http://www.ultimatebootcd.com/ Read what the software can do for you. If you do not want the software. Than break out you're windows CD & load it into you're CD-ROM drive. Boot the PC to the CD-ROM drive & in-stall windows. You're PC will function again when you finish installing windows & you're motherboard driver cd.
Good Luck!
I would have posted sooner but I though another was answering you're question.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 14, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
If your PC boots up successfully and load windows then its mean that RAM is working fine... There is some problem with OS settings.. So at XP booting press F8 for start-up menu and select Last known good configuration... Hope it will work...
Please Rate .... Thanks.
May 14, 2008 | Intel Motherboard
Which RAM supports
hi!good pm...hope this will help...
check your RAM,look for stickers that indicates your memory speed & capacity (e.g. 512MB PC400 DDR)...if there's no sticker description count the pin,a DDR has a 184-pin DIMM...
googdluck!
Feb 07, 2008 | ASUS P4GE-MX Motherboard
Foxconn P4M800P7MA-RS2 Motherboard Logo
199 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
