The ADF on my HP laserjet 3380 skews the paper to the right while pulling it into the machine. I am confident that it is not a software issue. I am hoping to replace individual parts, not the entire ADF.
It sounds like the rollers need to be cleaned in your ADF. Please make sure there isn't any torn paper or labels in the path of the ADF. Try qtips and some water to clean rollers. If you have roller cleaner that would be great or 91% alcohol but be very careful with the alcohol. DO NOT use anything below 91% because it can cause damage to the rollers. If this does not work you will need to replace the rollers in the ADF. Good luck.
Please follow the instructions for clearing the paper jam outlined in this article from the HP online support site. Here's another link with info on the manual feed in case you need it, and the home page for your printer in the event that a manual would help.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam
ISSUE:
How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam
SOLUTION:
Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
Open the ADF cover plate.
Remove any jammed media with care.Take out the page gently.
NOTE:
Take care not to tear the paper.
Close the ADF cover plate.
Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
NOTE:
Check whether all packaging straps inside the ADF are removed.
Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside.
Lift the green handle, and rotate the paper picker until it is opened.
Gently remove the page without tearing it.If you feel resistance, go to the next step.
Open the ADF cover plate, and loosen the media gently with both hands.
When the media are stopped, pull the media out gently along the shown direction.
Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055).
Pull down the green handle.
Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur.
hii..
is u 3380 fuser fixing film ok...if ok try to change presure roller..it below fixing film....you can take out the fixing firm or presure roller.just check the size only.if same u can combine it.
2.try to clean paper pick roller at 3380 printer..
If it is from the adf which is on the top then there is a small piece of paper stuck in the back. open the lid and you will find a plastic holder in the back. This helps the paper turn through the adf. Usally the paper is in there or this is out of positions which will cause this.
First try reseting the unit by holding the * key and the enter button and the same time turn it on until it starts beeping. This will rest the machine. If this does not work. you need ADF rollers the can be purchased for 20 to 25 bucks
