Question about Bose Acoustic Wave music system II - Graphite Gray Shelf System
No light in display
Impossible to determine station frequency when display is out. Any way to fix this at home?
  • 20 Answers
When the display is out? Does the backlight ever come on? If so, then there is no way to change this. If the backlight doesn't come on, contact Bose for service.
Posted on Dec 11, 2008
How to program the radio in a 96Lincoln continental after battery was disconnected
Here is the link to the owners manual which you can download if you wish:
http://owner.ford.com/servlet/ContentServer?pagename=Owner/Page/OwnerGuidePage&year=1996&make=Lincoln&model=Continental
Here/below are the specific instructions on the radio programming (pg. 159 of above link).
Good luck & please flag if "HELPFUL". Thanks!
(from section) Luxury Audio System
Selecting the AM or FM frequency band
Push the "AM" or "FM1/FM2" button to select the desired frequency band. Pushing the "FM1/FM2" button more than once will alternate between FM1 and FM2. These functions are used with the station memory buttons described under How to tune radio stations.
HOW to tune radio stations
There are four ways for you to tune in a particular station. You can use the "TUNE", "SEEK", 'SCAN"or memory buttons.
• Using the "TUNE" function:
You can change the frequency up or down one increment at a time by Pressing and releasing either the left (< arrow/up) or - right (> arrow/down) side of the "TUNE" or "TUNE DISCS" button. To change frequencies quickly, press and hold down either the right or left side of the button.
Manual tuning adjusts your radio to any allowable broadcast frequency, whether or not a station is present on that frequency. (See All About Radio Frequencies in this section.)
• Using the "SEEK" function
: Press the right *) side of the "SEEK" button to select the next listenable station up the frequency band. Press the left (.4) side of the button to select the next listenable station down the frequency band. By holding the button down, listenable stations can be passed over to reach the desired station. Pressing the "SCAN" button will begin the scan mode up the frequency band, stopping on each listenable station for approximately five seconds. To stop the scan mode on the presently sampled station, press the "SCAN" button again.
Setting the station MEMORY PRESET buttons
: Your radio is equipped with 6 station memory buttons. These buttons can be used to select up to 6 preset AM stations and 12 FM stations (6 in FMI and 6 in FM2)
1. Select a band, then select a frequency.
2. Press one of the memory buttons and hold until the sound returns and the lamp above the memory button lights up. That
memory button is now set.
3. Follow the above steps for each memory preset button.
NOTE:
Custom memory presets can be recalled using the keyless entry system. See Memory Profile System in the Features chapter.
Using the Automatic Memory Store feature ("AUTOSET")
: If the memory buttons have been set, either by using the Auto Memory Load feature or if you have set them manually, the system is prepared tolet you use a convenient feature called Automatic Memory Store.
With Auto Memory Store, you can continually set strong stations into your memory buttons without losing your originally set stations. Your radio will automatically set your memory buttons to the strong local stations.
Activate Auto Memory Store by pushing the "AUTOSET" button once. Your radio will set the first six strong stations of the band you are in (AM, FMI or FM2) into the memory buttons. The display will flash "AUTO" and display the autoset icon "A" while the stations are being set in the memory buttons.
NOTE: If there are less than six strong stations in the frequency band, the remaining unfilled buttons will store the last strong station detected on the band. After all stations have been filled, the radio will begin playing the station stored on memory button 1.
To deactivate the Auto Memory Store mode and return to the manually-set memory button stations, simply push the "AUTOSET" button. Display will show "AUTO" then "OFF". The next time Auto Memory Store is activated on that band, the radio will store the next set of six strong stations.
Nov 23, 2014 | 1996 Lincoln Continental
Where there should be information displayed (such as frequency of fm station that is playing) segments of the display are lighting but are not readable characters.
As I may have stated before, 3 issues can occur cause this. The display microprocessor(computer) within your unit that drives the display, can be bad. The actual display may be bad, or the wires and connections between the two can be bad. For more information, please visit my website at audioserviceclinic.com. Thank you.
Sep 20, 2013 | Yamaha Rx V795a 5.1 Chan 425 Watt Home...
Technics ST C04L
1. Search strong FM stereo station. (Like 97.05Mhz instead of 97.00Mhz)
2. Turn off auto scan/FM mode.
3. Adjust the frequency to 97.00Mhz
4.Adjust the Filter T01 very gently (about 5 degrees clockwise) as to make the Quartz lock lamp light up.
5.Turn on auto scan/FM mode and check for FM stereo lamp
Oct 05, 2012 | Cars & Trucks
How do i preset my stations on my deh-p400ub? thanks in advance
Here's the relevant instructions out of the manual.
Storing and recalling broadcast frequencies You can easily store up to six broadcast frequencies for later recall. ! Six stations for each band can be stored in memory. 1 Press LIST. Preset screen is displayed. 2 Use MULTI-CONTROL to store the selected frequency in memory. Turn to change the preset number. Press and hold to store. # You can also store the frequency in memory by pushing and holding MULTI-CONTROL right. 3 Use MULTI-CONTROL to select the desired station. Turn to change the station. Press to select. # You can also change the station by pushing MULTI-CONTROL up or down. # To return to the ordinary display, press BAND/ESC or LIST. # If you do not operate the list within about 30 seconds, the display automatically returns to the ordinary display.
You can find the full manual here: http://www.pioneerelectronics.com/StaticFiles/PUSA/Files/DEHP4000UBOperationManual1019.pdf
Aug 20, 2011 | Pioneer DEH-P4000UB CD Player
How do you set stations and clock
1.Select the radio band and tune in a desired radio station you wish to store in the preset memory.
2 .Press and hold any one of the Preset buttons (1 through 6) for at least 2 seconds until the station frequency on the display blinks.
3. Press the Preset button into which you wish to store the station while the frequency display is blinking (within 5 seconds). The display stops blinking once the station has been memorized. The display shows the band, preset No. with a triangle (9) and station frequency memorized
http://vault.alpine-usa.com/products/documents/OM_CDM-7854.PDF is link to full manual
Mar 03, 2011 | Alpine CDE-7853
I need to know how to set pre set stations on this model
Here is the info, for a link to the user manual go here for all the functions
http://www.fixya.com/support/p920294-pioneer_deh_p4000ub_cd_player/manual-26899
Storing and recalling broadcast frequencies You can easily store up to six broadcast fre- quencies for later recall. ! Six stations for each band can be stored in memory. 1 Press LIST. Preset screen is displayed. 2 Use MULTI-CONTROL to store the se- lected frequency in memory. Turn to change the preset number. Press and hold to store. # You can also store the frequency in memory by pushing and holding MULTI-CONTROL right. 3 Use MULTI-CONTROL to select the de- sired station. Turn to change the station. Press to select. # You can also change the station by pushing MULTI-CONTROL up or down. # To return to the ordinary display, press BAND/ESC or LIST. # If you do not operate the list within about 30 seconds, the display automatically returns to the ordinary display
Sep 22, 2010 | Pioneer DEH-P4000UB CD Player
Radio without remote
Press Function button at front of unit until display shows Tuner, and press Preset + / Preset -
If you want to listen Non-Preset stations, press << / >> keys of remote to tune a station. That's the procedure.
If built-in remote in your mobile have above said << / >> keys, you can tune station frequency.
Nov 10, 2008 | Audio Players & Recorders
I am just having difficulties setting my presets on my new DEH-P4000UB. I know it is something minor I am either doing or not doing. Your help walking me through this would be deeply appreciated. ...
This is copied from the manual, hope it helps:
for later recall.
memory.
1 Press LIST.
hold to store.
station.
BAND/ESC or LIST.
ordinary display.
Nov 07, 2008 | Pioneer Car Audio & Video
Set frequancy
Mount your Roady 2 in your Truck .Make sure the power is on & the antenna is connected. The middle connection should be open. Push the menu button, you should see FM Frequency at the top.Push the scroll button(Top Right) and you should see FM station numbers. Scroll though the stations and pick a frequency that isnt being used in your area. Push the scroll button in to set the station. The display will show that number set 88.3 set for example. Set the FM Tuner in your truck to the same station. You should be go to go. Good Luck
Dec 18, 2007 | Delphi Roady2 SA10085 XM Radio Receiver...
Bose Acoustic Wave music system II - Graphite Gray Shelf System Logo
215 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
