Question about SanDisk Sansa e250 MP3 Player
Replacement Selector Button
I'm looking for a replacement selector button that is located in the middle of
the player. The old was must have popped off and was lost.
Can't find anywhere online to get one. Who did I need to contact go purchase new button?
  • Kat191 Feb 12, 2008
    Any suggestions as to where I would find a "bricked" sansa player or a place I simply buy that particular part?
  • 69 Answers
Ooh i guess you got some problems :p but if you search for bricked sansa player you may find one that you can pick parts off.. or maby fix :)
Posted on Feb 12, 2008
  • johan jollens
    johan jollens Feb 13, 2008
    well .. you got to ask someone in your area .. i live in sweden so i don´t know how it´s for you :(
How do i get to the nettrual safety switch in a 1999 pontiac grand prix
Park/Neutral Position Switch Replacement
Removal Procedure
  1. Apply the parking brake.
  2. Block the wheels.
  3. Place the vehicle is the Neutral position.
  4. Remove the throttle body air inlet duct. Refer to Air Cleaner Assembly Replacement in Engine Controls.
  5. Click to Enlarge
  6. Remove the automatic transaxle range selector cable.
  7. Click to Enlarge
  8. Remove the wiring harness connectors.
  9. Remove the automatic transaxle range selector lever. Refer to Automatic Transmission Range Selector Cable Lever Replacement .
  10. Click to Enlarge
  11. Remove the PNP switch mounting bolts.
  12. Remove the PNP switch.
Installation Procedure
Tool RequiredJ 41545 Park/Neutral Switch Alignment Tool
    Click to Enlarge
  1. Verify that the shift shaft in the Neutral position.
  2. ImportantDO NOT ROTATE A NEW PNP SWITCH. A new PNP switch is pinned in the Neutral position. If the bolt holes do not align with the mounting boss on the transaxle, verify that the shaft is in the Neutral position.
    Adjust the PNP switch if the new switch has been rotated and the pin is broken or if using an old PNP switch. Refer to Park/Neutral Position Switch Adjustment .
  3. Align the flats of the shift shaft to the flats in the PNP switch.
  4. Install the PNP switch to the mounting boss.
  5. Caution! Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  6. Install the PNP switch mounting bolts.
  7. Tighten
    Tighten the PNP switch mounting bolts to 25 N·m (18 lb ft).
  8. Install the automatic transaxle range selector lever. Refer to Automatic Transmission Range Selector Cable Lever Replacement .
  9. Click to Enlarge
  10. Install the wiring harness connectors.
  11. Click to Enlarge
  12. Install the automatic transaxle range selector cable.
  13. ImportantVerify that the engine starts only in the Park position or the Neutral position once the PNP switch is installed. Readjust the PNP switch and/or check the shifter and the automatic transaxle range selector lever if the engine starts in any other position. Refer to Park/Neutral Position Switch Adjustment and/or Automatic Transmission Range Selector Lever Cable Adjustment .
  14. Install the throttle body air inlet duct. Refer to Air Cleaner Assembly Replacement in Engine Controls.
  15. Remove the blocks from the wheels.
  16. Disengage the parking brake. Hope this helps, the page was read only so no pictures. Info is for 3.1L engine.
Jan 18, 2018 | Pontiac Cars & Trucks
The selector button no longer works on unit or remote...AU...CD...Tuner ...etc. WHY???
If the selector button on the unit AND the corresponding button on remote has no effect, then the problem lies with the digital circuit responsible for changing inputs and not the Remote or the selector knob on unit.. I am assuming that the other functions do work.
That puppy needs to be repaired unless you can live with the input that it is stuck on. U might try unplugging the unit for a while and then replugging it. On some newer models this "reboots" the electronics and restores operation
Jan 19, 2015 | Panasonic Sa-pt750 Multi 5 Dvd Player...
My device NWZ-B133F once is powered on, it displays boot error
This issue may occur if the portable player was formatted via Windows Explorer. Follow these steps to correct this issue:
NOTE: If the message you receive is Format OK? , select Cancel .
1. Connect the player to the computer.
2. Click Start and then click My Computer .
NOTE: If the Portable Device box appears, click Cancel .
3. In the My Computer window, under Other , double click the icon for your portable player.
4. In the My Computer [Name of your device] window, right click the Internal Storage icon and then click Format from the menu.
5. In the Format box, click OK .
6. In the Format Complete box, click OK .
7. Close the My Computer windows.
8. Disconnect the portable player from the computer.
9. If it is not on, press the power button to turn it on.
10. Press the selector button repeatedly until Settings is highlighted.
11. Press the Play / Pause button.
12. Press the selector button repeatedly until Format is highlighted.
13. Press the Play / Pause button.
14. Press the selector button one time to highlight OK .
15. Press the Play / Pause button.
16. Once the player has finished setting up, Music Library will appear in the display and you can now use your portable player.
17. Test the player for proper functionality. If the error still occurs, reset the player by pressing the RESET button with a small pin or similar object.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required.
Thanks for using FixYa.
Apr 07, 2011 | Sony NWZB133F MP3 Player
My sony mp3(nwz-b133f) got boot error how to slve it
Apr 06, 2011 | Sony NWZB133F MP3 Player
My LG washer won't turn on. When I press the power button, you can here the power on jingle but the display does not turn on and when I turn the cycle selector nothing happens. This a fairly new washer a...
replace the main control unit under the inits top cover in the left rear top corner & inside the plastic cover if when you open the cover that protects the mainboard from water spray(if theres NO RED LED lit on the control board) then its the board that needs replacing,if it has the LED lit then run the diagnostics per the tech sheet located inside the machine and it will tell you whats actually wrong,next step is to replace the touch pad located around the selector knob on the front face of the unit
Jan 27, 2011 | LG WM2077CW Laundry XL Front Load...
How to set alarm and how to turn it off so that it is not used.
To turn on alarm, switch the selector lever to "Wake" and adjust the time shown. Then, switch the lever back to "Lock" and push the "Wake Mode" button until you see the selector dot (located on the bottom right of the time display) change to either the music or bell symbol; depending on how you'd like to be awaken.
To cancel the alarm, simply hit the "Cancel" button once, then press the "Wake Mode" button until the selector dot disappears.
Mar 10, 2009 | GE 7-4837 Clock Radio
Amana side-by-side icemaker buttons on door not working properly
I have an idea whats wrong but it amy be kinda hard to explain to you but here goes.
looking at the selector buttons does it look like the plastic overlay is cracked or worn from where you have made selections over time? what happens is when these selectors crack it causes teh switch to hange in one position. in your case it would most likely be the water button that is the worst culprit. the repair is very simple. you need to replace the overlay which is the sticker that labels the crushed/cubed ice and water. you can order this part through amana using your model and serial number, or post a good model and serial number here and I'll look up the part for you. thx peyton
Jan 28, 2009 | Amana ARS2464B Side by Side Refrigerator
Up & down push button not working
Repaired the same problem several months ago. The up/down control has a very small switch located under the button. The switch is part of the selector switch assembly that costs upwards of $100. However, the switch itself is available from Digi Key electronics part # P12321-SCT-ND at about $1.00 each, plus shipping. If you can handle the unit disassembly, which is extensive in this repair, and can solder very small switches, this is an inexpensive fix. I suggest you buy some spares. I'm looking for a seal replacement for this unit right now. Good luck.
Dec 02, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Ghost in the channel selector
the problems due to the microprocessor on the remote reciever present inside the tv .i think the remote is normal working. as the only problem with your iinfra red reciever microprocessor.microcontroler circuit. Replace the IC to solve this. Check electrolytic capacitor coupled to the memory block of the micro processor. Contact service if you are not well verse doing all this rectification works. it is off high risk and caution
thank you !
Nov 17, 2007 | RCA F36650 36" TV
SanDisk Sansa e250 MP3 Player Logo
160 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
