Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
Nothing Dishwasher won't do anything. No power or lights to LED display. Unplugged and plugged back in several times, checked breaker, and cheked GFI all test out ok.
  • 770 Answers
Have you check the door switch and for burnt off wire nuts in the electrical junction box?
Posted on Feb 12, 2008
I have a Proform 625 treadmill that I had to move. I unplugged the unit, slid it to where I needed it to go and plugged it back in. When I did so, the console powers on, but the display flickers and the...
You can try the following:
a. Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor
is plugged into a properly grounded outlet (see page 9). Use only a single-outlet surge suppressor
that meets all of the specifications described on page 9. Important: The treadmill is not compatible
with GFCI-equipped outlets.
b. After the power cord has been plugged in, make sure that the key is fully inserted into the console.
c. Check the circuit breaker located on the treadmill
near the power cord. If the switch protrudes as
shown, the circuit breaker has tripped. To reset the
circuit breaker, wait for five minutes and then press
the switch back in.
d. Check the on/off switch located on the treadmill near
the power cord. The switch must be in the on posi-
tion
Nov 25, 2013 | Proform 625 Front Roller Model Pftl62510
Elctrolux dishwasher won't start, display won't light and it randomly beeps
Check continuity of the 4 small wires that connect to the control panel to the control board. They seem to break where they flex for the door to open and close.
Jul 25, 2012 | Electrolux EWDW6505GS Fully Integrated...
The clean button blinks, yet it won't start?
I had the same flashing light problem first the normal wash flashing light then the others. I tried shuting of the breakers but nothing. I tried resetting the panel by pushing normal wash and heated dry simultaneously and nothing. So I took the six screws holding the front panel out and unplugged the ribbon type wires and plug and unplugged it several times to help make a better contact and I was able to get it to work right away. This may not work for all but I worked for me. It is very easy to do and it's worth a try if you're having the same problem. It took me less then 10 minutes. I had the problem for several days and could not use the dishwasher not mater what tried until I did what I described above. Now I have to see how long it lasts.
Jul 24, 2012 | Kenmore 24 in. 15689 Built-in Dishwasher
Asko D3530. Program LED does not come on. Also nothing happens when I push Set, Menu or Start. Tried button on the left (cirle with a I, looks like a reset button?). Checked plug, GFI and circuit breaker...
Welcome to FixYa.
It sounds like you've got a bad power switch or a wire at the power switch or as you described it... (circle with a I, looks like a reset button?) that's the power button, this will require removing the control panel, but I'd check the power at the dishwasher first though...
You'll need to check behind the kick plate at the bottom as opposed to just checking the GFI and circuit breaker. This is something I've seen fairly often with Asko dishwashers.
**Use caution when checking voltages with a live circuit. Turn off the breaker when servicing the unit otherwise...safety first**
If you have any reservations or aren't completely confident performing these tasks I suggest calling in a pro, sometimes the $100 or so is worth it.
You'll need a volt meter or multimeter to check for voltage as well as to look for burnt up connections at the terminal block/junction, it'll be pretty obvious if present. This will indicate a wire has been loose and burnt due to resistance, simply cutting it back and refastening it securely should solve the problem provided no further damage was done.
Let me know what you find and I'll try to assist you in any manner I can going forward.
Regards,
Macmarkus :)
Jan 28, 2011 | Asko 24 in. D3530FI Built-in Dishwasher
Dishwasher does not turn on. it is plugged in but
These are just some possible solutions that are worded for general assistance, I'm sure you have checked many of these things but others may not have;
The circuit breaker in the electrical panel may need to be reset. Hopefully it is labeled and will be easy to find without cycling power to everything else in the house.
The dishwasher may be on a GFI (ground fault interruption) circuit. The outlet may have a reset button on it that needs to be pushed or the circuit breaker in the electrical panel may have a built in GFI that needs to be reset.
Many dishwashers are installed with a light switch in the vicinity of the unit that is used as a disconnect. The light switch will cut power to the dishwasher if turner off. The switch is sometimes above the counter and sometimes below the sink.
There is also the possibility of a faulty On/Off button or dishwasher circuit board.
Dec 19, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
AEG Favorit 35085 vi trips electric every time
Simply things to check, you want to make sure your electrical connections are all tight, at the breaker (If your comfortable) and at the connection under the dishwasher. It's possible that the breaker may just simply be going bad. If you have a Amp meter you could run the Dishwasher and see how many amps the washer is pulling, and com pair the amount to the Name plate data where the model number is at, its usually listed in the same place.
Good Luck!
Nov 04, 2009 | Measuring Tools & Sensors
Whirlpool DU1100XTPS 9 Dishwasher acts as if no power
Is your dishwasher have a power cord and plugged into a wall outlet under the sink if the answer is yes then maybe the GFI outlet has tripped and all you need to do is reset the button on the outlet
Sep 22, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Whirlpool dishwasher du945PWPQ0 won't run, no led lights
If you have used a meter to check that the power circuit is live clear to the connection under the dishwasher then:
It is ~possible~ that (even though it is hard wired) a tripped GFI outlet in the kitchen has tripped and opened the circuit that this diswasher is connected to. Locate all GFI outlets in the house and reset them.
Seperate from that, you have a failed diswasher on your hands. If you have an extended waranty, well done. Otherwise, you need to decide between repair and replacement.
Mar 18, 2009 | Whirlpool 24 in. DU948PWPQ Built-in...
GFI 'shorted'
load neutral connects to the neutral binding screw on the GFI, do NOT connect the load neutral to the neutral bar.
Mar 05, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Dishwasher problem Model number GSD2200LO1
No, he didn't do anything wrong. Swithching to energy saver setting only prevents power from going to the heating element during the drying portion of the cycle. I suspect that you have no power going to the dishwasher. Check the household breaker for the dishwasher. If that is not tripped (probably not) then your dishwasher power may be supplied through a GFI (ground fault interupter) protected outlet which has tripped. Look around the kitchen for GFI recepticles, as there may be several. Power may even be fed from a GFI from another room, such as a bathroom. Push the reset on all GFI recepticles you can find. You can purchase a small pen sized tester for under $20 which will show if a wire is carrying power without even thouching an actual wire. Pick one up at a hardware store to help see if power is reaching your dishwasher if you need more help.
Sep 25, 2008 | GE Dishwashers
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
184 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
