Question about Sony PlayStation 2 (PS2) Console
Disk read error.
I have the thick on man. With only 8 screws on the back.
  • 86 Answers
You can try this sometimes it works .if it does not your laser is no good..if you are confident to pull the top off do this. .now take the cover of the dvd rom(laser ).you will see the laser ...if you can keep outer cover hooked up so you can hit the eject button to open draw..be very careful of the power supply..if you touch anything in there you can get electicuted..now see the laser it may have a plastic cover over it (depends on model)..the little round eye is the lense...get a cotton bud ,wet with your saliva gently lift up the lense (gently ) insert cotton bud under the top eye and clean around it..(gently)..dont force anything..when done reassemble and test .this sometimes works .a lot dont know that there are 2/lasers in these (keep to yourself )
Posted on Feb 12, 2008
HOW TO RESET THE ICE THICKNESS PROBE
If it's the one on the front of the evaporator, there is a screw that increases / decreases the thickness. Make sure all the plastics are in correct positions etc, first. turn screw in or out until the metal part of the sensor is 3/16" away from the front of the evaporator plate to give a 1/8" bridge.
Aug 25, 2012 | Manitowoc MAN-CVD2075 Condenser Unit...
Tip
PS3 Problems - Top 3 PS3 Repair GUides
Hi there
I am the Console Guru part of a six man team that repair PS3's - Xbox 360's and Wii's
I want to just make it clear to you, that you can repair the following probems at home with a good repair guide. There is no technical knowlage needed you simply do what you see on the step by step vids or the paper guide.
1.YLOD (yellow light of death)
2.Red/Green or blue Flashing lights
3.No display
4.Disk Read Error (Blue ray/DVD/Games)
5.Red/Pink/black and White screen of death
6.Hard drive corruption problems (you do not lose saved data)
7.Disk Stuck inside
8.Sync problems with controllers
9.Fuzzy Screen
10.Freeze ups and glitches
11.You also get the best tips on how to look after your PS3, also how to clean, Bonus material eg - how to install linux to your PS3 (PC on your PS3)
The best thing is you get to keep your PS3 guide for life so if somthing goes wrong in the future you can just review your guide and fix it.
THE TOP 3 PS3 REPAIR GUIDES
1. YLOD REPAIR WIZARD
2. PS3 LIGHTS FIX
3. PS3 FIXER
READ THE FULL REVIEWS ON ALL OF THE TOP 3 GUIDES
PS3 PROBLEMS - REVIEWS
PS3 Problems is a 3 man team including myself and we give you the full honest review of each guide, enjoy the read.
SO TO GET BACK TO GAMING TODAY!!!! - ITS DOWN TO YOU, THE TOOLS ARE ALL HERE.
on Jul 09, 2010 | Sony Playstation 3 (PS3) Console
My Boss br-8 keeps saying medium error. It's not reading any disc. It ask me to initialize disc that already have music on them.
If the disk had music that was not CREATED on the BR-8 you will get the error. The format is incompatible with computer formats.
If the files were created on the same BR-8, then you probably have a disk drive failure.
Try initializing a blank disk. If it will not, then you have a drive failure.
Also is it possible you are trying to read a 250Mb disk on a 100Mb drive? That won't work either.
Jul 25, 2010 | Boss Micro BR Digital Recorder
It says "Disk error" on any disk. It won't read disk
turn off and, unplug your DVD recorder remove the six screws holding on the top tilt the back of the top up disengage the front of the top and set it aside look for a small laser tag this will point to a 1/4 inch glass lense this is the laser taking rubbing alcohol on a q-tip gently clean the lense with a twirling circular motion
Apr 28, 2009 | RCA DRC8300N DVD Recorder/VCR
Toshiba 1370 Wrench and C7 error but, 0 & 8 and 89 did not help
Press 0 and 8 down before you turn on the machine, holding these down turn on copier, the display should say "ad" press 89 then start ( display will say 3 ) press 0 then start display goes back to "ad" turn off and on copier if wrench comes back take off red cover over hot section and in the middle there is a thermostat (1 screw) and toner build up under it needs to be removed.
Mar 03, 2009 | Toshiba 1370 Black and White Copier
My PS2 will only play a few games
It may be the laser is going bad or you just need to clean it. To do this, carefully take the 8 screws out of the bottom of the PS2 then remove the top cover. Take the 2 smal screws from the DVD drive cover and remove the cover. Clean the lens with alcohol and a q-tip or cotton ball then pat dry. Put the DVD drive cover back on and reinstall the case cover. This works especially if you are getting the "disc read error".
Dec 23, 2008 | Sony PlayStation 2 (PS2) Console
Disk read error
If other disks can be played then this problem is easily sovled, if your PS2 does not play any disks you may need a new reader, but this still might be able to solve it. If it is still under warranty, send it back to Sony and let them fix it. If not, then you will have to break the warranty seal on the back and open it up. You might just try cleaning the lens with alcohol and a cotton swab. You will need a small set of screwdrivers and a felt tip pen. First, take the case off, you will need to remove all 8 screws on the bottom in order to do so. Take the top of the case off, you will need to watch out for the front of the disk drive when doing this. After that, remove the lid to the disk drive. There are 4 screws near each of the corners that you will need to remove to do so. Lift the top off and then there are two screws on the left side(if the controller bay is facing towards you), you will need to remove these to get the disk drive out. Once the disk drive is removed, in older versions you will already be able to see the white dial that we need to alter, in newer versions there is a plate covering it, it is near the back of the console. Remove it and then mark the starting position of your white dial with your felt tip marker. Once you know where the starting position is, you can rotate it one movement at a time and then put the disk drive and covering back on, you will not need to replace the screws yet. After moving the dial one click, put the drive back in and put a CD in it. Since you are having problems with the blue disks, try one of those first, although this is the most difficult one to get working, but if it works, most if not all of the other disks should work. Put the top back on and plug it in, turn it on and hold the lid firmly but not to firmly onto it. If you are holding it too loose the disk will fly off, too tight and it will click. If this doesn't work, take it all apart and move the dial one more click. This is just trial and error until you finally get one to work. You will want to have a controller in so you can get to the browser menu so you don't have to wait for it to load the game and then turn it off. Once you get your console to read a blue disk, you might try the other style disks before putting it all back together. If you try every click on the dial and none of them work, you may need to purchase a new reader. After you find you PS2's working position, you can put all the screws back in and continue gaming. This is a common problem among the older versions of PS2's so don't worry if you do need a new reader. You can find new readers online and they are faily easy to replace, they cost somewhere between $50-$60. I hope this helps.
Mar 21, 2008 | Sony PlayStation 2 (PS2) Console
Playing recordable dvd
My Emerson won't play anything except DVD Movies, never has, wasn't suppose too. Make your movies in DVD Video format and it will read them fine (unless it's broke). I make movies all the time and play them back in mine. It reads DVD-R, DVD+R, and in duel layered. It will not read RW disks!
Man I've every problem you can imagine with DVD Players. I've found when the disk gets stuck, as long as it's not jammed. You can turn the unit off or unplug it. Plug it back in but DON'T TURN IT ON! Instead hit the eject button and the drive should open the drive without trying to read the disk.
Feb 24, 2008 | Emerson EWD7003 DVD Player
Disk read error.
hello is this a slim line or the thick...need to know this first befor i can let you know
Feb 11, 2008 | Sony PlayStation 2 (PS2) Console
Disk read problems
hello .this could be a laser problem .most of the blue discs are cd based .silver can be cd or dvd . do you know how to pull it apart .also what version is it .the waqy to tell is by model no,and the amount of screws in bottom case.8 or 10
Feb 09, 2008 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
21 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
