Question about Kenmore 63252 Microwave Oven
Just stopped working
I can input the power & time on the touchpad but when I press "start" it makes a slight crackling sound, then NOTHING!
  • 2 more comments
  • Janir Feb 12, 2008
    Is that easy to do, Dom? How can I tell if it is bad?
    THANK you for responding so fast!
    I'm going to wait for hubby to come home, I can't get it off the shelf enclosure by myself, it's too bulky. Thank you again & sorry for messing up your name, I misread it.
    Appreciate your help!
    Jan
  • Oreo-oreo Feb 16, 2008
    Kenmore 64282 where is the fuse I need to replace it?
  • bandnyoung Oct 07, 2008
    I have the same problem - but I went thru 2 fuses with no luck - each time I replaced the fuse & started it up, it crackled and popped. When I tried setting the clock it popped.
    Master:
    Sergeant:
  • 440 Answers
Cheak fuse inside ok
Posted on Feb 12, 2008
  • 1 more comment
  • nick helpap
    nick helpap Feb 12, 2008
    take side cover off or the cover and look wile its unpluged
  • nick helpap
    can u take reg pci card
  • nick helpap
    its ok lol if its just reg size case then any 5.1 sound blaster card will work ok
Is it normal for a microwave to make crackling noises when standing and not in use but plugged in ?
A microwave in standby mode should not crackle. There might be a slight humming sound from a transformer, but that should be all the noise it makes. You could have a transformer or control panel component that is failing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Oct 28, 2016 | In Microwave Ovens
The problem is that when I press the 'Start' button, nothing happens. The clock is working, the fan is working, but I cannot cook anything even after I have entered the time and the power level
If when you press the start button the turntable starts but no heat then magnetron is faulty otherwise if nothing happens then the touchpad itself is faulty.
Oct 10, 2013 | Samsung 1.8 Cu. Ft. Over-the-Range...
Microwave oven touch pad problem
The keypad very well could be worn from use and be working intermittently. Replacing the keypad (and the keypad face if it is a separate piece) is the most logical solution.
Aug 22, 2012 | GE Microwave Ovens
It stopped working what to do to start it
1. The touchpad and external mouse drivers should be able to work together. Just make sure that you have the touchpad enabled. To see if you have the touchpad enabled, hold the Fn key and press F9. The combination Fn-F9 locks and unlocks the touchpad. If pressing Fn-F9 once, twice, thrice does not seem to lock/unlock your touchpad.. then you might not have the Toshiba hotkeys working or enabled. So lets forget it and try step 2. If Fn-F9 solved your problem.. there you go !
Arrow The way it works is you have to keep holding Fn key and have to hit F9 once, that should lock the touchpad. Again if you keep holding Fn and hit F9 again, that should unlock it and so on..
2. Sometimes this solves the problem.. Do a power cycle of your computer.. i.e., unplug the AC.. take the battery out.. Plug the AC back in and try to turn computer ON with AC alone (i.e, leave the battery out and just start computer with AC power).. Once windows loads up and everything is fine, then turn system off. Unplug AC.. put battery back in.. Plug AC back in and restart computer.. All should be working now.. if not, keep reading..
3. Click on START>go to RUN>type devmgmt.msc
4. Now in the Device Manager, click on the + sign next to Mice and other pointing devices. Right click on each device listed under "Mice and other pointing devices" and Uninstall ALL the MOUSE Devices you see listed there..
attention Make sure you ONLY uninstall the Mouse devices and not ALL devices from Device Manager like your CD, Display etc.. Just uninstall the devices listed under Mice and Other pointing devices after you have clicked on the + sign to the left of it..
5.Install Drivers
6. In the page that came up saying Downloads ( All operating systems, All categories ), at the top drop the list Filter by Operating System and select Windows XP (I am assuming you have XP.. if you have another OS, select that instead).. then on the right of it, drop the list Filter by Category and select Touchpad.. then click on the button "Apply Filters"..
7. Now you just see two drivers listed..
09-30-2004 Toshiba Utility
Touchpad Toshiba Touchpad Enable/Disable Utility for Windows XP (v1.27.0.3; 09-24-2004; 5.34M)
06-15-2004 Driver
Touchpad Alps Touchpad Driver for Windows XP/2000 (v6.0.303.5; 05-26-2004; 2.43M)
Click on the Download link on the right.. Save them to your computer somewhere in a folder or desktop, where you can remember.. After the files are downloaded, double-click on the file.. Unzip.. then Run.. and it will install the driver..
8. Restart your computer.. Now the Touchpad should be working fine.. Try Fn-F9 combination.. i.e, keep holding Fn key and tap F9 once, twice to see if it locks/unlocks the touchpad..
Jun 29, 2011 | Microwave Ovens
Panasonic NN-SD277. Almost 3 years old. We pressed start, it went for about a second (may have made a sparking sound) and then it just lost all power. There is still power to microwave but no lights are...
We also have this same microwave. It is less than 3 years old. We've had nothing but problems since we purchased it. In November 2010, the microwave made a crackling sound and then BOOM! Nothing. I have been back and forth with Panasonic. I refuse to pay for the repair on an appliance that is less than 3 years old. It's ridiculous!
Anyway, the problem t is an issue with their inverters. Google it and you will find page after page of the same story.
Jan 21, 2011 | Panasonic Microwave Ovens
Starts when closing door
This is a list of possible causes. 1. Defective triac or relay 2. controller is confused (pull power cord for a minute and see if it resets) 3.Defective controller or touchpad.
Mar 02, 2010 | Microwave Ovens
Turned microwave on this morning ,sudden crackle,then nothing.
Sounds like something has shorted out-blown. Unless it is a very expensive model it won't be worth fixing and is not something you should attempt yourself anyway. If under guarantee then get it repaired via the guarantee arrangements. No harm in checking the plug is wired properly but as the light and timer are working it is very doubtful it is a connection problem. I think you need to buy a new microwave!
Oct 03, 2009 | Electrolux EMS2487X Convection Microwave...
GE XL 1800 touchpad motor sound
that sound comes from fan motor, please replace or service fan motor ..
Sep 25, 2007 | GE XL1800 1100 Watts Microwave Oven
Nothing happens when you press "Start"
PLEASE CHECK IF DOOR IS CLOSED PROPERLY THOSE HOOKS ON THE DOOR ACTIVATE SWITCHES ON THE INSIDE OF MWAVE OPEN COVER AND CHECK IF HOOKS ARE MAKING CONTACT WITH SWITCHES .COULD ALSO BE TOUCHPAD FAULT YOU WILNEED A TECH
May 09, 2007 | GE JE1540 Microwave Oven
Kenmore 63252 Microwave Oven Logo
122 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
