Question about LG 42LC2D 42 in. LCD HDTV
The tv sensor is not working on my 42" lg lcd hdtv
LG 42LC2D 42 IN. HDTV LCD TV SENSOR IS NOT WORKING.
  • 3 more comments
  • pump28kin Feb 24, 2009
    The remote works (took it in to shop and it actually turned all the LG TV's on and off). We were told that the sensor on the TV was not working. Is this a problem that can be fixed?
  • Anonymous Feb 27, 2009
    i.r. sensor on tv isn't working.
  • Andrew Davis May 11, 2010
    Is it the IR sensor or the component input sensor you are talking about ? please give symtoms and problem
  • darrylwerner Jun 09, 2012
    THIS WORKED!!!!!!! Saved me a service call and all the hassle that goes with it.
  • Christian Caron
    Christian Caron Jan 03, 2014
    Hi! Thanks for that. TV is working fine now
Believe it or not...THIS WORKS!!!!
 Look on the back of your set for an external remote jack. It should be the same size as a small headphone jack. If it has one, use a spare headphone plug or your headphones, and plug them in and out about 50 times. This will clean the tarnished contacts and make your remote sensor start working. Your remote sensor goes through a switch on this jack.
Posted on May 04, 2010
  • 6 more comments
  • Logicl77 Nov 10, 2010
    All, my LG 37LC2D TV just started displaying the same symptoms. I could not turn on the tv, change the channels or do any functions from the tv remote. Found the remote ir sensor jack and plugged in some headphones a bunch of times. IT WORKED!!!!
    Thanks for this fix. Even though I am a bit sad I don't have a reason to buy a bigger tv, lol.
  • urwright Nov 18, 2010
    I have a 44" Zenith LCD. I was told I need to get a new IR sensor. My remote works but then it stops after a few minutes and then comes back on. It goes on and off for first half hour, very frustrating!! I did go look for the headphone jack, but this model does not have one. There are audio jacks that are not the same size as the headphone jack. I did try that with a different jack, but it still not working correctly. Months back I did by a brand new remote, so I know it's not the remote. Do you have any other suggestions?? Thanks in advance.
  • OKEYDOKy May 12, 2011
    Thank you , Thank you!!!! I have a 32 inch LG and the remote stopped working. I used my mic plug-in to insert into the jack on the back of the TV. Then I reprogrammed the remote.
    IT WORKED!!!!!! I had just got off the phone with the repair shop and was getting ready to take it in when I saw this post.....Thanks, Again!!!!!!!!!!!!!!!!!!
  • allthumbsup Jul 10, 2011
    IT WORKS!
    Absolutly amazing! Such a hi tech solution, they should all be this simple - Thank You!
  • gano_doug
    gano_doug Feb 23, 2012
    Amazing... so simple but who would have thought to do it. It worked immediately for me! Thanks!!!
  • Daniel Garcia May 23, 2013
    IT WORKS!!! OMAZING!! THANK YOU!
  • Patrick Young Oct 03, 2013
    Stranger things in Heaven and Earth I guess.
  • Bert Scherer
    Bert Scherer Apr 24, 2014
    OMG it works Thank You
To fix this problem, like a previous user suggested, take a pair of headphones and turn the TV off manually, and then plug your headphones in and out of the remote jack 50 times. Your remote should now work. This sounds crazy, but works. I had my LG LCD 37 TV for 3 years and out of no where the remote stopped working, the remote itself still worked but the TV stopped accepting the signal. I tried everything to fix it and this was the only thing that worked. Thank you so much me6666666666 for the advise.
Posted on May 31, 2010
  • gano_doug
    AMAZING!!! I have been frustrated for weeks and tis worked immediately!
    THANKS!!!!!
HOLY **** THAT ACTUALLY WORKS!!! I DIDNT BELIVE IT AND TRIED ANYWAYS BECAUSE COULD FIND A SOLUTION THAT WORKS. THANKS YOU SOOOOOOMUCH!!!!
Posted on Oct 08, 2012
    Champion:
  • 208 Answers
Please clarify your problem.
Posted on Feb 12, 2008
    New Friend:
LG 42 PC3DV I had the Time Warner Cable Techician come out and could not figure what was wrong with the LG TV. I saw this online stuck a 3.5 earphone device into the remote in a few times and now all the remotes work!
Posted on Sep 04, 2014
    New Friend:
To bad.. i have an LG plasma 42pq 1000, and it doesnt have an external remote jacket.. it looks like the IR sensor repeats the last signal what was send, until you hold your hand in front of the sensor.. any suggestions?? pls??
Posted on Mar 23, 2014
    New Friend:
Same to me, it's working fine. Tanks for this information.
Posted on Jan 03, 2014
I have a 42lg-lcd30 and i try that simple trick and my tv is working now.thank you for those helpfull comments.
Posted on Dec 04, 2011
  • 718 Answers
First check to see if the TV is working properly by using the buttons on the TV.
Then if you can check the remote by trying it on a compatible set. Maybe try it at the store you bought the set. If it works then you have a bad infared unit on the TV. Infrared units can be replaced.
Posted on Mar 10, 2009
  • swab01 Nov 20, 2010
    Have a Zenith plasma TV and the remote quite working, tried the remote control on another tv and it worked so I knew it was a problem with the tv sensor. Had a repairman out and he replaced the sensor and PC board and it still did not work,reinstalled old board. The repairman said it was the big PC board and it was to expensive to replace. Paid for the service call.Neighbor then looked on the internet and found this post about remote control jack on the back of LG tv's and found out that my Zenith also had one. Cleaned the jack with a earbud plug and dialectric grease and now the remote works. Great post. Will call TV repairman and let him know about this fix.
PHILIPS UNIVERSAL CONTROL CODE
These are the universal remote set-up codes for LG TV: 0004 0050 0009 0005 0227 0338 0012 0057 0080 0156 Brand name of the remote control isn't a matter.
Sep 25, 2012 | LG 42LC2D 42 in. LCD HDTV
I'm trying to look at a movie from my phone I hooked the usb cord to the phone and tv. You can hear the movie but not see it
you need to bring your LG 42LC2D 42 in. HDTV LCD Television to tv technician the problem is on boad
Mar 03, 2011 | LG 42LC2D 42 in. LCD HDTV
Could somebody tell me if this TV will work in Argentina? LG - 42'' Class / 1080p / 120Hz / LCD HDTV Thanks
Yes,u buy this tv in the US?Argentina run on NTSC frequincies,the tv should work find.
Jun 08, 2010 | LG 42LC2D 42 in. LCD HDTV
Remote control not working on brand new series 4 42 inch samsung
Make sure the remote is set to operate your tv and not a cable box or accesory. It's in the menu
Jul 24, 2009 | LG 42LC2D 42 in. LCD HDTV
LG 42LC2D 42" HDTV LCD
Sounds like the front panel may have a short. thats where the buttons and IR sensor are. Check with partsstore.com about a price and availability on the component.
Feb 27, 2009 | LG 37LC7D 37 in. LCD HDTV
Supplying and replacing a LCD screen
i have spoke in the past to LG service and to buy an LCD screen actually costs more than a new tv.
Aug 18, 2008 | LG 42LC2D 42 in. LCD HDTV
LG 42LC2D 42 in. LCD HDTV Logo
5,852 people viewed this question
