Question about Hotpoint SY36 Style Line Stainless Steel Electric Single Oven
Hotpoint oven not heating up;broiler ok
Hotpoint oven not heating up although broiler works;older model# not readable
  • 398 Answers
The element is burned out, remove itand check it with a ohm meter. if it moves when you touch the leads to both sides its good if it don't its bad. ps i take them all the way out to check them. you must unplug the oven before repairs!
Posted on Jan 19, 2010
SOURCE:
Hotpoint 24in double electric wall oven 20RJ83D not heating, element is working
The thermostat for the upper element has gone bad. Needs to be replaced.
Apr 15, 2017 | Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
The oven is not heating up, its not even turning on. there's no gas or fire. the stovetop is working. what can be the problem.
Since you didn't include the model number, I cannot check for you to find what type igniter the oven uses but if neither broiler nor oven will turn on, it is probably one that uses an electrical spark that isn't happening. If the broiler works, it is a 'surface' igniter and the one servicing the oven has failed. There is no gas because the flow is blocked if no ignition is occurring. This is an important safety feature otherwise the oven would just fill with unburnt gas and finally explode.
Jun 17, 2011 | Hotpoint Ovens
My Hotpoint electric oven no longer heats up. The top oven works but not the main one. How can I fix this?
HI, seen this before with the ge/hotpoint elec. ovens i worked on when i did apartment maintenance. One could be a bad control switch(knob u turn to turn on oven).turn on broiler and see if it comes on,if it does not that could be it.If it comes on it u might have to replace lower element,but could still be control switch not working for that section.But it will one or the other.
Mar 12, 2011 | Hotpoint Ovens
Burners work, broiler works, oven does not
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Jan 12, 2011 | Hotpoint Ovens
Hotpoint oven model rgb745wea1ww oven doesn't light. Broiler and stove top work fine.
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 04, 2011 | Hotpoint Ovens
Oven and broiler isn't heating but the burners on top of stove work fine, what would this be?
It would likely be your igniter/glow plug.
There is also a limit switch or thermostat for that glow plug on some models which can go bad, but it is usually the igniter itself. Quite cheap to buy most of the time.
Mar 05, 2010 | Hotpoint SY21 Style Line Gas Single Oven
Hotpoint oven glowbar not working
My oven glowbar stopped working christmas morning. Yesterday we bought a whirlpool brand (igntr-oven #4342528) because it is twenty something dollars cheaper then GE. My husband installed it today. The only difference is you have to splice the wires (it comes with everthing you need) The first time he put it in it did not work because he had the wires backwards. He switched the wires and now its working fine.
My oven is two years old also.
Dec 27, 2008 | Ovens
MY HOTPOINT SELF CLEANING STOVE
how do I get my self cleaning to come on in my hotpoint stove
May 22, 2008 | Ovens
Hotpoint SY36 Style Line Stainless Steel Electric Single Oven Logo
471 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
Steve Allison
Steve Allison
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
