Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Error code 1 2
Had the blinking green light. Pressed Device and Menu and got the error code. Blinking green light stopped and then I pushed power. The TV is working. What is error 1 2?
  • Blacky81 Feb 12, 2008
    When I moved the TV down stairs maybe we jiggled something. It has had the blinking green light and has not worked for a year.
  • 145 Answers
I found this list of codes
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Posted on Feb 12, 2008
  • logan moneypenny
    logan moneypenny Feb 14, 2014
    what does lamp cover open mean
Howdo you fix an error message 5C00 on a Canon iP90 printer.
Try this to reset the error.
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Please rate this solution, thanks!
Mar 07, 2011 | Canon Office Equipment & Supplies
Green LIght Blinking
Does the led ever stop blinking? No ..well in that case generally this indicates a standby voltage problem...if all those voltages ok then the cuircit known as digital module is at fault. also make sure the lockout has not been activiated. i really dont think it could but to unlock hold menu button down for 10 seconds. After all that i believe it would be a bad digital module
Willie@fordtv.com
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
BLINKING GREEN LIGHT AND WILL NOT POWER UP
You can check the Error code by doing the following.
On the Front panel hold down the Device and Menu Button for 5 seconds. The LED light will then start flashing the first set of flashing lights is for the "1"5 part of the code it will then pause for about a half second and start the ones place 1"5". The code will repeat 5 times before going off.
The Error Codes: 12 - Normal Operation; 21 - X-Ray Protect; 22 - Short Protect; 23 - Loss of Horizontal Deflection; 24 - Loss of Vertical Deflection.
The problem may also be in the power supply when you first plug the device in check how many times the Led blinks if it blinks for just over a minute the power supply is working fine. If the Led blinks repeatedly and does not stop the DM is not running.
This is a link to the service manual for you TV,
http://www.service-manual.eu/model.php?id=2710
Mar 02, 2011 | Mitsubishi WS-65909 65" Rear Projection...
I have a mitsubishi ws-73711. I get a rapid flashing green light after unplugging and plugging back in. TV won't power up. I replaced the seven DM capacitors and the exact same thing is occuring. I am...
12 means no error. The device and menu buttons have to be pushed after unplugging and re-plugging for the error code operational check to work. If you have done that and if its still the same, then please tell me which LED is blinking so that I can help you. I remember your tv has 3 LEDs at the front.
Jan 08, 2011 | Mitsubishi Diamond WD-65831 65" Projection...
I have a canon iP90 printer and a code is coming up 5C00?
If it still comes up with this error there might be some paper down near the print heads. If there is no paper there, you might have an actual hardware issue.
Aug 29, 2009 | Office Equipment & Supplies
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Error 5100 canon ip90
You may try this to rest the 5100 error:
Dec 07, 2008 | Canon PIXMA iP90 InkJet Printer
I have a Mitsubishi WD-62525. This morning my TV would not turn on so I pressed the rest button. After the Timer light stopped blinking I pressed power. I could hear the fans start than a somewhat loud...
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Error Code Operational Check
Note:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
I need to know what the error codes 5100, and 5700 mean, and what causes those errors to come up on the screen. Thank you
Try resetting the printer:
Jun 20, 2008 | Canon PIXMA iP90 InkJet Printer
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
1,131 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
