Question about JVC FS-S77 System
Attaching other components
I misplaced the manual for my son's JVC FS-S77 and I was wondering if you could somehow use the tuner and speakers to amplify the sound from the TV when playing XBox 360. Any information would be helpful- thanks
Michelle
  • 145 Answers
If the unit has an auxillary input you can attach your device to it. If not you could by a transmitter to broadcast the audio and then tune it in with the stereo, although there will be quality loss and the transmitters are a bit pricey for what they do, generally less then $30
Posted on Feb 12, 2008
Jvc stereo tray error fs-s77
Model number is not correct. Give the JVC model number
Sep 15, 2013 | JVC AM FM CD DET FACE CAR STEREO
No sound from speakers, headphones work
check the setting you must have changed the setting and you must have set the system on microphone mod eon some products you have to set o options at atime however go through your manual guide.
Oct 30, 2010 | JVC FS-S77 System
My cd player says locked when i try ejecting the disc trays it is a jvc uxs77
on the one I have you hold down the stop button and the eject button at the same time to unlock but it is a diffrent model maybe it will work.
Oct 16, 2009 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
JVC UX S77 my 5 disc cd says "tray err". It won't open or play.
it sounds like the tray has come off the guides a comon problem with kids pushing the tray in rather than pressing the button. if the teeth on the track are ok then it is just a case of opening it up and putting the tray back
May 16, 2009 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
No sound coming from JVC FS-SD7
You burn out the audio amplifier IC you need to replace him
Mar 28, 2009 | JVC FS-SD7 CD Shelf System
Jvc protect
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Feb 28, 2009 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
CD player ate a CD!!
I fixed the same issue by forcibly pulling individual trays to their open position.  I removed the casing to gain better access (tons of screws) but you can probably gain clear access to the shelfs without removing the casing if you have good needlenose plyers.  I found a stuck CD within one of shelfs, wedged WITHIN the moving components of the shelf.  It works perfectly now.
Aug 01, 2008 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
Dvd player is locked
Ideas
1/ Turn power off for a while at powerpoint for as long as you want 5mins should be fine then turn on and try again.(which youve probably done already) as well as looking up your model number on the net to attain a info on your system.
Does the remote still work if so try to find unlock in menu/setting/functions but if it requires a digit code then youll need the manual as it could have an override built for cases such as yours.
start at jvc.com/dvd5.1 surround and find your model
good luck
Clapster
Jan 28, 2008 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
Tray error
I saw on another JVC systems manual that its an error message that shows when the tray isn't fully open due to an obstruction. If you can locate a manual eject button(usualy you'll need to insert some tip into it) it will help you eject the tray and look for any obstructions, anything looking out of the ordinary there. at least that way you'll be able to take your cds out... You can also try disconnecting the system from all power sources for a few days(including an internal battery), maybe the reset will jog it back to working order. If you're out of warranty and know your way around those things, try taking it apart, cleaning as much as you can, and look for anything out of the ordinary, like broken gears or pins, bent parts, a cog, etc. Good luck
Feb 12, 2006 | JVC FS-S77 System
JVC FS-S77 System Logo
89 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
