Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Error code 1 2
After the green blinking light. I pushed device and menu and got an error code of 1 2. Then I pushed the power button and the TV worked.
    President:
  • 4,402 Answers
If it does it again i would check for bad caps
Blinking Problem
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
Posted on Feb 12, 2008
I have a mitsubishi ws-73711. I get a rapid flashing green light after unplugging and plugging back in. TV won't power up. I replaced the seven DM capacitors and the exact same thing is occuring. I am...
12 means no error. The device and menu buttons have to be pushed after unplugging and re-plugging for the error code operational check to work. If you have done that and if its still the same, then please tell me which LED is blinking so that I can help you. I remember your tv has 3 LEDs at the front.
Jan 08, 2011 | Mitsubishi Diamond WD-65831 65" Projection...
I replaced the lamp however the green light blinks for a minute then the lamp light comes back on and the tv can't be turned on. WD-Y57 model
with that model after the tv shuts off pres the "menu" and "device" button on the front panel buttons together for about 8 seconds and then the power led will blink green. it will blink a certain number of times then pause and blink a different number of times this will be the error code for the fail that the tv thinks it is having. for example it may blink green 6 times then pause and blink 1 more time that would be code 61 check the code and repost and i will tell you the next course of action good luck
Jan 05, 2011 | Mitsubishi WD-Y57 57" Projection HDTV
Our WS-55313 Mitsubishi Projection screen tv was on then just died. When we push power button or remote on, the green power light comes on for a couple of seconds then the tv goes off .
do the self check this model has.
When green light goes off press and hold both the input and menu buttons for five seconds and release both buttons.
The power light will blink a two digit error code like, two blinks, two blinks, a pause and then repeat it several times.
let me know what the error code you find is and I will let you know what it means.
SD TECH
Dec 26, 2010 | Mitsubishi WS-55513 55" Rear Projection...
My 55313 mitsubishi just will not power on. green light comes on but then goes not off not ever producing a picture. ran error codes, none detected? what could be wrong? plz help
Hello.
Just in case if you have done it wrong.... To retrieve error code plug TV into wall outlet. Push power button, let it do whatever it does. After that push BOTH buttons in fron of TV named "Menu" and "Input" and hold it for at least 5-6 seconds.
Green LED in front of TV will start blinking error code (when it starts you can let buttons go).
If it clinks like "2 blinks, pause, 2blinks longer pause, repeat" most likely you have convergence issue. Two convergence amps have to be replaced along with couple PICO fuses that already open.
I would strongly recommend to let professional do this repair. As well in case of different error code.
Should cost you in ball park of $250-$300.
Regards.
Russ.
Dec 01, 2010 | Mitsubishi WS-55313 55" Rear Projection...
Power will not come on even after system reset. Pushed reset and LED flashes then after it stops flashing TV will still not turn on.
do self check: when it shuts off and power light goes off:
On front of set press and hold both menu and input (device) buttons for at least five seconds and release both buttons.
Power light will blink a two digit error code, like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code and I will assist you
SD TECH
Sep 24, 2010 | Mitsubishi WS-55513 55" Rear Projection...
I push power button and my 1080 series 42 in. mitsubishi big screen shuts right back off.
Most of these sets have a self check feature:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device”(device sometimes is called input) and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
Let me know what you find and I will tell you what it means.
If this information helped you rate this solution as I do this here for free.
SD TECH
Dec 14, 2009 | Mitsubishi Televison & Video
TV will not turn on. Push power button green
Try this and let me know what you find:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
If it is 2,2 I have START TO FINISH STEP BY STEP INSTRUCTIONS AND PHOTOS TO SHOW YOU WHERE THE FUSES & PROTECT RESISTORS FOR THEM ARE LOCATED.
The instructions tell you everything you will need for the repair and how to do it.
You can buy all the parts needed for less than 30 dollars on Ebay (I know the best seller there) I have repaired hundreds of these sets with this problem
If this information has helped you rate this solution as I do this here for free.
If you want the instructions & photos let me know and I will post them here for free.
SD TECH
Dec 09, 2009 | Mitsubishi WS-55809 55" Rear Projection...
I turn the tv. on , the green light comes on then
When you turn it on and it shuts off---ON THE FRONT OF THE SET PRESS AND HOLD BOTH THE MENU AND INPUT(DEVICE) BUTTONS TOGETHER FOR AT LEAST 5 SECONDS AND RELEASE BOTH BUTTONS.
Power light should blink a two digit error code---for example: 2 blinks, a pause and 2 blinks--This is the most common error code.
Let me know what error code you get and I will tell you what it means and if 2-2 what the problem is.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 12, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi ws-73711 turns on (I see a green power light) then off
press and hold 'device ' and 'menu' buttons on front of tv until the power light starts to blink out an error code . It will blink a few then pause and....repeat.. . Count the blinks. It is giving a two digit error code and repeating it 3 or 4 times. 22=low voltage short detected usually caused by the convergenge amp I.C. .12=normal
Oct 03, 2009 | Mitsubishi Diamond WD-65831 65" Projection...
Error code 1 2
I found this list of codes
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Feb 12, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
349 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
