Question about Metrologic Instruments Voyager MS9520 Handheld
Locked Metrologic MS9520-37 (keyboard wedge) after unintentional programming
After entering by error a random code from the Programming guide, page #68 (USB Interface Section) the device has stopped working normally. We don’t have the MX009 serial to USB cable.
Immediately upon power on the following sequence is repeated every two seconds:
  1. green led on, laser initiates scanning
  2. laser stops scanning & green led turns off
  3. red led turns on and single beep
  4. red led turns off
It doesn’t matter if there is or there is not any barcode. or surface in front the scanning window. It there is a barcode (programming or any other type which was recognized before this accident), it’s ignored.
This model has an IR sensor instead of a button.
The PC has difficulties receiving the keypresses from the PS/2 keyboard (which is connected through the scanner)
I will be very happy for any suggestion. Many thanks in advance for your time.
  • vorian Feb 12, 2008
    Sorry, the model is Metrologic MS9520-47 (keyboard wedge)
    Problem Solver:
  • 18 Answers
You programmed it for usb interface, but the scanner is keyboard wedge. Try pointing the scanner at the "recall defaults" barcode in the manual as you plug the scanner back in.
Posted on Apr 02, 2009
Metrologic ms9520 not scanning UPC's
Hello.
The issue is likely due to the programming (or the lack of) of the scan gun. It is entirely possible that the UPC bar code is not configured in your gun as a valid bar code.
You can remedy this by programming the scan gun to recognize the UPC bar code (and any other bar codes you may need to scan). Use the link below to download the programming guides for this scan gun.
http://www.honeywellaidc.com/en-US/Pages/Product.aspx?category=hand-held-barcode-scanner&cat=HSM&pid=9520/40
Hope this helps!
Dec 01, 2011 | Metrologic Instruments Voyager MS9520...
We are using a Metrologic MS9520 (keyboard wedge) with QuickBooks. It won't scan barcodes provided by Quickbooks, even though it's supposed to be compatible. We've downloaded about every driver, config,...
What I would first is to bring the barcode scanner back to factory defaults. To do this you will need the manual that came with the scanner, on the first page is a bar code that say "enter/exit configuration mode" scan that first and you will hear three beeps, then scan the bar code for "recall defaults" and rescan the bar code to "enter/exit configuration mode" then retry using your scanner, if this does not work bring up "notepad" on your computer and try to scan any bar code form any retail item. This should scan, if it does net then it could be a defective scanner. See page 2 on the manual link
http://www.posguys.com/download/voyagerprogramming.pdf
Nov 11, 2010 | Microsoft Metrologic MS9520 Voyager...
Ls9208 need to press enter after read
If you need to have a carriage return/enter after each bar code scanned, scan the following bar codes (from the Product Reference Guide) in order:
1. <SCAN OPTIONS> (on page 12-9) 2. <DATA> <SUFFIX> (on page 12-10) 3. Enter (on page 12-11)
Jun 16, 2010 | Symbol LS9208 Hands Free Barcode Scanner
I need to program a <tab>suffix character
Just go to page 8-6 and scan the "Enable Tab Suffix" Barcode that is 5th down from the top of the page. It took me awhile to figure it out too. Hope this helps someone since the question is a year old...
Jul 09, 2009 | Metrologic Instruments MS9535 VoyagerBT...
Incorrect Reading
Try experimenting with the different inter-scan code delays. You can find the programming barcodes in your manual.
Aug 20, 2008 | Metrologic Instruments Voyager MS9520...
Replaced battery - do I need to re-boot?
No you have to configure blutooth Adress, it's located on the bottem side of the scaner , scan that barcode and try to read, if it fall, get the user configuration gueid and enabel KBW OR USB ( first Chek Your communication method) if it's KBW trun to page 56 and scan Load keyboard Wedge Defaults , if it's usb trun to page 68 and scan enabel usb interface. if agein fall, scan the recall deafult and do the above steps.
mevan
MARC
Aug 04, 2008 | Metrologic Instruments Voyager BT MS9535...
I need an owners manual
You can download a manual (06656 User's Guide/Programming Guide) at the DataLogic site. They bought PSC in 2005.
http://www.scanning.datalogic.com/sitefiles/result.aspx?m=Product%20Manual&p=53XX&l=english&d=1&t=search&s=NonCurrent
If your cables are connected between your keyboard and PC, be sure to set up the correct Keyboard Wedge Parameters, beginning on Page 34, to allow connectivity.
I'd start by scannig barcodes "CE" and "ZA" to reset to default wedge values. If that doesn't work, I'd procede to sc an "CF" for PC=AT,PS/2.
Pages 36 & 37 address the Caps Lock issue, where the scanned value is in the wrong upper or lower case.
Have a nice day,
Label_Guy
Jun 12, 2008 | PSC Quickscan GP5385 Handheld
Metrologic 9520 help...Please
Is it 13 digit barcodes you are trying to scan?
Also, does the cable go straight into your till (straight cable) or is it connected to you keyboard via a wedge?
Jan 19, 2008 | Metrologic Instruments 9520 Voyager
Scanner blocks when scanning a bar-code
the metrologic scanner you are talking about has a barcode in the maual under the keyboard wedge section it is called stand alone keyboard this will cure your problem when you scan it. the reason being it fools the scanner into thinking there is a keyboard connected. hope this helps Pete
Aug 16, 2007 | Metrologic Instruments 9520 Voyager
Metrologic Keyboard Wedge Barcode Scanner (MS5145)
are you using usb keyboards if so set the scanners to stand alone keyboard wedge you will find this in the manual. if this is not the case it could be that the scanner is set for a different keyboard type just set the scanner for keyboard wedge emulation. hope this helps Pete
Aug 15, 2007 | Metrologic Instruments MS5145 Handheld
Metrologic Instruments Voyager MS9520 Handheld Logo
1,729 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
jackcity
jackcity
Level 1 Expert
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
