Lasko heater model 5620
When the unit is plugged in the caution light on the control panel comes on and it does nothing when the power button is pressed.
  • 9 more comments
  • Anonymous Feb 22, 2008
    After plug in yellow light lights up, but nothing works.
  • Rayven Feb 22, 2008
    caution light comes on when heater is plugged up. What is the problem? Nothing is blocking it.
  • firebug1447 Feb 24, 2008
    I am having the same problem. I turned it on this morning and when I came home after lunch, there was a yellowish/ orange light on. None of the buttons work. I tried unplugging the unit for a couple of minutes, but to so avail. How do I fix this problem?
  • jaybird32 Mar 19, 2008
    same problem turn heater on few seconds later yellow light comes on and heater wont do anything
  • Anonymous Apr 30, 2008
    the heater caution light stays no it will not work . i unpugged it for a day
    plugged it back in nothing nothing works
  • Alucard185 Oct 29, 2008
    i have the problem with the caution light as well. took the whole thing apart and let it sit overnight, no help at all. and you people who post your Problem in the SOLUTION section, with the exception of the last guy, are idiots.
  • gkfriers Nov 09, 2008
    Same problem. I'm calling the company on Monday.  I'll post the information they give me.
  • Anonymous Nov 11, 2008
    lights on but no heat no digital display
  • Anonymous Dec 10, 2008
    The caution light won't turn off ! I can't get any of the buttons to turn on. I unplugged it for a few days, that didn't help either. I will try to called Lasko for help. Thanks
  • hotgirl12320
    hotgirl12320 Feb 09, 2012
    IVE NEVER HAD A PROBLEM WITH MINE HAD MINE FOR 6 YEARS NEVER A PROBLEM NOPE NOPE MY HEATER CAME OUT AWESOME
  • Clark with Big Toast Dec 11, 2012
    MILKHOUSE HEATER "CAUTION LIGHT" SOLUTION: Unplug the heater. Open it up and clean it out. I mean, buy a can of non-chlorinated brake cleaner and squirt all of the contacts good. Below the fan there is a sensor mounted on the heater element box on the bottom. That goes bad and causes it to trip. While you are there, squirt the motor bushings good with the brake cleaner and dab a drop of synthetic motor oil (just a drop) on EACH of the two motor bushings. Personally, I rewired this and bypassed all of the safety features. You can bypass that sensor without soldering or cutting any wires. All you have to do is unscrew the wires from the holder and then unscrew the tiny nuts and tiny bolts. Then bolt the together at one end (note the position) and put it back in the holder and tighten the screw to hold it in. This method fixes the issue completely as it removes the sensor from the equation. In fact, I just did that on my third milkhouse heater and it has been running solid for the last 15 minutes. Use your modified heater with caution!
Underneath the heater element are two thermostats that are run in series with each other. Inside the wire that connects them is a thermal fuse that opened up. Replacing the fuse corrected the problem.
Posted on Nov 10, 2008
The Lasko heater model 5620 is a piece of junk. throw it in the garbage.
Posted on Dec 23, 2008
I have the same problem, i bought this from lowes about 4 months ago and the orange light came on a few days ago so i unplugged it for a day and when i plug it back up, same thing, I cant get it to work. Any suggestions, please post
Posted on Mar 20, 2008
I'm having the same problem. The caution light came on today and has not been turned off. I need this heater!
Posted on Feb 24, 2008
  • 506 Answers
One of the two thermostats died in mine. They are NC170 deg C thermostats. (NC = normally closed) Since they are NC they read shorted at room temp, just use an Ohm meter or check for continuity and you are all set.
Posted on Dec 13, 2009
  • RedWireNut Dec 13, 2010
    Allied Electronics has these thermostats. Allied part # 557-0020 or mfr (Selco?)part # OR-350-QC. Price in 2009 catalog has gone up (doesn't everything?)
  • RedWireNut Dec 31, 2010
    The inline TCO thermal fuse located in the line between the two snap disc thermostats is a NTE #8181 and can be obtained from Newark Electronics.
    Newark SKU #06M7506 http://www.newark.com/jsp/content/printC...
How do i change the temperature setting on a lasko 5628 without a remote
Posted on Mar 11, 2012
Got this info off their website:
SAFETY FEATURES
1. A thermal overload protector is built in to prevent overheating.
2. When an overheat temperature is reached, the Heater will be automatically
shut off and the CAUTION light will be lit. After the
CAUTION light goes off, you may resume normal operation.
3. If the Heater senses that the room temperature is too high, the
Heater will shut off, the display will begin to flash and the green
heating light will also flash. To reset the unit, unplug the Heater
and wait 10 minutes for the Heater to cool down.
4. After the Heater has cooled down, follow the operation instructions
described in this manual.
MODEL 5620
TROUBLE TIPS
If your heater shuts off unexpectedly or fails to operate, one of
the above-mentioned safety features may have been activated
1. Be sure the power cord is plugged into a working electrical outlet.
2. Check your Thermostat setting. The Heater may be off because
it has reached the desired temperature setting.
If you have a problem that can not be resolve by the steps listed
above, contact Technical Assistance at 800-233-0268, Monday
through Friday, between the hours of 8am and 5pm EST.
Posted on Aug 26, 2008
  • mystuff2 Jan 05, 2011
    Dahhh!
    I already read the (Useless) manual!
LASKO 5624 will not turn on. The red light underneath the clock button is on. How do I reset? Is this broke after 20 uses?
Disconnect power, (unplug); wait for over 20 minutes, (have a cup of coffee); Depress power button before pluggging in to wall socket . (This will let any voltages that are stored in the unit drain off).
Plug in to AC outlet and press power to turn on.
If this doesn't work, Lasko has a 3 year warantee.
CUSTOMER SERVICE:
Toll-Free (800) 233-0268. Email: producthelp@laskoproducts.com
Feb 02, 2015 | Lasko 5624 1500 Watt Convection Heater w/...
Caution light
when did this started happening?
Mar 16, 2008 | Heating & Cooling
Nothing when plugged in to a live outlet
There should be a fuse inside the unit somewhere, look for a small panel that comes off and behind it should be a fuse you can replace. The cover plate might be circular and when you take it off the fuse should just slide out.
Jun 17, 2011 | Lasko 5536 Ceramic Heater
Orange light came on
The orange light is just an indicator light to show you that the heater is working...there is nothing wrong and nothing to worry about...
heatman101
Jan 04, 2011 | Lasko 5620 Electric Baseboard Heater
Our Lasko 5620 has a digital control, but we can't set the temperature. It says at 76 degrees, no matter what we do. Hitting the control buttons does not work.
Based from your comments, it seems that you have a
defective digital control. Have a check up for this item.
It may need to be replaced. Hope this will help you.
Jan 10, 2010 | Lasko 5610 Baseboard Heater
Need manuall for model 5620 electric baseboard heater
If google and manufacturer website are of no help then ask a search agency like http://manualfox.com - They do a great job.
The service is not for free, but often worthy (you only pay if they find what you are asking for).
Jan 04, 2010 | Lasko Under Desk Space-Saving Area Heater...
Cannot get the heating element to turn off properly on Lasko 5620
From whatI have seen on base board heaters if I recall correctly, the thermostat may be sepperate. Usually thermostats on these have a round knob. 1 line goes to this and the other side of the thermostat goes to 1 end of th element and the othe line attaches to the other side of the element. Its possible you have the element wired in directky if it came without a thermostat and without instructions it may till be connected directly. You should have an L1 and L2 connection and hope there is a wire diagram on the cover.
THE reason these basebord heaters used to come without a thermostat is because they are (OR WERE)set up to add on additional heaters comming right on down the wall. At the last one you could tie in and get a correct rated thermostat installed in the center of the series.
Return to LOWES and ask them to remove the instructions and copy them for you from another like model. Or have them contact the manufacturer and request they fax a copy of instructions with a diagram. Also ask if the heater comes with a thermostat. It may stoill be sepperate in another kit.
Mar 04, 2009 | Lasko 5610 Baseboard Heater
Yellow caution light
I also have the model 5620. with the yellow caution light on. After taking the unit completely apart I found 2 thermal fuses on the bottom of the unit(appox. size of a nickel). They are located under 'U" shaped brackets which are below the medal heating element. The thermal fuses do not reset. you could test them with a drip or two of souder or wire on the top - if you ran the heater this way it would be a safety problem as the fuse would be overridden. I am throwning mine away.
Lasko 5610 red caution light, no power
the caution light is telling you something is wrong. most wired baseboard heaters have a hi limit cutout that may be bad.  it is connected into the heater circuit as a safety device.  you could jump out this element to test this theory.  if the element is shorted, certainly it would blow a fuse or circuit breaker.  if the element is open it won't heat at all.  you need to take it apart and use a test meter to troubleshoot it.
Jan 02, 2007 | Lasko 5610 Baseboard Heater
Heating & Cooling Logo
5,269 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
