We have a problem in our church with what sounds like the mic. cutting out at times then it will work for quite a while then for no reason it will cut out again. I have checked connections can't find any loose wires or wires touching each other can there be some adjustment I need to make. We had a group come in and use the system for a performance and when they left we made some adjustments back to where we had it and things worked great for about 6 months then for no reason that I know of it started acting up again.
There are so many variables with sound systems, sometimes it's hard to isolate the problem. When I have a problem with the sound system at my church I usually try and force the problem again. In my experience it's usually been the cable that will go bad before the microphone. Try moving the cable around at the end where it plugs into the microphone, if you get any crackling or popping it usually means the cable has a short in it somewhere. Another problem I run into pretty often is that the channel on the soundboard is having problems. Try switching channels and see if the problem comes up again.
